buying jeep on saturday (seatbelt issue, rust, and possible things to check) - JeepForum.com
post #1 of 25 Old 01-03-2008, 09:05 PM Thread Starter
ben8jam
ben8jam's Avatar
well, technically i've already bought - put a deposit down with the seller so i can come back on saturday and pick it up - this will be my second jeep - first was a 98 SE - which treated me really well untill someone rear ended it at 70mph when it was parked - i'm sure you've all seen the pic by now, but here it is again anyway
the new one is a 2000 Sport - with 31" tires - and only 45,000 miles - nice little upgrade - quite a difference in ride - big difference between the feel of the I4 and the I6 - the I6 feels rumbly - if that's even a word
here are some pics
have a couple questions...
1. the seat belts don't lock when you pull down on them... arn't they supposed to?
2. does this look like alot of rust to ya'll?
3. anything i should goto the mechanic with to check out? she has been the only owner and and most of the mechnical records - and not much has ever been done to it - wonder what might be due
thanks
and it's good to be back in the jeep world
ben8jam is offline
post #2 of 25 Old 01-03-2008, 09:07 PM
Jeepster55
"V6"???
someone do an engine swap?
Jeepster55 is offline
post #3 of 25 Old 01-03-2008, 09:22 PM Thread Starter
ben8jam
ben8jam's Avatar
heh... all fixed
ben8jam is offline
post #4 of 25 Old 01-03-2008, 09:23 PM
97casteeltj
97casteeltj's Avatar
Originally Posted by Jeepster55
"V6"???
what do you mean?? its a Sport they are standard with a 4.0L
needing a new rig....
97casteeltj is offline
post #5 of 25 Old 01-03-2008, 09:26 PM
Ronnie4283
Heh "V6". Anyhow, that appears to be surface rust, but a quick scrap with a screwdriver would tell you. The I6 is pretty notorious for front and rear main seal leaks. I'd suggest checking the conditions of all your fluids for dirt of metal fragaments (front and rear diffs, transmission, transfer case, brake fluid, etc).
Too bad stupidity isn't painful.
Ronnie4283 is offline
post #6 of 25 Old 01-03-2008, 09:46 PM
hecubus
1997 XJ Cherokee
the 4.0 is an "inline" 6, not a v-6
"eh, it's the bank's jeep anyway..."
hecubus is offline
post #7 of 25 Old 01-03-2008, 09:47 PM
hecubus
1997 XJ Cherokee
here are some pics
thanks
trying the click free thing & no, looks like normal surface rust
hecubus is offline
post #8 of 25 Old 01-03-2008, 11:22 PM Thread Starter
ben8jam
ben8jam's Avatar
yeh - you can see some black leakage on that pic. gonna have that checked out - i wouldn't know how to check the fluid for gunk. it would all looking gunky to me...
btw. what do you think about the seat belts? odd that none of them lock when yanking on them hard... though i seem to remember my old ones doing that...?
ben8jam is offline
post #9 of 25 Old 01-04-2008, 05:05 AM
truckin88
i like it, normal underside for a 7 year old truck (jeep)...If I was gonna buy it, first things I would do are..oil change, air filter, plugs, wires, differential fluids, t-case fluids, trans fluid...most of this is pretty cheap and preventative maintence.
2006 Wrangler X, 6 speed manual 4.0 I6, BFG T/A's 31x10.50x15 on Promcomp )97 Soft 8 Steelies, stock sunrider soft top, KC Replacement fogs, westin step bars (yeah I know).
RED JEEP CLUB MEMBER #442
truckin88 is offline
post #10 of 25 Old 01-04-2008, 05:28 AM
glenno
glenno's Avatar
yea
what he said
glenno is offline
post #11 of 25 Old 01-04-2008, 06:39 AM
ChadCielencki
ChadCielencki's Avatar
I would make them put front tow hooks and fog lights on it...and sell it as a sport...
2004 TJ
1978 CJ5
ChadCielencki is offline
post #12 of 25 Old 01-04-2008, 07:02 AM
truckin88
all those are optional, and if it is not from a dealer, then whats the point of passing on a clean jeep, tow hooks can be added for under $100, fog lights...the heck with mopar/hellas, get metal KC's
post #13 of 25 Old 01-04-2008, 08:32 AM
ASUsax
Rust doesn't look too bad, Jeep's probably not lived it's whole life in LA, though, it's been up north at some point, or in the high country, to get that much rust. But it's still looks like only surface rust, not a big deal.
If the seatbelts don't work properly, they're pretty Cheap and really easy to replace. I replaced my Passenger side recently, it wouldn't retract. I think it cost me $65 for the whole shebang.
Blue Jeep Club Member #197
'02 TJ - 33" BFG MT's's, some armor, yadda yadda. 2" BDS lift/1"BL
'94 ZJ - May it rest in pieces.
ASUsax is offline
post #14 of 25 Old 01-04-2008, 11:37 AM Thread Starter
ben8jam
ben8jam's Avatar
actually it's lived its whole life in LA - though right next to the ocean - so i'm assuming the salt air did that - she said it's been rained in a few times too - i checked under all the carpets and looks fine - no body rust (well, the hinge for the windshield is rusty and paint crumbley, odd that that's the only spot )
as for the seat belts, can someone confirm that they are supposed to lock when pulled on? or only lock when slamming on brakes?
btw. thanks to whoever updated my title - i actually tried to do that once i had posted it but couldn't...
ben8jam is offline
post #15 of 25 Old 01-04-2008, 12:05 PM
MusicMaverick
MusicMaverick's Avatar
2014 JK Wrangler
Looks like just surface rust. That's not too much concern, maybe when you want to unbolt something you might need to spray it down, but that's all. The rust you want to be concerned about is when its actually rotting. I live in LA too btw,
They should only lock when brakes are applied.
Currently: '14 JKU
Past vehicles: '92 YJ, '97 TJ, '10 JK
MusicMaverick is offline
Buying a TJ, What important things to look for ? chaznad TJ Wrangler Technical Forum 10 02-19-2009 07:45 AM
Why do these things rust so DARN much? mr.grumpy YJ Wrangler Technical Forum 25 12-14-2006 11:34 PM
Things to look at when buying a jeep? beaniebmx YJ Wrangler Technical Forum 10 11-09-2006 01:44 PM
Things to look for in buying d-rings? Bren Gun TJ Wrangler Technical Forum 23 06-21-2006 08:34 AM
sorta scarey seatbelt issue badoosh27 TJ Wrangler Technical Forum 3 07-26-2005 09:01 AM
