bumpstops, shock length, and tires size. help me iron out the fuzzy points.. - Page 22 - JeepForum.com
post #316 of 383 Old 05-15-2013, 10:50 AM
eduardostewart
any help would be appreciated -
When i bought my tj it came without a rear upper jouncer. I'm just going to order two replacements so they're the same and then be able to judge/measure what increment(s) bump stop extensions i need.
Now, the part where i need you guys. I'm pretty sure to have everything the way it should be i need to look into bump stop extensions. I did the usual googling and seems most people say to stay away from the d*ldo looking things and that what i should get are the hockey puck type discs.
with that being said, what are your thoughts on bottom extensions vs upper extension. I believe i remember seeing a thread where people were saying go with upper extensions but i came across a nifty kit from jks for bottom?
http://www.4wd.com/Jeep-Lift-Kits-Je...0&t_pn=JKS1100
eduardostewart is offline
post #317 of 383 Old 05-15-2013, 02:23 PM
joe_jeep
any suggestions for running 3.5 re spring (besides dont run them) for max "useable" travel.
i have not bought shocks or bump stops yet. i have a 1.25" body lift, and will be getting a mml.
i will be running 35" tires.
i have a used set of re 3.5 springs front and rear.
i have currie jj control arms front and rear.
i have a rear teraflex revolver track bar.
i was gonna use the stock front track bar, and re drill the axle mount hole.(i could buy a currie if it will help)
i have re extended braided brake hoses front and rear.
i want to get the teraflex rear upper shock mount that raises the mount location 1"
i would like to move the rear lower shock mounts on to the lower control arm mounts.
i was not planning on moving the front shock mounts.
it all on a 2005 rubicon unlimited sahara.
all suggestions are welcome.
i know re springs dont travel the best, its the rate i want, i tow.
glfwda #6624
2005 rubicon sahara lj #592
joe_jeep is offline
post #318 of 383 Old 05-15-2013, 02:54 PM
MisfitSeven
MAiL Crawler.
MisfitSeven's Avatar
Skip the upper shock mount relocation. Outboarding the rear shocks lets you run a longer shock and puts the shock in a position to dampen better.
Mail crawling.
MisfitSeven is offline
post #319 of 383 Old 05-15-2013, 09:19 PM
joe_jeep
i know about outboarding rear shocks, doubt i will go that route.
i can get enough travel with moving the lower mounts, and gaining an inch up top.
its not a desert racer, and will see only mild off road use.
i got a rock buggy to abuse. this is a toy for light use.
glfwda #6624
joe_jeep is offline
post #320 of 383 Old 06-21-2013, 11:50 AM
elclipo
Wonderful thread. I definitely have a good idea what I must do to get my bump stops dialed in (the PO had a 4" lift installed and no bump stop adjustment whatsoever). Now, based on other threads I have seen hockey pucks used as bump stops and seeing they are one inch think they would work great as I can add or subtract as needed. My question is regarding attachment. What is best to use (other than a bolt as I don't have a tap and die set). RTV? JB Weld? Elmers Glue? Thanks
elclipo is offline
post #321 of 383 Old 06-21-2013, 11:54 AM
biffgnar
biffgnar's Avatar
Drill, tap and bolt is best option. I've made epoxy work, although make sure it is strong and mix it well before applying.
biffgnar is online now
post #322 of 383 Old 08-13-2013, 03:37 PM
papa355
1977 CJ7
quick question. I have SOA, CJ7 , Dana30 front. I have 11 1/2" from center to center on front studs for the shocks. How short of a shock should I use to allow for wheel to come up? is a 9 1/2" shock too short, compressed ?
1977 CJ7, 360 AMC with HEI, TH400 quadratrac, dana30, AMC20, SOA, 35" M/T MTZ
papa355 is offline
post #323 of 383 Old 08-14-2013, 11:56 PM Thread Starter
mudb8
want it rite or rite now?
mudb8's Avatar
Originally Posted by papa355 View Post
quick question. I have SOA, CJ7 , Dana30 front. I have 11 1/2" from center to center on front studs for the shocks. How short of a short should I use to allow for wheel to come up? is a 9 1/2" shock too short, compressed ?
