Caliper bolt stripped, how to get off? - JeepForum.com
post #1 of 34 Old 12-18-2009, 02:53 PM Thread Starter
TheDragonfly
I decided to change the brake pads myself. When I went to get the caliper off, the bolts were so corroded that theyre practically round. The sockets aren't gripping on to anything. I went at it with a monkey wrench too but cant get any grip anywhere. How am I going to get these things off?
TheDragonfly is offline
post #2 of 34 Old 12-18-2009, 03:21 PM
BomberJeep
2011 WK
I cant remember the name of the sockets but there is a set that grab on to the side of the head not just the points. Supposedly they are really good.
Never get between a man and his Jeep - Stacey David.
BomberJeep is offline
post #3 of 34 Old 12-18-2009, 03:21 PM
SantaAnaSlim
2004 XJ Cherokee
Vice Grips? I suppose worst case if you cut the heads off, you will be able to pull the caliper off and then you'll have a whole bolt to grab onto and unscrew.
SantaAnaSlim is offline
post #4 of 34 Old 12-18-2009, 03:37 PM
Varnish
Varnish's Avatar
If they will fit, this type of bolt-out kit.
http://www.sears.com/shc/s/p_10153_1...yword=bolt+out
They come in smaller sets.
'98 TJ, '06 LJ, '88 YJ
Varnish is offline
post #5 of 34 Old 12-18-2009, 03:44 PM
dustinnice
1980 CJ7
yeah the bolt out kits are good. if worse comes to worse you can weld another bolt head on top of the stripped one
dustinnice is offline
post #6 of 34 Old 12-18-2009, 04:01 PM Thread Starter
TheDragonfly
Okay im going to head to sears to try out those bolt out kits. Home depot and lowes didnt have anything like that. We'll see if that works.
post #7 of 34 Old 12-18-2009, 04:11 PM
98TjTommy
I have been able to cut a cross into some bolt heads and use a large screwdriver tip to break them loose.. I have a tip that fits in a socket for pressure and leverage.
98TjTommy is offline
post #8 of 34 Old 12-18-2009, 05:24 PM
jgorm
jgorm's Avatar
If a monkey wrench wont do it, then those bolt outs are not even going to get close. Maybe you need a smaller pipe wrench? Can you fit it on there good? I've never seen a pipe wrench slip on anything if you load it up correctly. If it will fit on there, a pipe wrench is by far the best tool to use. Sure a welder will work, but if the bolt is that rusty you'd have to grind at it to clean it up, then lug out the welder.
jgorm is offline
post #9 of 34 Old 12-18-2009, 05:29 PM
NEPAjeep02
NEPAjeep02's Avatar
Go will the torch for a few seconds then wart remover. The kind that freezes instantly. No bolt can stand up against that combo
NEPAjeep02 is offline
post #10 of 34 Old 12-18-2009, 05:31 PM
dustinnice
1980 CJ7
yeah welding is kind of a last ditch thing. stripped bolts are the devil as far as im concerned
post #11 of 34 Old 12-18-2009, 11:03 PM Thread Starter
TheDragonfly
Thanks for the input everyone but the bolt out sockets actually worked out great for me! I was surprised at such a simple concept. I found a set of 6 for only $19.99. I used the size smaller and fit it on nice and tight with a rubber hammer. Then I just had to turn it and break it free from the rust after soaking it in some more wd40. The bolt heads looked like they went through a garagedisposal afterwards, but thats nothing a trip to autozone couldn't fix.
post #12 of 34 Old 12-18-2009, 11:09 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Next time you need a liquid penetrant to get hardware loosened up from corrosion, use something like Liquid Wrench, Break-Free, or PB-Blaster. Using WD-40 for that job is like toasting your new bride or celebrating New Years with 7-Up. It may look like the same stuff but it's not and it doesn't work nearly as well.
Jerry Bransford is online now
post #13 of 34 Old 12-19-2009, 12:48 AM
zachjf
how does one remove the caliper when it still has brake pads and a rotor in the way of sliding it off?
Needs parts?
PM
or
zachjf is offline
post #14 of 34 Old 12-19-2009, 01:59 AM
Varnish
Varnish's Avatar
Why wouldn't the rotor come off with it? Just held on by caliper.
Varnish is offline
post #15 of 34 Old 12-19-2009, 02:45 AM
zachjf
the rotor would have to clear the wheel studs as well the the hub with the upper edge locked into the caliper. Rotor removal is impossible with the caliper still attached to the vehicle, if it wasn't you could replace rotors without removing the caliper. Not saying its absolutely impossible but you'd end up damaging a bunch of stuff to create the clearance to make it possible
Needs parts?
PM
or
zachjf is offline
Stripped Brake Caliper Bolt at the knuckle JeepRocks86 TJ Wrangler Technical Forum 19 05-08-2010 06:59 PM
Knuckle threads for Caliper bolts STRIPPED sebastian22 YJ Wrangler Technical Forum 16 12-15-2008 07:24 AM
Bottom bolt on front brake caliper stripped athos76 TJ Wrangler Technical Forum 1 08-09-2008 04:41 PM
Helicoil for Stripped Front Caliper?? gtospeeding TJ Wrangler Technical Forum 22 09-08-2007 09:50 AM
Size of helicoil for caliper bolt/stripped knuckle repair? Alheim YJ Wrangler Technical Forum 8 05-23-2007 05:46 AM
