a/c on big power loss - JeepForum.com
post #1 of 3 Old 07-30-2006, 04:02 PM Thread Starter
KKiowaTJ
all the sudden now when i turn the a/c on my jeep seems to lose 1/3 of its power.i had the charging system and the battery checked and they are both fine.the compressor kicks on fine and blows cold,just loses alot more power than it did before or should for that matter.figured sombody else might have ran into this problem,and might know what it is.thanks in advance for any advice.
MOPAR!
KKiowaTJ is offline
post #2 of 3 Old 07-30-2006, 06:19 PM
NEWtoTHEjeepLIF
Maybe something is just loose in the connectors. Did you check everything by hand?
NEWtoTHEjeepLIF is offline
post #3 of 3 Old 07-30-2006, 08:10 PM
01locker
maybe your compressor needs an oil charge? It doesnt sound like the compressor is siezed, because your air is still cold. If it was siezed it wouldn't be blowing cold air. Get a small can of oil charge for your a/c compressor and see what that does. It helps it compress more efficiently anyway.
01locker is offline
Still loss of power Iamjr TJ Wrangler Technical Forum 9 01-14-2010 07:32 PM
power loss dw9301998 YJ Wrangler Technical Forum 7 07-11-2009 10:03 PM
Someone Help Me, Loss Of Power cardinalsfan06 TJ Wrangler Technical Forum 19 03-03-2006 10:12 PM
Need some help here...power loss.... markburtenshaw YJ Wrangler Technical Forum 5 12-11-2003 12:45 PM
Power Loss Crawlin'Ken TJ Wrangler Technical Forum 2 05-21-2003 12:40 PM
