A/C Problem - JeepForum.com
post #1 of 4 Old 08-06-2010, 09:55 PM Thread Starter
m361
A/C Problem
NEW MEMBER AND JEEP OWNER!I have a 1997 Jeep Wrangler Sport (TJ) w/ the 4.o I-6 engine. I just purchased it 3 days ago so I don't know much about it. After driving today, I noticed an oilly fluid with a green tint on the top of the front passenger fender. When I opened the hood, the same fluid was sprayed on the underside of the hood and the battery area. It appears that the larger hose on the A/C accumulator has pulled out of the pipe fitting it was attached to and the fluid came out of the hose. There is still a metal clip on the hose. The A/C now only blows warm air. Can I just put that hose back into the pipe or is this gonna require a more extensive/expensive repair?
m361 is offline
post #2 of 4 Old 08-07-2010, 01:36 AM
DallastheJeeper
You are going to have to get a new end crimped onto the hose and then get a new accumulator ($45) then if you live in a state that you can buy refrigerant do it yourself (about $20) or have a shop do it. Also do not turn on your A/C or your defroster until you have fixed it otherwise your compressor could get damaged.
DallastheJeeper is offline
post #3 of 4 Old 08-07-2010, 08:39 AM
mikevsgeek
You will also want to have the system evacuated after you have the line and the accumulator replaced. Anytime the system is open like that, its also advised to have the orifice tube replaced.
mikevsgeek is offline
post #4 of 4 Old 08-07-2010, 11:40 AM Thread Starter
m361
Thanks for the help on that. Looks like its gonna be a bit more extensive/expensive that I thought. Probably better leave this one to the pros.
m361 is offline
ac , a/c , loose , hose , tj , wrangler , repair
clutch problem ? Master / Slave Cylinder Problem rthompson48082 YJ Wrangler Technical Forum 34 11-30-2011 06:31 PM
Belt problem, blinker problem, and a random problem... Mike89db TJ Wrangler Technical Forum 10 12-14-2009 06:34 AM
brake pad problem, and front drive shaft problem bluejeep2088 TJ Wrangler Technical Forum 1 05-12-2008 10:34 AM
Brake Fluid problem or Jeep Drinking problem daledaniel TJ Wrangler Technical Forum 6 01-04-2008 10:11 PM
FINALLY! fixed idle problem and stalling problem Big-n-Broke-YJ YJ Wrangler Technical Forum 4 02-28-2006 08:50 PM
