Burping the engine (new radiator ) - JeepForum.com
post #1 of 3 Old 09-25-2009, 08:24 AM Thread Starter
zband
zband's Avatar
OK just installed the new radiator and tested the jeep - it ran in the normal temp range but fluctuated. I've read that you have to "burp" the engine" to fix this but after searching the results usually came up as older 4.0 not the newer TJ's. So I have a 03 do I need to burp it or will the overflow bucket thing take care of it over time?
If I have to any suggestions on techniques? ?
zband is offline
post #2 of 3 Old 09-25-2009, 09:41 AM
Shadowline
the easy way to get a motor to "burp" is park it on a incline.... with the radiator being at the highest point possible. Let it set for a bit, most of the remaining air will bubble up to the radiator cap. I've also had luck parking it level and opening the temp sensor slightly at the t-stat houseing for those small little bubbles...
2003 TJ 4.0 5-speed 31inch Goodyear Authority's, 2inch Rubicon Express Springs, Hella Vision Plus H/L's, IPF upgraded H/L wiring harness. JCR Offroad Stage 2 Frt Bumper with CocaCola Bottle opener, Smittybuilt XCR8 Winch, Rampage Bowless top.
Shadowline is offline
post #3 of 3 Old 09-25-2009, 11:28 AM
2004sahara
just fill the rad and put some in the over flow tank....squeeze the upper rad hose a bit....put heater on hot..fan on high...start engine with rad cap off...let run for a bit while watching to level in the rad...when it starts to puke out the top it is full......always worked for me...good luck.
2004sahara is offline
Radiator/ engine overheating Shane64 TJ Wrangler Technical Forum 21 05-21-2008 06:13 AM
First uwharrie run=Blown radiator and engine mudlover1832 YJ Wrangler Technical Forum 6 04-07-2008 06:44 PM
Oil in Engine Radiator joburnet TJ Wrangler Technical Forum 18 04-13-2006 06:28 AM
Need help -- burping radiator issue pwoens YJ Wrangler Technical Forum 5 09-21-2005 12:06 PM
Service engine light on!! Is it from H20 in radiator & engine coolant compartment?? chaznad TJ Wrangler Technical Forum 12 04-24-2005 08:57 PM
