a/c clutch removal - JeepForum.com
post #1 of 17 Old 06-07-2006, 07:33 PM Thread Starter
dougthecat
a/c clutch removal
Guys need a little help.
I am trying to remove the a/c clutch to replace the bearing... Very noisy.
I rented all the pullers at the local autozone, but none seem to fit.
Does any one know hoe to remove this without damage or else can someone look it up in a service manual and let me know.
Thanks
dougthecat is offline
post #2 of 17 Old 06-07-2006, 07:56 PM
Scott_98TJ
On my 98, I removed the outer nut, the plate, some shims and a key along with a snap ring, and then there was another snap ring inside the belt pulley. IIRC I used a few taps with a rubber mallet to work the pulley off. Sometimes you can thread a bolt into the front to remove a pulley, I know I do that on my OBA clutch, but dont recall if you can on the AC unit.
FYI I know that some people have replaced their bearing, but it's built and sold as a non service item. The bearing is stamped in. Yes, you can get it out, but it's not as straight forward as it could be.
98 TJ 4.0L | GenRight Stretch, 4 Link | Built XJ HP30 & XJ 44 | AW4 | ARB's | 35" Krawlers | Allied Beadlocks | York OBA | Warn 9500i etc. | M416 Trailer
Scott_98TJ is offline
post #3 of 17 Old 06-07-2006, 08:09 PM Thread Starter
dougthecat
I removed the nut, but can not remove the clutch, From what I know there is the shim and c clip behind that then the pulley can be removed.
The bearing is a servicable item as I already have purchased that. Just need to get the damn clutch off, i have anything i need at work as far as getting the bearing out goes.
Thanks for the response.
Any one else???
post #4 of 17 Old 06-07-2006, 09:02 PM
T.H's TJ
T.H's TJ's Avatar
They make a special puller for ac clutches. That is what i have always used on tractor trailors.
T.H's TJ is offline
post #5 of 17 Old 06-08-2006, 09:03 AM
onebigtj
I realize that, Just am not sure what which one i need. Seems they do not have the correct one at the autoparts store.
00' Silver TJ
D44,Jeeperman Front Bumper,Kc Dayliters,AtoZ Rock Sliders....Much More to Come
onebigtj is offline
post #6 of 17 Old 06-08-2006, 10:29 AM
Mudder6699
I got the same problem right now, I just need to replace my bearings. But where did you find these? I cant get them from anywhere around here...
Thanks
-Joe
02 Wrangler sport 5 speed d44....full traction 3 inch lift, 33x12.50 super swampers tsl's (summer) 32x11.50 bfg a/t's (winter)...cragar soft 8's
66 Buick LeSabre 2 dr hardtop
99 GMC Sierra RCLB 4x4-Gone
Mudder6699 is offline
post #7 of 17 Old 06-08-2006, 10:38 AM
onebigtj
I got mine through autozone. It was a special order part which took about 3 days to come in and was ~$40.
I am just unsure how to remove the clutch on the compressor so i can get to the damn bearing.
Anyone know what type of compressor it is??
Thanks
00' Silver TJ
onebigtj is offline
post #8 of 17 Old 06-08-2006, 12:01 PM
Mudder6699
Thanks I'll check them out
-Joe
post #9 of 17 Old 06-08-2006, 05:49 PM
T.H's TJ
T.H's TJ's Avatar
Thanks
Should say on the compressor.
T.H's TJ is offline
post #10 of 17 Old 06-08-2006, 08:09 PM Thread Starter
dougthecat
It probably is but i did not want to take it off. looks like i may have to though.
anyone else???
post #11 of 17 Old 06-09-2006, 10:40 AM
onebigtj
no one has ever taken this off??
00' Silver TJ
onebigtj is offline
post #12 of 17 Old 06-09-2006, 11:29 AM
usmc1951
ac clutch
What is the year of the jeep and does it have factory air or aftermarket and i will tell you how to take off the clutch Allie
usmc1951 is offline
post #13 of 17 Old 06-09-2006, 11:36 AM
skinton
In the 98 TJ Factory Service Manual, under the heating and air conditioning section, compressor clutch section:
Step 6) Insert the two pins of the spanner wrench (special tool C-4489) into the holes of the clutch plate. Hold the clutch plate stationary and remove the hex nut.
Step 7) Remove the clutch plate with a puller (special tool C-6461).
Step 8) Remove the compressor shaft key and the shims.
Step 9) Remove the external frnt housing snap ring with snap ring pliers.
Step 10) Install the lip of the rotor puller (special tool C-6141-1) into the snap ring groove exposed in the previous step, and install the shaft protector (special tool C6141-2).
Step 11) Install the puller through-bolts (special tool C-6461) throught the puller flange and into the jaws of the rotor puller and tighten. Turn the puller center puller bolt clockwise until the rotor pulley is free.
As you can see from the partial set of directions, there are a couple of special tools you will need.
Good luck!
1998 TJ Sport, 4.0L - 5 spd -Suffering from frame rot
2006 Grand Cherokee Overland (5.7L HEMI)
HEMI Club Member #53
2003 M-B C240 4matic
skinton is offline
post #14 of 17 Old 06-11-2006, 06:30 PM Thread Starter
dougthecat
the jeep is a 2000 wrangler sport with 4.0l. It has factory air as far as i know.
post #15 of 17 Old 06-11-2006, 06:31 PM Thread Starter
dougthecat
thanks for posting the fsm directions. It looks like i may have to bring it over to jeep if i cant find these tools.
stubborn fan clutch removal Weeeee TJ Wrangler Technical Forum 37 07-12-2015 11:33 PM
2.5l fan clutch removal InEmberClad YJ Wrangler Technical Forum 2 10-16-2009 09:44 PM
Fan Clutch Removal Roshambo88 TJ Wrangler Technical Forum 7 07-28-2008 06:10 AM
A/C Clutch removal problem Flyingfreak TJ Wrangler Technical Forum 8 04-18-2007 08:28 PM
