bumpstops, shock length, and tires size. help me iron out the fuzzy points.. - Page 12 - JeepForum.com
post #166 of 383 Old 03-29-2011, 12:10 PM
jamesmanis
Looking for a good brand for the front. I found these bump stop spacers. I assume we are talking about something like this for the front
http://www.quadratec.com/products/16090_1119.htm
Never work harder than you play
1999 TJ, 3.25" lift on 33"x12/50" Goodyear MTR
2002 Harley VRod 114hp at the wheel
jamesmanis is offline
post #167 of 383 Old 03-29-2011, 09:11 PM
05xwrangler
Originally Posted by EricsGreen98Tj View Post
Probably get 4" springs and correct length shocks will help alot. But at 4" you kinda at the max of the stock control arms(Length wise) Plus you'll probably have to do either a t-case drop or an SYE/CV shaft to clear up any vibrations. If I were you I'd runa 1.25" bodylift and a set of 2.5" or 3" lift springs. Keeps everything so much simpler and closer to stock geometry. But I'm not a pro. Look to the Zone Offroad 4.25" combo kit(I ran it in the past and loved it) its a 1.25" BL and 3" suspension lift + a Motor mount lift all in one package. It rides dang well too.
I think i might get that kit. Did you run into any problems with it or have to order extra parts? Thanks
05xwrangler is offline
post #168 of 383 Old 03-30-2011, 02:27 PM
EricsGreen98Tj
Nope. I didnt order anything extra and it rode EXCELLENT, which was a huge + for me as my Tj is my DD. I went the the Nitros cause the streets around here are really rough and i wheel 3-4 weekends a month. If your going to mainly DD your ride go with the Hydros. It is an excellent kit for a great price man......You'll love it.
Building my junk with more junk, so Im always on the look out for more junk....Free to cheap preferably. :D
My junk http://www.jeepforum.com/forum/f22/survivor-project-driveway-frame-swap-33s-build-1280626/index3.html
EricsGreen98Tj is offline
post #169 of 383 Old 03-30-2011, 02:29 PM
EricsGreen98Tj
Also The Boogieman put a set 3/4" front spacers on when he did his combo lift and he runs 35's. But since i have the 4cyl i went with 33x10.50's.
post #170 of 383 Old 03-30-2011, 08:17 PM
unlimited06
Is it my imagination or did Q-tech forget to list how long these bump stops are ? Do they think people are gonna' blindly buy sets of these like playing the lottery ?
unlimited06 is offline
post #171 of 383 Old 03-31-2011, 06:32 AM
jamesmanis
I asked them on the online support and the guy didn't even know the length
My question was really asking is this the type of product not that brand for the front.
post #172 of 383 Old 04-03-2011, 07:41 PM Thread Starter
mudb8
want it rite or rite now?
mudb8's Avatar
the fk16 bumpstop spacer is the rear upper, close to 7/8" tall, which is insufficient length for the 2" track bar extension, coil bind, and n67 shocks.
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable
ASE Certified Master Tech/Fabricator @ jeepwest.com
mudb8 is offline
post #173 of 383 Old 05-19-2011, 11:54 AM
rogerschrisj
Hey Mud8, this is a great thread. Especially for newbies like me. I would like to run 33x12.5x15 tires on my 97tj Sahara. Right now it is bone stock. I was looking at the rough country 2.5" suspension lift to accomplish this. After reading your thread I am worried about two things. I don't want to unseat my coil springs. I also don't want to change anything else on my jeep other than the springs, shocks and bump stops (to keep the wheels out of the fender). I don't mind loosing the uptravel, I do want to get as much down travel as possible though. Do you think if I ran the RC 2.5" suspension lift with the correct length bump stops and limit straps to prevent the coil from unseating I could accomplish what I want and still keep everything else stock on my jeep? Or would you suggest another route? Thanks in advance.
Chris
rogerschrisj is offline
post #174 of 383 Old 05-19-2011, 01:55 PM Thread Starter
mudb8
mudb8's Avatar
Chris
"correct length" RC shocks won't unseat the coils....... RC front shocks require 1.25" bumpstops however without a 1" BL you need at least 2" bumpstop extensions.
mudb8 is offline
post #175 of 383 Old 05-19-2011, 02:12 PM
rogerschrisj
Thanks for the quick reply. When you say "correct length" shocks (I'm assuming from your chart that would be a 25.5"shock), do you mean the ones that come with the kit or a different shock? I was planning on just running the shocks that are included with the kit. So, if I run the "correct length" shocks will that eliminated the use of limit straps? I won't be doing a body lift. Maybe some fender mods in the future when I regear and move up to a bigger tire. I also do not plan on relocating my shock mounts. What do you think?
post #176 of 383 Old 06-10-2011, 05:54 PM
jr03
When talking about down travel/droop and springs unseating, how much droop should be allowed for? That is my front RE springs are 19" uncompressed, 15.5" at ride height, should they be setup for down travel so that they just barely become loose, fully uncompressed, or up to .5" or some other amount of looseness?
