A/C and Heater blower motor not working - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > A/C and Heater blower motor not working
Unread 11-13-2012, 10:06 PM   #1
TresMarkham
My blower on my heating and A/C is not working. When I am driving air will barely come out but other than that nothing. A few months ago it only ran on high, and now if I hit a hard bump the high setting will sometimes kick back in. I'm pretty sure that it is either the blower motor resistor or the blower motor control switch. Any ideas?
TresMarkham is offline   Reply With Quote Quick reply to this message
Unread 11-14-2012, 06:25 AM   #2
jdhawes
Got a similar issue also, but my blower only works in the top two positions. It has been like that for almost a year but i am sure it is on its way to going completley out. I was going to start with the switch, then move onto the resistor.
2006 Jeep Wrangler TJ
4" Tuff Country EZ Ride Suspension Lift
33" Mickey Thompson All-Terrains
jdhawes is offline   Reply With Quote Quick reply to this message
Unread 11-14-2012, 06:38 AM   #3
JPNinPA
Sounds like you may have more than one issue. First look over the motor wiring and ground, select switch and connection and connection at the resistor. Look for melted wiring. Once you get the high setting to work properly then look at replacing the resistor.
There are several posts on here with photos of what to look for.
"Never look down on anyone unless your helping them up"- Jesse Jackson
JPNinPA is offline   Reply With Quote Quick reply to this message
a/c , blower , broken , heater , help please
