Quantcast Calling all v8s! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Calling all v8s!
Free Shipping on all Engo Winches Continues...starting at Black Magic Brakes - 5% Off, No Minimum Purchase RequiredOfficial Chassis Saver Rust Preventive Truck & Auto Un
Old 11-03-2009, 01:43 PM   #1
Peej03
Calling all v8s!
If you guys could share your overall gear ratio with me that would be great. (first gear x transfer case x axle)
I know what is ideal for the 4.0, but the v8 has more power. So when I think of the 4 banger needing to be geared to 4.88, and the inline six being geared to 4.56, does that mean a V8 should run 4.10 for a 33 inch tire?
originally I had planned on running 94:1 on 33s. This sounded WAY to low. So I a revamped my v8 swap plan and got it down to 63:1, how does that sound for a v8 on 33s? Still too low?
They Call me..Peej
2003 TJ SE Trail Rider/DD
1982 CJ5 Project
Peej03 is offline   Reply With Quote
Old 11-03-2009, 01:48 PM   #2
NotURMailman
Straight Up Fool!
NotURMailman's Avatar
Which V8 are you planning on running? Tranny? T-case? In most cases 4.10:1 is good with a V8 and 33s...
My RHD TJ - Savvy equipped... And loving it! - Durty Rok Carolina Offroad
I drive on the right side, what's wrong with you?
Be very careful with the wife mod. Uninstallation can be extremely expensive. Wife mods have been known to take the Jeep and all other mods during the uninstall process. Also, make sure you service your wife mod properly as often as humanly possible. Wife mods not properly serviced may malfuction or uninstall themselves at any time.
NotURMailman is offline   Reply With Quote
Old 11-03-2009, 01:51 PM   #3
Peej03
5.9 magnum, np231, nv4500 five speed (5.61) first gear. Leaving 4.10 axle gearing.
They Call me..Peej
1982 CJ5 Project
Old 11-03-2009, 01:55 PM   #4
NotURMailman
Straight Up Fool!
SO if you already know everything you are going to run, what is the question? I thought you were trying to select a axle ratio? Or are you just wanting to compare crawl ratios with other V8 set ups?
Old 11-03-2009, 02:27 PM   #5
2000jeeper
To the OP From what i have found out with the 5.9 NV4500 and 231 tcase the 4.10 will be more then adiquit (spelling). I have a friend back in delaware that is running the 5.9 nv3500 and 231 tcase on 35's and he says it is perfect. That is what i plan on doing as mine already has 4.10's. Just need to build the 8.8 with 4.10's
AMSOIL DEALER
2000jeeper is offline   Reply With Quote
Old 11-03-2009, 02:39 PM   #6
Peej03
I fear the gear. lol
I wanted to compare crawl ratios with other v8s. And see if I need to lower my axle ratio or select a different transmission with a 4.03 first gear or something.
They Call me..Peej
1982 CJ5 Project
Old 11-03-2009, 02:45 PM   #7
Peej03
what axle gearing is he running?
if the nv3500 on 35s is perfect, maybe I need to higher my gearing since the nv4500 is a considerably lower gear. And 35 > 33 lol
Crap
They Call me..Peej
1982 CJ5 Project
Old 11-03-2009, 02:57 PM   #8
NotURMailman
Straight Up Fool!
You're thinking too hard! If you already have the axles geared to 4.10 then run it and see what you think...
Old 11-03-2009, 03:11 PM   #9
Peej03
Genius. lol
I keep forgetting about this, I just dont know if I will have to be changing driveshafts lengths constantly. for the lift, then for the engine, then maybe again when I swap my rear axle for a 44.
I think I can make it work though.
Still, anyone who wants to throw up their gearing ratio would be very helpful
They Call me..Peej
1982 CJ5 Project
Old 11-03-2009, 03:15 PM   #10
lumpster
lumpster's Avatar
run what you got, the v8 will have the torque to turn 33's with 4.10's. you could probably get away with 35's. 5.9 should be 2k rpm or just under for highway use.
Originally Posted by SuperWade2 View Post
Blaine asked me before we left camp if I'd ever been wheeling before, I said "sure, of course I have"... about 50 feet onto the trail, he said "Wade, you f'in lied to me, you've never been WHEELING before"... I think he was right! :rofl:
Want to STOP?
JEEP Co-op parts, jk, tj, lj, yj, cj delrin door bushings, TRE inserts, poolball shifters, tierod flip kits
My Goodyear tire experience
lumpster is offline   Reply With Quote
Glock Forum
