A.C. problems - JeepForum.com
post #1 of 6 Old 07-20-2012, 10:48 PM Thread Starter
abrown2669
A.C. problems
My 98 tj air blows cold for a while then starts to blow not so cold. Noticed some condensation around vents and some dripping in the floor both driver and pass side. Just replaced serpentine belt.I also noticed the fan blows harder when its NOT on recirculate. This is my first post and any help is greatly appreciated.
abrown2669 is offline
post #2 of 6 Old 07-21-2012, 12:16 AM
Reptile
1991 XJ Cherokee
Is your aux fan running with AC on?
Reptile is offline
post #3 of 6 Old 07-21-2012, 12:29 AM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
He has a TJ.
What aux fan?...
Knuckelhead is offline
post #4 of 6 Old 07-21-2012, 01:00 AM
Reptile
1991 XJ Cherokee
Originally Posted by Knuckelhead View Post
He has a TJ.
What aux fan?...
E-fan. I do realize, still the 4.0... besides any AC system works the same regardless of vehicle.
Reptile is offline
post #5 of 6 Old 07-21-2012, 09:31 AM
Knuckelhead
AFSOC Retired
The only electrical fan (OEM) in his TJ is the HVAC fan and he says its working...
post #6 of 6 Old 07-21-2012, 10:08 AM
Reptile
1991 XJ Cherokee
My bad then.
The water in the cabin is probably a clogged evaporator drain tube.
http://www.jeepforum.com/forum/f11/w...reeze-1385164/
If this doesn't help making it colder, there might be moisture in the system freezing up the orifice tube inside the evaporator. Vacuum up the system 30" of Hg, then refill to specs.
Reptile is offline
a.c. , air conditioning , tj
Ignition problems....well, actually key problems... redblur YJ Wrangler Technical Forum 4 11-28-2010 09:08 PM
Problems Getting into 4-Low aontkos YJ Wrangler Technical Forum 17 04-24-2010 11:06 PM
LED Tails - problems problems problems! Zachs TJ Wrangler Technical Forum 5 07-20-2009 10:21 PM
4WD Problems Deere9670 TJ Wrangler Technical Forum 6 04-28-2008 08:57 PM
D44 Gear Problems, shaft problems. lazerusrm TJ Wrangler Technical Forum 7 04-09-2008 05:29 PM
