A/C condensate floor puddle? - JeepForum.com
post #1 of 7 Old 09-22-2017, 10:54 AM Thread Starter
Assassn8r
I have a '97 TJ that dribbles A/C condensate water on my passenger side floorboard. I have blown thru the firewall drain and vacuumed the drain with an adapted shop vac hose. The puddles continue. Does anybody out here in Jeepworld have an idea for a fix?
Assassn8r is offline
post #2 of 7 Old 09-22-2017, 12:59 PM
Jeepsr4me
the ac box may have a hole in it..
Jeepsr4me is offline
post #3 of 7 Old 09-22-2017, 08:26 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
From somewhere in the back of my mind I remember an "L" (pointing down) shaped rubber hose being added to the drain port coming out of the firewall. This is used because when driving the air coming through the engine cavity would push the condensing water back along the drain port and dropping inside the back of the firewall.
I added a hose to the port to send that drainage back to mid frame. I don't like any fluids dripping/draining from my engine compartment onto the ground. I did the same thing for the windshield washer tank and the coolant reservoir...
Knuckelhead is offline
post #4 of 7 Old 09-22-2017, 08:37 PM
Freeagent27
Originally Posted by Knuckelhead
From somewhere in the back of my mind I remember an "L" (pointing down) shaped rubber hose being added to the drain port coming out of the firewall. This is used because when driving the air coming through the engine cavity would push the condensing water back along the drain port and dropping inside the back of the firewall. I added a hose to the port to send that drainage back to mid frame. I don't like any fluids dripping/draining from my engine compartment onto the ground. I did the same thing for the windshield washer tank and the coolant reservoir...
I put a little rubber grommet on my drain as mine always leaked on the floor only at highway speeds with the a/c on. I think you are correct with the elbow, as I remember reading that on the forum a while back ago too
"My thoughts on yoga pants? Depends who I'm walking behind".
Freeagent27 is offline
post #5 of 7 Old 09-23-2017, 05:30 AM
2jhanna
I found that a standard 1/2 pvc elbow from lowes/home depot plumbing section for .29 was a perfect fit, no glue required. A little black spray paint to make it blend in.
jhanna
denton county, tx
2jhanna is offline
post #6 of 7 Old 09-23-2017, 06:45 PM
2004CSOTP
Same as above. I had a large puddle on the passenger side floor until I installed an elbow shaped hose on the evaporator drain. This part often falls off.
2002 TJ Wrangler X
4.0L automatic
pretty much stock other than 31s
2004CSOTP is offline
post #7 of 7 Old 09-23-2017, 08:28 PM
Momamac
I think that the 90 elbow was an afterthought by Jeep. I made my own from heater hose parts I had laying around. No drips all summer, even after a 6 hour + drive from Michigan to Indiana and back with the air on most of the time!
Sent from my VS990 using Tapatalk
Momamac is offline
