bumpstops, shock length, and tires size. help me iron out the fuzzy points.. - Page 19 - JeepForum.com
post #271 of 383 Old 11-11-2012, 07:39 AM
BadApple1403
Y do u have to remove the springs to check the amount of bumpstop need y can't u just leave it in and flex it
BadApple1403 is offline
post #272 of 383 Old 11-11-2012, 07:47 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
read this:
http://www.jeepforum.com/forum/f9/tj...l#post11060614
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #273 of 383 Old 11-11-2012, 07:52 AM
BadApple1403
I've read thru that so what did I miss
post #274 of 383 Old 11-11-2012, 07:54 AM
Unlimited04
apparently you missed the whole point of the thread, and post #861 that I just linked.
Useful Write-Ups:
Funny:
post #275 of 383 Old 11-11-2012, 07:55 AM
BadApple1403
I get the clearance of the trackbar and diff cover but I don't get y that has anything to do with removing the springs to check bumpstop
post #276 of 383 Old 11-11-2012, 07:58 AM
Unlimited04
if not bumpstops, what do you think stops the track bar from hitting the diff, or stops the track bar from hitting the tie-rod? what stops the shocks from bottoming out? what prevents other suspension interferences? what stops the springs from over-compressing at full bind? what stops the tires from hitting steel?
Useful Write-Ups:
Funny:
post #277 of 383 Old 11-11-2012, 08:04 AM
BadApple1403
I realize the bump stops keep that from happening but couldn't u also leave in the springs and use a lift or ramp to cycle the suspension..like on mine I used a ramp and everything clears other than the shock is what is goin to stop my rear up travel so I know I gotta extend them..I know that sound dumb bit its all I have right now living on the road with work don't have acces to a garage right now
post #278 of 383 Old 11-11-2012, 08:09 AM
Unlimited04
you use a ramp/bump/pothole to cycle the suspension everyday you ride on the road.
problem is, you need a way to simulate that in your garage. You have to make the frame and axle come together somehow...slowly, in a controlled manner.
And since the springs hold the frame off the axle, the easiest thing to do is remove the springs. Support the frame, drop the springs out, then use a floor jack (or a lift of some sort) to push the axle up to full bump and full flex. You also check tire clearances, full droop, brake line length, etc at the same time.
If you're looking at flex on an RTI ramp, hill or something, you're not even getting half the story.
Useful Write-Ups:
Funny:
post #279 of 383 Old 11-11-2012, 08:20 AM
BadApple1403
Well for me everything clears the only thing hitting is the rear shocks bottoming out which is y I was saying couldn't I just leave in the springs and measure what I need..I see ur point of cycling everything slowly..my jeep was just an exception to the rule with everything already done except for the rear
post #280 of 383 Old 11-11-2012, 08:21 AM
Unlimited04
your jeep isn't an exception to the rule, you just don't comprehend what this thread, and others, are trying to teach you.
Useful Write-Ups:
Funny:
post #281 of 383 Old 11-11-2012, 08:32 AM
rchase559
Cycling without the springs allow you to check clearances when both sides of the axle are at full bump. You can't do that in on a ramp.
I bet that a lot of the people who have issues with the track bar and diff clearance could go on a ramp and have everything clear just fine.
rchase559 is offline
post #282 of 383 Old 11-11-2012, 08:33 AM
J03_TJ
Originally Posted by JohnlTJ View Post
Thanks Herklord, not the answer I was hoping for but so be it. Will fit it all up and see how it goes. Nice Jeep by the way!!
Plenty of guys run 3" springs with 1" drop without vibes. I did it for 3-4 years and had no vibes.
J03_TJ is offline
post #283 of 383 Old 11-11-2012, 08:34 AM
Unlimited04
yup, the thread I linked for him above, the exact post in fact, describes just that and shows pictures of it.
you can lead a horse to water, but you can't make em drink.
Useful Write-Ups:
Funny:
post #284 of 383 Old 11-11-2012, 08:46 AM
BadApple1403
I reopened ur link and I see what ur talking about the first time my phone app took me to the first page which I've read thru that thread but not every single page..so my apologies for questioning ur knowledge lol ill pull the springs
post #285 of 383 Old 12-18-2012, 07:04 AM
andrewf09
I've been reading through the threads and I'm still a little confused.
My setup
33's, AEV 3" Springs, Rancho rs9000xl, 1.25BL, 1"MML
Rancho rs9000xl shocks
F Compressed: 16.110 Extended: 25.970
R Compressed: 15.290 Extended: 24.150
F 16.110 - 13.50 = 2.61 - 1.25 BL = 1.36 BS?
R 15.290 - 12.50 = 2.79 - 1.25 BL = 1.54 BS?
andrewf09 is offline
bump stop , bump stops , bumpstop , bumpstops , shock length
What size bumpstops do i need with bb and 33s trick pony TJ Wrangler Technical Forum 8 05-09-2009 09:29 PM
shock length???? bradp37 YJ Wrangler Technical Forum 0 01-16-2009 03:10 PM
Need longer bumpstops, and shock travel? Scotch740 TJ Wrangler Technical Forum 7 09-11-2008 01:55 PM
RE Shock Length jeep 62 TJ Wrangler Technical Forum 0 02-03-2008 03:42 PM
Shock Length jeepteejay TJ Wrangler Technical Forum 3 10-26-2006 09:12 AM
