A/C blows warm air above 45mph - JeepForum.com
post #1 of 21 Old 07-22-2011, 09:44 AM Thread Starter
05WK98TJ
My 98 TJ blows outside temperature air inside the cabin even when A/C is on at speeds above 45-50. Anything lower than that it blows ice cold air. Anyone know where I should look first for problems?
05WK98TJ is offline
post #2 of 21 Old 07-22-2011, 09:51 AM
Robert J. yates
I'd start with checking the compressor clutch.... sounds like it could be cutting out. It has a really close air gap tolerance.
Originally Posted by samgm2 View Post
And yes, I am an exceptional scientist and engineer.
Robert J. yates is offline
post #3 of 21 Old 07-22-2011, 09:57 AM Thread Starter
05WK98TJ
I have no experience with A/C systems so could you please give more detail on how to do this?
05WK98TJ is offline
post #4 of 21 Old 07-22-2011, 10:03 AM
JBTJ
Mine had a vacuum leak at a canister that was located under the battery tray. A rubber hose had a crack in it. You have to get on your back with a flashlight and look up under the tray to see it.
JBTJ is offline
post #5 of 21 Old 07-22-2011, 10:04 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
have you checked the system pressure? it might need recharged. it may be leaking somewhere too...condensor, hoses, seals, etc.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #6 of 21 Old 07-22-2011, 10:55 AM
TheBoogieman
Disturbed Jeepaholic
TheBoogieman's Avatar
Spend $25 and get a refill kit with a gauge.Typically 97-99' Tj's get vacuum leaks that stop the A/C from blowing out of the vents at any load of the engine(higher speeds).If it doesn't switch to defrost vent only,recharge it.
TheBoogieman is offline
post #7 of 21 Old 07-23-2011, 04:57 PM Thread Starter
05WK98TJ
Ok now I have a new problem the A/C compressor makes a ticking/whirling noise sounds like a bearing. It makes this noise whether the A/C is on or off. Am I looking at a new compressor or is there a cheaper way to rebuild it?
05WK98TJ is offline
post #8 of 21 Old 07-23-2011, 06:49 PM Thread Starter
05WK98TJ
Anyone? The AC system might just need a recharge cause it's dry so that's what making the noise? Does that sound right?
05WK98TJ is offline
post #9 of 21 Old 07-25-2011, 09:48 PM Thread Starter
05WK98TJ
Bump. I also noted that there is little noise from compressor when AC is on but when I turn it off it makes a loud rattling noise. And noise increases when engine is under load.
05WK98TJ is offline
post #10 of 21 Old 07-26-2011, 12:52 PM
oldmots
Sounds like the clutch bearings are bad, fairly cheap to get fixed, just take it to a good shop. They'll put in a new clutch.
oldmots is offline
post #11 of 21 Old 07-26-2011, 02:40 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
You are correct, you now have two problems, one is you have to fix your clutch or risk severely overheating your rig when the serpentine belt gets tossed off when the clutch locks up and the second is your vacuum leak causing the blend door to default to the heat side.
I am Savvy
blackmagicbrakes.com
mrblaine is online now
post #12 of 21 Old 07-26-2011, 02:43 PM
seadoons
How does one go about checking for a vacuum leak? Is there a way to use a machine to pull a vacuum and to see if it holds?
seadoons is offline
post #13 of 21 Old 07-27-2011, 01:32 PM Thread Starter
05WK98TJ
I found something else out when the clutch or pulley(whatever it is) is not spinning I hear the grinding noise but when it is spinning there is a whining noise probably from the belt.
05WK98TJ is offline
post #14 of 21 Old 07-27-2011, 06:46 PM
YJ_TJ_JK
Have an experienced Tech check out that clutch. But, I think that it's a vacuum leak. When you get above 45, it's starving for air. How's your idle with the a/c on? Jeeps have cracky vac hoses all over. Start with a bright light and closely examine for cracks in any thin vac. hose. Look everywhere under the hood and underneath. Don't forget to check the hoses that lead down to the front diff. too.
YJ_TJ_JK is offline
post #15 of 21 Old 07-27-2011, 06:54 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
There are no vacuum hoses going to the front axle on a TJ...
Knuckelhead is offline
a/c , highway speeds , warm
wabel at 45mph 81victor YJ Wrangler Technical Forum 25 06-06-2011 09:07 AM
odd vibration at 45mph nqlblq TJ Wrangler Technical Forum 19 07-01-2010 02:32 PM
A/C blows warm medic1230 TJ Wrangler Technical Forum 7 08-14-2009 09:59 AM
Tire came off at 45mph. jimG16 Wrangler General Discussion 36 03-21-2009 03:46 PM
98 shakes above 45mph becker21603 TJ Wrangler Technical Forum 9 12-02-2006 06:51 AM
