A/C doesnt work on 1st or 2nd power setting - JeepForum.com
post #1 of 4 Old 07-27-2010, 04:39 PM Thread Starter
calrain07
It doesn't matter what vent setting i put it on only 3rd and 4th speed work, 2nd speed only blows air when i move. when i first got the jeep all the speeds worked perfectly fine...what could be the problem? if you need more details i'd be happy to give more information.
'05 rocky mountain edition....kc daylighters, 33x12.5x15 Duratracs, RC 3.25" SL, and 1.25" Spidertraxes
calrain07 is offline
post #2 of 4 Old 07-27-2010, 04:42 PM
SaxManClay
It's the blower motor resistor. It's pretty easy to install yourself. If you search "blower motor resistor," you should be able to find a thread or two about it.
My Jeeps name is TUG!
What I'm all about.
SaxManClay is offline
post #3 of 4 Old 07-27-2010, 04:44 PM
SaxManClay
Here is the link.
http://www.jeepforum.com/forum/f9/bl...sistor-347106/
What I'm all about.
post #4 of 4 Old 07-27-2010, 05:19 PM
wushaw
Rockin jeep
wushaw's Avatar
I can see it on the resistor for the first speed but second only working when ya get movin is kind of a mystery. I just wonder if the blower motor is getting a little long in the tooth (05 or not) and has built up a little resistance to the low volts it's getting on one and it takes a little umph from the alt to get her going in the second speed.
wushaw is offline
ac , a/c , setting , blower , broke , tj , wrangler
4wd doesnt work newjeeper369 YJ Wrangler Technical Forum 2 02-11-2010 03:47 PM
Fan doesn't work on any setting xltj TJ Wrangler Technical Forum 22 07-27-2008 09:01 AM
3rd Setting in Blower doesnt work? rreynolds12 TJ Wrangler Technical Forum 14 10-01-2007 03:48 PM
AC/HEAT doesnt work in 3rd setting. RedWrangler99 TJ Wrangler Technical Forum 2 05-06-2006 09:50 AM
Low setting on fan doesn't work. killamike YJ Wrangler Technical Forum 1 06-02-2005 09:22 PM
