bumpstops, shock length, and tires size. help me iron out the fuzzy points.. - Page 10 - JeepForum.com
post #136 of 383 Old 02-09-2011, 12:11 PM
tw_jeep
After reading this thread and other mudb8 info, I wish Oregon wasnt so far away.
Good stuff mudb8 - thanks for all your posts/tables/analyses...
2000 TJ Sport/auto/D44/X8000i & Tomken mount/jeeperman rear bumper and rails/Skidrow steering skid/RE 3.5SF/33x10.5x15ATKOs/JB Conversions SYE/CV shaft/BESTOP tire carrier/AtoZ front bumper/Front Aussie Locker/some aesthetic stuff/
tw_jeep is offline
post #137 of 383 Old 02-09-2011, 12:14 PM
CRJeepin
Agreed! There's not a lot in the way of good shops on the east coast, at least not near MD/PA.
CRJeepin is offline
post #138 of 383 Old 02-09-2011, 06:09 PM
dbbd1
dbbd1's Avatar
I am sure if you paid his airfare...
The opinions of worthless people, are worthless.
The only problem that you have with anyone in this world, is what you expect of them.
Society is no match for a stupid person.
"Life Is tough but it is tougher when you are stupid"
-John Wayne
dbbd1 is offline
post #139 of 383 Old 02-10-2011, 06:46 AM
CRJeepin
Haha! Not necessary for shocks....but for all the little odds & ends that come up with Jeep ownership, it'd be great to have somebody with his experience nearby when you get into something that really stumps ya!
CRJeepin is offline
post #140 of 383 Old 02-17-2011, 10:54 AM
bandit455
Mudb8,
Do you know if the teraflex shock adaptors that give you another inch of uptravel can be used with a bilstein 7100? the appear to have a standard shock eye, but use heims.
Eagle scout jeeper #10
The Things We Make, Make Us
bandit455 is offline
post #141 of 383 Old 02-18-2011, 10:01 AM
UofMtj
alright quick question that hopefully I can get just a straight forward answer on. I'm installing an RC 4 in suspension lift tommorow also I'm going to have 2 in coil spacers on top of that. I'll be running 35's on stock rims. what size bump stops do I need in front and back? I'm prolly just going to fab some up from materials I have. Any help is appreciated.
UofMtj is offline
post #142 of 383 Old 02-18-2011, 10:10 AM
telkins88
What rough country 4" lift are you running?
telkins88 is offline
post #143 of 383 Old 02-18-2011, 11:19 AM
UofMtj
it's the s series lift kit. short arm kit. the basic shocks...not the 2.2's.
UofMtj is offline
post #144 of 383 Old 02-18-2011, 12:20 PM
telkins88
Does it come with adjustable control arms? If it doesn't I really would not recommend adding the 2" spacers. Anything above 4" on a short arm will give you a terrible ride. I run 35's with a 4inch short arm and they fit well. If you are going to run sway bar disconnects I would run 3" bumpstops.
post #145 of 383 Old 02-18-2011, 12:58 PM
UofMtj
yeah I'm buying the discos in a couple weeks. so 4 in with 35's has a good amount of clearance? I plan on getting smittybuilt flat fenders so that will help.
UofMtj is offline
post #146 of 383 Old 02-18-2011, 05:50 PM
telkins88
Yea actually that's the flares I am running. They made a huge difference in clearance.
post #147 of 383 Old 02-18-2011, 10:46 PM
UofMtj
okay right on! so tried installing the front tonight without a spring compressor...yeah no way. I'll have to rent one from napa tommorow to continue.
UofMtj is offline
post #148 of 383 Old 02-19-2011, 04:45 AM
telkins88
Autozone also has them for rent. But it should look good with just the 4" and 35's. Install some 3" bumpstops and it shouldn't rub ever even at full flex.
post #149 of 383 Old 02-19-2011, 01:47 PM
UofMtj
hey thanks for the advice!
UofMtj is offline
post #150 of 383 Old 03-01-2011, 09:12 PM Thread Starter
mudb8
want it rite or rite now?
mudb8's Avatar
here's some bumptop/spring tech....
Rear Springs are Rancho 2.5" RS616... unloaded length is 15.5". collapsed to coil bind they are 5",
Which means the 2.5" rear lift springs REQUIRE a minimum of 1.5" bumstop extension whith the relocated spring perches, no loss or gain in ride height was made from the relocation, I made sure to set them exact.
A stock 104 rubicon/sahara rear spring is 11 3/4" unloaded, 3 3/8" @ full coil bind...
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable
ASE Certified Master Tech/Fabricator @ jeepwest.com
mudb8 is offline
bump stop , bump stops , bumpstop , bumpstops , shock length
What size bumpstops do i need with bb and 33s trick pony TJ Wrangler Technical Forum 8 05-09-2009 09:29 PM
shock length???? bradp37 YJ Wrangler Technical Forum 0 01-16-2009 03:10 PM
Need longer bumpstops, and shock travel? Scotch740 TJ Wrangler Technical Forum 7 09-11-2008 01:55 PM
RE Shock Length jeep 62 TJ Wrangler Technical Forum 0 02-03-2008 03:42 PM
Shock Length jeepteejay TJ Wrangler Technical Forum 3 10-26-2006 09:12 AM