jr03 is offline
post #177 of 383 Old 07-25-2011, 08:50 PM
negreac
Hey mudb8 I was hoping you could help me on the system I am currently piecing together. I've read through multiple pages and I think i know what I need and also think I may have already bought some stuff which may hinder me
So here was the plan:
http://www.amazon.com/Rancho-RS6505-Suspension-System/dp/B000CPCCUY/ref=wl_it_dp_o?ie=UTF8&coliid=I13TJND1TY3VGV&colid=22EFYPAUE0AZG(Looks like this is actually the same kit you have)
http://www.amazon.com/Rancho-RS19255-RS9000XL-Pro-Shock/dp/B000CP8G3G/ref=wl_it_dp_o?ie=UTF8&coliid=I28382HWC0BFSM&colid=22EFYPAUE0AZG
http://www.amazon.com/Rancho-RS19256-RS9000XL-Pro-Shock/dp/B000VTVZU4/ref=wl_it_dp_o?ie=UTF8&coliid=I3GN1E9X0ORCQ9&colid=22EFYPAUE0AZG
Rancho RS6416 & RS6417 a.k.a. thier Rubicon/3" springs (Should help make up for all the armor I am adding)
Pretty much the same shock/spring/lift combo as the guy on this thread:
http://www.jeepforum.com/forum/f9/ra...-lift-1193164/
JKS Bar Pin Eliminators Front & Rear
Currie Rear Shock Mount Relocation
S.Y.E. and CV Driveshaft
Tummy Tuck by Extreme Metal Performance
1" Raised Gas Tank Skid by Extreme Metal Performance
M.O.R.E. 1" Body Lift and Motor Mount Lift
WJ Front Knuckles/Brakes/Tie Rod/Drag Link
BFG Mud Terrain KM2 33" x12.5" x 15"
I think about covers everything that would affect my suspension.
So based purely on shock travel alone (13.1" front and 12.5" rear stock) I would need an additional 2.775" up front and 2.625 in the rear. Now with the JKS bar pin eliminators I believe they add about an additional .5"meaning I would end up around 3.275" in the front and 3.125" in the rear. I'm not sure how the relocators will affect the rear. I also don't know if I will need adjustable upper arms for the rear. Any help is appreciated here. Also I know this all seems a bit long for my lift but I eventually will probably go with a 3.5 to 4" lift (probably just some different springs) and upgrade to 35" tires when I get enough cash to upgrade my axles. Also I;m not too sure about the rear track bar relocation bracket this kit comes with. It seems too much like a band aid.
1999 Jeep Wrangler Sport 4.0L Auto (Under Construction)
negreac is offline
post #178 of 383 Old 07-25-2011, 09:09 PM
negreac
Also if my calculations are correct I appear to have 2 options for bump stops. My cups are gone BTW.
Option #1 is to get both the front and rear Currie kits (Not sure if these are large enough)
Currie Front Bump Stop Kit (CE-9122F)
Currie Rear Bump Stop Kit (CE-9122R)
Option # 2 is to get 4 of the lower Currie spacers (2") and Daystar uppers (2.5" long - not sure how much longer this is than the stock cup)
Currie Lower Spacers (CE-9122F4)
Daystar Upper Bump Stops (KU09037BK)
There's also the option of using the 2 or 3 inch lower spacer from RE I suppose.
negreac is offline
post #179 of 383 Old 07-25-2011, 09:44 PM Thread Starter
mudb8
mudb8's Avatar
Rancho RS6505 Short Arm Kit (Looks like this is actually the same kit you have)
Rancho Pro Series Front Shocks (RS19255- 15.875"-25.875" - 10" of Travel)
Rancho Pro Series Rear Shocks (RS19256 - 15.125"-24" - 8.875" of Travel)
15.8 front collapsed length shocks need 2.25" min. 2.5"max bumpstop extension.
the 15" collapsed rears are gonna need closer to 4" extension unless you relocate the rear mounts out and down... if you are refering to currie ce9601 shock relocation brackets the bumpstop extension will be even more I would NOT use them...
Now, if you think the rear track bar relocation is a bandaid, think again.. the relocation bracket raises the roll center and prevents the track bar from binding on the axle bracket. I would brace the axle bracket especially if it's gonna see some hard wheeling, a pavement pounder will never experience a problem.
the rancho/rubi springs will yeild you closer to 3" lift and won't need adjustable ca's if you use a t-case drop. mine was fine with the rubi t-case without the case drop, it did however have a minor vibration. I put a 1350 high angle CV and Nth Degree TT to fix that, I refuse to loose ground clearance.
put the Polly bumpstops out of your head, they are too stiff and too long, use factory rubber bumps with a the proper height axle mounted extension like the currie, the rear extensions are ok to mount between the bumpstop bell and tower.
WHY aren't you using a SAVVY fuel tank/belly skid?
mudb8 is offline
post #180 of 383 Old 07-25-2011, 10:44 PM
negreac
I can't believe the shocks Rancho recommends for these kits are this long. A 4" bumpstop seems pretty crazy. I don't imagine in the bumpstop spacers they send in the kit are anywhere near this long. I was really trying to avoid having to do any welding for the time being. Any other options I have and still use this length of shock? Perhaps the teraflex upper mounts instead of the bar pins. Won't I hit the spring perch with my shocks without the extension or relocating the entire mount? Is there any way I can avoid this without cutting off and welding new mounts?
Honestly I had never heard of the savvy skid till now. EMP at the time seemed relatively nice and affordable.
negreac is offline
bump stop , bump stops , bumpstop , bumpstops , shock length
What size bumpstops do i need with bb and 33s trick pony TJ Wrangler Technical Forum 8 05-09-2009 09:29 PM
shock length???? bradp37 YJ Wrangler Technical Forum 0 01-16-2009 03:10 PM
Need longer bumpstops, and shock travel? Scotch740 TJ Wrangler Technical Forum 7 09-11-2008 01:55 PM
RE Shock Length jeep 62 TJ Wrangler Technical Forum 0 02-03-2008 03:42 PM
Shock Length jeepteejay TJ Wrangler Technical Forum 3 10-26-2006 09:12 AM
