bumpstops, shock length, and tires size. help me iron out the fuzzy points.. - Page 16 - JeepForum.com
post #226 of 383 Old 10-27-2011, 05:51 PM
Necromancer_tat
Where'd all my money go?
Originally Posted by SpeedJeep View Post
The Currie bumpstops will fix all of that...the correct way.
You have a good start so far. I would change a few things as you have the time/money.
1) Bumpstops before you break something important
2) Ditch the body lift for a smaller 1" lift
3) Ditch the factory control arms for something like Currie, Savvy, or Rokmen.
I already have Currie front upper and lower control arms, plus the axle housing kit, I just haven't installed them yet. I think I'm going to order the front and rear Currie bump stop kits, I just wanted to make sure they would work with the parts that are still on my Jeep and that I wasn't missing anything important that I would need to make them work.
Necromancer_tat is offline
post #227 of 383 Old 10-27-2011, 06:40 PM
EricsGreen98Tj
They will work GREAT!
Building my junk with more junk, so Im always on the look out for more junk....Free to cheap preferably. :D
My junk http://www.jeepforum.com/forum/f22/survivor-project-driveway-frame-swap-33s-build-1280626/index3.html
EricsGreen98Tj is offline
post #228 of 383 Old 10-27-2011, 06:45 PM
ytowntj
The currie kits are great, but a bit of tube and some new $6 oem jounce bumpers works very well too. A piece of plate tapped into the lower mounts retain the coils well. Its a bit of work but can save you some coin
ytowntj is offline
post #229 of 383 Old 10-27-2011, 07:12 PM
Necromancer_tat
For less than $200 for all 4 corners, the Currie set up doesn't seem to pricey to me. I'm pretty sure the time it would take to fabricate something similar would cost me as much as just going with the Currie set up. If you're itching to do some fabricating though, I'm thinking outboarded rear shock towers, and triangulated rear control arms and axle truss, relocated upper coil spring mounts, and a mild rear stretch.
post #230 of 383 Old 11-29-2011, 07:34 AM
turtle05LJ
great info thanks!!
turtle05LJ is offline
post #231 of 383 Old 12-19-2011, 12:26 PM
Yellow02
I hope i can bring this back to life so i dont have to make another thread about bump stops. So i am getting my 5.5'' RK la lift installed after the new year and was curious what bump stops i would need. the 1st page says i need 3.5'' but i also have metalcloak overline fenders. can someone please help me
Yellow02 is offline
post #232 of 383 Old 12-19-2011, 12:28 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
as stated in the first page, the bumpstop requires depend on your SHOCK LENGTH first. What will be the compressed length of the shocks you'll be using front and rear?
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #233 of 383 Old 12-19-2011, 01:06 PM
Yellow02
I can't remember the exact length but I believe its 20" front 18" rear
USN Jeep Club Hull #144
#83 Rubicon Sahara Edition
Yellow02 is offline
post #234 of 383 Old 12-19-2011, 04:29 PM
Unlimited04
those can't be right...thats a whole lot more bumpstop requirement than lift...
Useful Write-Ups:
Funny:
post #235 of 383 Old 12-19-2011, 05:00 PM
Yellow02
Ok I will double check with the shop I am gettin them from tomorrow because they are closed today
Yellow02 is offline
post #236 of 383 Old 12-20-2011, 02:39 PM
Yellow02
So i got the shock lengths the front is 29.5'' extended 17.5'' collapsed and the rear is 26.75'' extended and 16.5'' collapsed
Yellow02 is offline
post #237 of 383 Old 12-20-2011, 05:03 PM
Unlimited04
now go look at the first page and see if you can figure out a starting point for bumpstop extensions...
Front: ~13" stock starting point
Rear: ~12" stock starting point
Add 1" in bumpstop for every 1" in compressed shock length...
17.5-13 = 4.5"
16.5-12 = 4.5"
That's only a starting point to get you into the ballpark. The rear will change drastically due to pinion angle and the misalignment of the spring perches at that tall of a lift height. You will still need to push the axle to full bump with the springs removed, as mudb8's described, to determine your actual required bumpstop extensions. Upper spring perch relocation would be recommended to aid in this.
Useful Write-Ups:
Funny:
post #238 of 383 Old 12-20-2011, 05:43 PM
Yellow02
ok awesome i understand how you got that thank you, now the bumpstop size will decrease since i have metalcloaks right?
Yellow02 is offline
post #239 of 383 Old 12-20-2011, 05:47 PM
dreed
Only if you get shorter shocks.
dreed is offline
post #240 of 383 Old 12-20-2011, 05:48 PM
Unlimited04
do metalcloak fenders have anything to do with the mounting locations of your shocks on the frame?
^this.
Useful Write-Ups:
Funny:
bump stop , bump stops , bumpstop , bumpstops , shock length
What size bumpstops do i need with bb and 33s trick pony TJ Wrangler Technical Forum 8 05-09-2009 09:29 PM
shock length???? bradp37 YJ Wrangler Technical Forum 0 01-16-2009 03:10 PM
Need longer bumpstops, and shock travel? Scotch740 TJ Wrangler Technical Forum 7 09-11-2008 01:55 PM
RE Shock Length jeep 62 TJ Wrangler Technical Forum 0 02-03-2008 03:42 PM
Shock Length jeepteejay TJ Wrangler Technical Forum 3 10-26-2006 09:12 AM
