Bumpstops ?? - JeepForum.com
post #1 of 17 Old 05-16-2007, 03:23 PM Thread Starter
nevadamike
Bumpstops ??
Ok so i did the search thing and think I got the info that I needed but i want to double check. I'm getting a black diamond 3in lift from a guy on here, there is no bumpstops with it. Now i know I'll need them if I get bigger tires but for right now, I'm just going to stay with my 245/75/16's that are on it since there still pretty new. So if I stay with my tires that I have now, am I going to need the bumpstops right now?
Mike
nevadamike is offline
post #2 of 17 Old 05-16-2007, 03:29 PM
elkfan2
elkfan2's Avatar
I personally wouldn't worry about the extended bump stops. When I installed the 2" BB in mine and put in the longer bumpstops I eventually had to cut them back to the original length because it kept bottoming out on them. I now have a 6" Long Arm lift and still have the factory lenght bumpstops and have no problems. There is a company in quadratech that makes some that fit over the shock piston that look like a pretty good set-up, I would maybe look into those.
elkfan2 is offline
post #3 of 17 Old 05-16-2007, 03:53 PM
VinoTJ
VinoTJ's Avatar
I would put your lift on, disconnect the front sway bar and see if your tires will hit the flare at fulll stuff (in your driveway/parking lot - not on the trail).
I have OME 2.5 + 1"BL with 33x11.5 and I think I have too much bumpstop. I think you will be fine - but best to check it out before damaging your fenders on the trail.
2008 Wrangler Unlimited X
VinoTJ is offline
post #4 of 17 Old 05-16-2007, 04:00 PM
airframer
airframer's Avatar
i have a 3.5 lift with 33's i never installed the bumpstops due to the shop on base closing, i have never had a problem
airframer is offline
post #5 of 17 Old 05-16-2007, 04:43 PM Thread Starter
nevadamike
Thanks for the info guys. Airframer where you stationed at?
post #6 of 17 Old 05-16-2007, 05:06 PM
blacksheep1
what concerns me about running without bumpstops would be that every time you bottom out your shocks all the impact will be against your shock mounts instead of the much heavier duty axle to frame bumpstops. i am facing the same issue as i recently got new shocks that are a bit longer than what most would run with my lift. i did this so that i will have massive droop. i wheel pretty slow for the most part and dont need the compression. plus this will allow me to run a larger tire with less lift.
just my $.02
3 Jeep family again.
MINE 1999 TJ sport, HERS 2004 KJ Renegade and 2005 Rubicon
Wind Tunnel Tested . . . FAILED
blacksheep1 is offline
post #7 of 17 Old 05-16-2007, 05:22 PM
95BadBoy
nevadamike
You will see many opinions on wether you need to install bumpstops. Some will say that if you don't rub your tires on your flairs - that you do not need them.
Proper bumpstops help protect from completely compressing your coils. Completely compressing your springs will def shorten thier life and eventually ruin them. Some people will advise you that it does not matter, because they are doing it (or thier friend told them they were doing it). It is about more than how your tires stuff or what someone has gotten by with.
It's all about choices. Some are good, then again some not so good. Do what you feel is best for you and your rig. I would run the bumpstops.
95BadBoy is offline
post #8 of 17 Old 05-16-2007, 05:28 PM Thread Starter
nevadamike
Originally Posted by 95BadBoy
nevadamike
Thanks that was very helpfull.
post #9 of 17 Old 05-16-2007, 06:55 PM
airframer
airframer's Avatar
i am stationed in fort worth texas at nasjrb
post #10 of 17 Old 05-16-2007, 06:56 PM Thread Starter
nevadamike
Ok I'm at NAS Fallon NV
post #11 of 17 Old 05-16-2007, 06:58 PM Thread Starter
nevadamike
Where can I find a decent set of bumpstops at online? If no one around the forum is selling a set.
post #12 of 17 Old 05-16-2007, 07:01 PM
airframer
airframer's Avatar
no doubt man so im assumin ur in the navy, if u want i have the kit from re for my 3.5 lift, u can hve them for a small fee
post #13 of 17 Old 05-16-2007, 07:04 PM Thread Starter
nevadamike
Ya I'm in the Navy for about 8 more months then I get my parole papers. How much is a small fee shipped to 89408?
post #14 of 17 Old 05-16-2007, 07:09 PM
airframer
airframer's Avatar
i ll find out but how much u wanna spend, 20-25
post #15 of 17 Old 05-16-2007, 07:10 PM Thread Starter
nevadamike
IS that the complete set front and back?
where to buy bumpstops 472cid TJ Wrangler Technical Forum 4 07-19-2009 08:45 AM
Bumpstops...How Big? 46hemi TJ Wrangler Technical Forum 2 10-04-2006 03:26 PM
Bumpstops PolloLoco TJ Wrangler Technical Forum 4 05-04-2006 10:59 AM
bumpstops Jibbyjeep00 TJ Wrangler Technical Forum 2 04-05-2006 11:20 AM
Bumpstops TheDuke05 TJ Wrangler Technical Forum 4 06-03-2005 07:27 AM
