Quantcast A/C overheat - JeepForum.com
jeeppartsdept.com
Get your jeep parts here. Full line Jeep dealer. HUGE DISCOUNTS!
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > A/C overheat
JKS products - Free shipping! Lowest prices!East Coast Gear Supply- Quality Diff PartsJeep CJ, YJ, and TJ build your own bumper packages.
Old 06-23-2003, 07:52 PM   #1
Zookeeper
A/C overheat
I have an '03 TJ Sport with the 6-cyl. When I run the A/C, it runs a little hotter than normal, which I consider to be reasonable. However, sometimes when decelerating from freeway speeds, such as coming down an exit ramp, the temperature will spike to where it says the engine is overheating. Then, it will come back to normal within a couple of minutes of driving.
I recently had the dealership replace a blown water pump...
Any ideas on what might be causing this weirdness? Anyone else having this problem?
Ari Adler
KD8CXP
Zookeeper is offline   Reply With Quote
Old 06-23-2003, 07:57 PM   #2
davebelair
when I bought my 97 a year ago I noticed the water temp to be over aveage when using a/c but it never overheated I thought maybe gauge isn't accurate. anyway it turn out to be the themistat was sticking a little I had that changed and now it has not gone over 210 I hope this helps...
davebelair is offline   Reply With Quote
Old 06-23-2003, 08:07 PM   #3
bigmatt
Zookeeper
I have a 03 sport with A/C also,I will check it out .
91yj 4 banger, 265,000 miles,100% stock ,bought it new.NOW SOLD,
03 TJ sport, stock 4.0.dana 44 ,red w/black hardtop
2001 XJ Sport, stock 4.0L 130.000miles,soon to have new motor.)0331 head issue.
bigmatt is offline   Reply With Quote
Old 06-24-2003, 04:21 AM   #4
K9JEEP
Registered Abuser
Sounds like a flakey thermostat, which would possibly cause damage to water pumps. Perhaps even a blockage elsewhere. You're still under warrenty, go have it checked out and verified, you've paid for it.
K9Jeep
Http://www.dso4x4.com
K9JEEP is offline   Reply With Quote
Old 06-24-2003, 06:18 AM   #5
Zookeeper
Thanks. I knew somebody here would know something about this!
Ari Adler
KD8CXP
Glock Forum
