C-clips???? - JeepForum.com
post #1 of 4 Old 03-15-2004, 11:16 PM Thread Starter
Jash927
C-clips????
I have an 04 wrangler Columbia edition, with the 3.07 35 rear, and I am looking at lockers and new gears, how do I know if my rear has a c-clip or not?
Jash927 is offline
post #2 of 4 Old 03-15-2004, 11:19 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
All Wrangler Dana 35c rear axles have had c-clip axle shafts since around 1989. Only those with the optional extra-cost stronger Dana 44 axle are not c-clip. It's generally not advisable to install a locker into a Dana 35c because of the added stress a locker adds that will eventually/usually result in a broken axle shaft.
Jerry Bransford is online now
post #3 of 4 Old 03-16-2004, 06:06 AM Thread Starter
Jash927
so even with just 31" tires a locker will cause my axle to break? Is the front 30 ok with a locker?
Jash927 is offline
post #4 of 4 Old 03-16-2004, 09:22 AM
mking7
mking7's Avatar
The 30 is fine to lock. If you are going to the expense of locking and re-gearing, consider buying the Super 35 kit from Superior. It comes with a locker (Detroit or ARB) and 30 spline shafts so you will be good to go up to 35" tires....
The Detroit Locker Super 35 can be had for $850ish last time I saw one priced....
2003 TJ and a bunch of crap bolted on........
mking7 is offline
What's the deal with c clips? lowblue91 YJ Wrangler Technical Forum 10 12-07-2008 09:26 PM
C-clips GreatWhiteYJ YJ Wrangler Technical Forum 3 01-25-2008 12:28 PM
cant get c-clips off rebuiltyj TJ Wrangler Technical Forum 2 11-30-2007 02:09 PM
door clips tsharrett YJ Wrangler Technical Forum 1 03-04-2007 08:41 AM
No Retainer Clips Silver TeeJay TJ Wrangler Technical Forum 7 02-09-2006 06:33 PM
