in-cab electrical ALL dead, gauges, lights and switches - JeepForum.com
post #1 of 6 Old 07-28-2010, 04:55 AM Thread Starter
whatevah
Posting for a buddy, way too busy with running a new business and family.
04 TJ, 4.0L Battery in the Jeep died in the winter (left something on) and he replaced the battery with a new one. But didn't tighten the brackets enough and the battery slid. The positive post/cable hit the body of the Jeep and everything electrical shut off. Engine would still run and he could drive it, but nothing electrical worked...
A few months of sitting later, battery died. Recharged it and everything worked until he steps on the brake or turns the lights on and everything shuts off again.
had the alternator tested at pep boys, says it's ok. he checked all the fuses under the hood and glove box and they all appear to be ok. Checked wires underhood between battery, starter and alternator, all look fine. Nothing melted, burned or broken.
I loaned him my OBD reader and at least that still works, picked up an emissions code P0443.
Any ideas I can pass on? I searched on here for a bit, but only found threads related to the guage cluster connectors (which he did check).
EMT/Firefighter... 2012 Rubicon, AEV 2.5" lift, JCR stubby winch bumper with HID lights, JCR engine skid, ACE side steps.
formerly- 2001 XJ, 7" longarm, 35s, etc.
whatevah is offline
post #2 of 6 Old 07-28-2010, 05:28 AM
cidd
more than likely fryed a grounding strap or ground wirer somewere.
cidd is offline
post #3 of 6 Old 07-28-2010, 11:02 PM Thread Starter
whatevah
I stopped by to look at his TJ today while he was at work, the ground strap from the back of the block to the firewall is in 2 pieces. That may have something to do with it...
whatevah is offline
post #4 of 6 Old 07-28-2010, 11:04 PM
1990offroadYJ
that would definatly cause a huge problem. after my motor swap i forgot that ground strap and the jeep ran like garbage. put it on and everything is good
1990offroadYJ is offline
post #5 of 6 Old 08-04-2010, 06:56 PM Thread Starter
whatevah
a quick update... I stopped by his house and looked over the engine compartment for him. I checked all the fuses and relays and started on the wiring. The ground wire from the battery to the engine was fine, but the braided grounding strap from the back of the engine to the firewall was broken/torn/burnt through around 4 inches from the firewall. He replaced it a few days ago and all appears to be back to normal. His wife was a little annoyed that his Jeep was sitting in the driveway for 6 months when all it needed was a 5 minute fix. hehe
whatevah is offline
post #6 of 6 Old 08-04-2010, 09:04 PM
1990offroadYJ
thats good to hear. Another jeep on the road!
electric , electrical , battery , dead , ground , grounded , wire , tj , wrangler
Customish Electrical Gauge's Project (replace my 88 gauges with 95 gauges) kgillette YJ Wrangler Technical Forum 15 08-12-2009 08:51 AM
Electrical gremlin, low volts, and gauges and lights don't work bclg YJ Wrangler Technical Forum 2 04-25-2009 10:36 PM
Flasher Electrical Problem - All Lights Flash...including all the dash gauges ozdevil YJ Wrangler Technical Forum 7 09-03-2008 03:28 PM
Dead Gauges, FAQ Link Is Dead omnipseudo TJ Wrangler Technical Forum 2 05-01-2004 09:05 PM
