A/c - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > A/c
Metalcloak: Celebrate Freedom with Free ShippingFS: Wrangler RGB Multicolor Fog Light LEDs: Awesome EffectIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 06-14-2015, 07:02 PM   #1
DK8148
A/c
2006 lj. When I have my ac on one of the first two settings, the air is coming out not just from the front vents but a little from the bottom vents as well. Is that normal? No, I don't have it set on both, just front vents.
DK8148 is offline   Reply With Quote Quick reply to this message
Unread 06-14-2015, 09:44 PM   #2
Twistedtrax
Either the lower vent for the floor is not closed all the way, or you might have vacuum leaking, which is opening the lower vent while in the first 2 setting. Try pushing in on hte settings knob a little bit and see if it changes.
Twistedtrax is offline   Reply With Quote Quick reply to this message
Unread 06-14-2015, 11:12 PM   #3
CluelessLJ
I have the same issue. The air is coming out cold and at a pretty good speed so im leaving it for now. Sometimes I have to wiggle or push in on the fan speed knob to get the AC fans blowing. Id try what Twistedtrax said about messing with the knobs a bit then going under under everything and taking a look.
CluelessLJ is offline   Reply With Quote Quick reply to this message
Unread 06-15-2015, 01:58 PM   #4
JeepCACares
DK8148,
When did you notice the air-flow concern. Did it occur suddenly, or had it been intermittent?
Dave
Top Care Specialist
FCA Canada
JeepCACares is offline   Reply With Quote Quick reply to this message
Unread 06-16-2015, 03:37 PM   #5
DK8148
I bought it about 2 months ago and noticed right away. It's probably 80% front vent and the rest below. Does blow cold
