Cable fuse From alternator upgrade - JeepForum.com
post #1 of 7 Old 08-02-2010, 09:04 AM Thread Starter
dickyson
Fuse wire From alternator upgrade need help
Hello everyone,
I just upgraded my alternator and the company that sold it to me said that the cable had also to be changed to 2 gauge. So went ahead and replaced the cable but noticed that there is a wire fuse (someone told me that it is a cable that works as a fuse and has silver in it or some sort of material, this cable runs from the alternator to the fuse box which then runs to the battery) anyways I changed my new cable to 2 gauge, can anyone fill me in to what cable fuse should I buy to place the fuse cable or what to do to protect the battery in case the alternator goes wrong?
2005 wrangler rubicon
thank you!
Last edited by dickyson; 08-02-2010 at 01:01 PM. Reason: forgot the word need help in the title
dickyson is offline
post #2 of 7 Old 08-02-2010, 01:55 PM
BlueFlame
BlueFlame's Avatar
It's called a fusible link.
BlueFlame is offline
post #3 of 7 Old 08-02-2010, 02:02 PM Thread Starter
dickyson
thanks ,
now I just need to know what gauge of fusible link to buy for a 205 amp alternator with a 2 gauge cable.
dickyson is offline
post #4 of 7 Old 08-02-2010, 02:34 PM
RubiOR
From Wikipedia
An electrical fusible link is a type of electrical fuse that is constructed simply with a short piece of wire typically four [American wire gauge] sizes smaller than the wire that is being protected. For example, an AWG 16 fusible link might be used to protect AWG 12 wiring. Electrical Fusible links are common in high-current automotive applications. The wire in an electrical fusible link is encased in high-temperature fire-resistant insulation to reduce hazards when the wire melts
I'd like to hear more about your 205A alternator...
'06 Solar Yellow Rubicon Unlimited --
Their huge yellow spaceships hung in the air in exactly the same way that bricks don't. -- Douglas Adams, Hitch Hiker's Guide to the Galaxy
RubiOR is offline
post #5 of 7 Old 08-02-2010, 02:56 PM Thread Starter
dickyson
205 amp alterator
Thanks for the info from Wikipedia. Finally that resolves my problem.
Regarding the alternator $299 205 amps (load Boss) , plus the 2 gauge cable that was $20 or $30 , here is the website:
Alterstart
Let me know if you need anything else
dickyson is offline
post #6 of 7 Old 08-02-2010, 03:50 PM
5-90
5-90's Avatar
1988 XJ Cherokee
You'll have a hard time finding 6AWG fusible link wire anywhere (I've been looking for 10AWG for years!)
Use a 225A ANL or MEGA fuse instead. I can help you there if you like - link in sig.
"recon" (sic - reckon)(tm) "hihgly"(tm) "seceed"(tm)
"Outback AIDS - Alcohol-Induced Dizzy Spells"
5-90 is offline
post #7 of 7 Old 08-02-2010, 03:56 PM Thread Starter
dickyson
thanks, your right, best i could find is 10 gauge fusible link, perhaps adding the 10 gauge and the MEGA fuse or ANL will have a better protection.
dickyson is offline
alternator , fuse , cable , upgrade , tj , wrangler
Fusible link (?) on TJ Alternator Cable? Woodyhfd TJ Wrangler Technical Forum 7 03-16-2016 10:30 PM
Alternator upgrade bilabong TJ Wrangler Technical Forum 3 11-09-2008 01:43 PM
alternator cable pkmkelly TJ Wrangler Technical Forum 0 07-20-2008 03:01 PM
Alternator Upgrade? 08 Sahara YJ Wrangler Technical Forum 12 11-13-2007 09:56 PM
Alternator upgrade 2000yellowtj TJ Wrangler Technical Forum 1 05-18-2006 04:53 PM
