A/C blower issue - JeepForum.com
post #1 of 14 Old 07-21-2010, 07:22 PM Thread Starter
larubie
A/C blower issue
My 04 Rubicon a couple months ago would not blow air at the second fan selection, but did work on all the others. Than last week the third selection stopped working and all I have is high (the lowest is so low its hard to tell if anything is happening) which is fine in the south Louisiana summer, but i would like to fix it. I was talking to a dealer mechanic and he said that it could be a dozen issues. Really? What do you guys think?
larubie is offline
post #2 of 14 Old 07-21-2010, 09:04 PM
scottymc
ac issue
I was hardly getting any air out of any of the vents. it was all coming out of the top defrost vents. The vaccum hose had come of the motor, I popped the hose back on and everything was fine. If it is the vac hose you will here a whistling noise from the engine.
scottymc is offline
post #3 of 14 Old 07-21-2010, 09:06 PM
wushaw
Rockin jeep
wushaw's Avatar
It's your resistor pack, it is behind glove box.
wushaw is offline
post #4 of 14 Old 07-22-2010, 07:38 AM Thread Starter
larubie
I had the problem with the vacuum hose coming off after I stripped the inside of the Jeep to apply "Second Skin" (similar to "Dyna Mat"). I must of knocked it loose. But, now its the blower speed that is the problem. It seems like I am loosing all control except high speed. Funny thing is that this was happening one speed at a time... I will check into the resistor pack as a problem child. Is there a way to check it other than replacing the item?
larubie is offline
post #5 of 14 Old 07-22-2010, 07:41 AM
cajunfireman
x2
2000 Jeep Wrangler Sahara
Firefighter Jeep Club Member #337
"Greater love hath no man than this, that a man lay down his life for his friends." -John 15:13
Fight Crime....Shoot Back
I'll keep my money, my guns, and my freedom. You can stick the change up your ***.
cajunfireman is offline
post #6 of 14 Old 07-22-2010, 07:53 AM Thread Starter
larubie
K, I get the message... I will change it. Thanks guys.
larubie is offline
post #7 of 14 Old 07-22-2010, 07:27 PM Thread Starter
larubie
Picked up the part from the local Jeep dealer for $20. The top tech guy and parts man said this is the part that usually causes the symptoms I have. Will install this weekend and let yall know. Thanks again for the help.
larubie is offline
post #8 of 14 Old 07-24-2010, 01:22 PM Thread Starter
larubie
I changed the resistor pack and that was indeed the problem. Thank for the answer to my problem.
Wherever I may roam...
larubie is offline
post #9 of 14 Old 07-24-2010, 01:39 PM
Fireman0402
I just went through the same thing last week and I swapped out all the fuses having to do with the AC/Heat system as well as the blower motor resistor too. FYI and For later on down the line Wranglers are prone to have the blower motor switch over heat and Melt into position.
Fireman0402 is offline
post #10 of 14 Old 07-24-2010, 01:41 PM Thread Starter
larubie
Good to know thanks!
larubie is offline
post #11 of 14 Old 07-24-2010, 02:46 PM
domano 68
My LJ air flow seems weak compared to other vehicles I've owned. Anyway to increase air speed/flow?
2005 Wrangler Unlimited
domano 68 is offline
post #12 of 14 Old 07-24-2010, 03:44 PM
wushaw
Rockin jeep
wushaw's Avatar
Has it done it since new?
wushaw is offline
post #13 of 14 Old 07-24-2010, 09:15 PM
domano 68
I just picked this up in January of this year so I really can't answer that question. It just "seems" weak and I know that is a relative comparison. I'd like to improve the flow somehow.
post #14 of 14 Old 07-25-2010, 03:31 PM
wushaw
Rockin jeep
wushaw's Avatar
Pull the blower motor out and see if it has anything built up on the blades. Check your ducts for blockage.
wushaw is offline
ac , a/c , blower , issue , help , advice , suggestions , TJ
A/C blower issue jeeperjeffer TJ Wrangler Technical Forum 3 08-23-2010 02:42 PM
Another TJ AC blower issue rmv23887 TJ Wrangler Technical Forum 0 06-29-2010 08:01 PM
Blower resistor issue? txflood3 TJ Wrangler Technical Forum 5 08-27-2009 07:51 AM
Blower Vent Issue gov-t_mule TJ Wrangler Technical Forum 2 02-15-2008 11:47 AM
Blower Issue Optik45 TJ Wrangler Technical Forum 2 01-17-2007 11:31 AM