At least 4" uptravel imo....
How did you end up with 11 1/2" on a SOA?
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable
ASE Certified Master Tech/Fabricator @ jeepwest.com
mudb8 is offline
post #324 of 383 Old 08-15-2013, 12:01 AM Thread Starter
mudb8
mudb8's Avatar
More rear cj...
mudb8 is offline
post #325 of 383 Old 08-15-2013, 07:08 PM
papa355
1977 CJ7
got it figured out thanks
papa355 is offline
post #326 of 383 Old 09-23-2013, 09:04 PM
RaggedOleMan
Came upon this thread a few years ago. Wasn't knowledgeable enough to grasp it at the time. While my truth is I'm still not all that savvy to all that's been discussed in here, though I can now appreciate it a lot more. Loved how you handled the moron in the first 5-pages or so, too...
Outstanding thread. Friggin' outstanding.
RaggedOleMan is offline
post #327 of 383 Old 11-09-2013, 04:54 PM
edinct
great thread, very informative.
edinct is offline
post #328 of 383 Old 01-26-2014, 12:08 AM
ravenworks
Great thread, thanks for taking the time to post you knowledge.
Semper-Fi "81-84"
I.U.O.E. - 18
ravenworks is offline
post #329 of 383 Old 03-23-2014, 12:44 PM
jpatt10
I am going to resurrect this beast of a thread to get some input. I've read through this at least twice over the last few months and every time I finish, I end up with a throbbing headache. Sorry I don't have a lot of posts, as I generally just search and read and figure it out as needed, but this one blows my mind.
Here goes, '05 TJ X, 2.5" RC lift about 2 years old, 32s on Moabs, no body lift or MML on at this time. She is mostly my DD, some light trails and the snow that has decided to be a SOB this winter.
If I go with the Bilstein shocks for a 3" lift, as shown on Q-tec
Front 24.00/14.88
Rear 22.44/13.98
That would require 1" BSE for the front and 2" for the rear?
Any help would be appreciated.
jpatt10 is offline
post #330 of 383 Old 03-23-2014, 10:59 PM Thread Starter
mudb8
mudb8's Avatar
1.25 front and can be closer to 3" with a 14" collapsed rear length depending on pinion angle.
Pull the springs, install the new shocks then set it down bottoming out the shock, measure the distance from the axle pad to the metal bumpstop cup.
I have never nailed the rear due to variables. I do have a tj in the shop now with 14" collapsed rears in stock mounts, stock upper ca's and 16" re lowers i could measure. I can tell you tho it has 4" extensions currently bolted on it, 2" rear uppers along with 2" lowers that would normally belong on the front, which i had nothing to do with, the dirt line on the shaft comes within a half inch of bottoming out. it came in that way. It has 3.5" re springs, 03 rubi skid pan w/1" t-case drop.
Im pretty sure there are measurements in a photo with ome n66l shocks that are 14" collapsed. Lift height does not matter or even factor into the bumpstop requirements of a collapsed shock length. Use of shock shifters and pinion angle changes do factor into the rear bumpstop requirements.
mudb8 is offline
bump stop , bump stops , bumpstop , bumpstops , shock length
What size bumpstops do i need with bb and 33s trick pony TJ Wrangler Technical Forum 8 05-09-2009 09:29 PM
shock length???? bradp37 YJ Wrangler Technical Forum 0 01-16-2009 03:10 PM
Need longer bumpstops, and shock travel? Scotch740 TJ Wrangler Technical Forum 7 09-11-2008 01:55 PM
RE Shock Length jeep 62 TJ Wrangler Technical Forum 0 02-03-2008 03:42 PM
Shock Length jeepteejay TJ Wrangler Technical Forum 3 10-26-2006 09:12 AM
