Bumpstops - JeepForum.com
post #1 of 7 Old 08-08-2011, 03:40 PM Thread Starter
OahuCrawler
Bumpstops
Anyone use the new Daystar Stinger Bump Stops at all? I was looking around online and came across them. They look pretty good, progressive stops int he canister and it can be adjusted as you need it. You just weld the mounted bracket on your spring perch and its done it looks like. Yalls thoughts?...
99 TJ Sport- 31x10.50 BFG A/T, DDM H.I.D upgrade, Body Armor 4x4 bumpers and tire carrier
97 TJ SE 4" with 33's- Sold but will always be my 1st JEEP
2010 AUBURN UNIVERSITY UNDEFEATED BCS NATIONAL CHAMPIONS 14-0
OahuCrawler is offline
post #2 of 7 Old 08-08-2011, 03:43 PM
TheBoogieman
The Devil's Advocate
TheBoogieman's Avatar
Unlimited04 is shaking his head right about now.
TheBoogieman is offline
post #3 of 7 Old 08-08-2011, 04:54 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
Let's see. Those are $210 and require significant fabrication and welding.
These cost $4 and don't require any welding.
Which brings us to Boogie's correct assessment:
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #4 of 7 Old 08-08-2011, 05:15 PM
jeepsus
I did the hockey puck bumpstops. my actual cost was $12 for 12 pucks (3" decrease in uptravel at each corner) plus a tube of RTV $9.99 and about an afternoon.
i am super happy with it.
I am helping to fight a great cause that hit close to home, please click to read my story!
jeepsus is offline
post #5 of 7 Old 08-08-2011, 09:28 PM Thread Starter
OahuCrawler
When you say hockey puck, do actually mean a hockey puck like in the sport? How are those set up?
post #6 of 7 Old 08-08-2011, 09:35 PM
Unlimited04
yes, hockey puck as in the sport. you glue them down to the spring pad in the front (can only use them in front) using an epoxy. they're 1" thick...and you can stack them up if necessary.
Useful Write-Ups:
Funny:
post #7 of 7 Old 08-08-2011, 10:12 PM
MayRoll
Or you can use JKS bumpstops. They're great if you feel that down the road you might change coil/damper configurations.
First of the Breed
03 Khaki Rubi
JF short arm champ
MayRoll is offline
No bumpstops... PirateJoe YJ Wrangler Technical Forum 3 09-04-2009 06:58 PM
YJ bumpstops NorthwestYJ YJ Wrangler Technical Forum 1 08-28-2009 12:47 PM
Anyone use Bumpstops? StCloudMNSahara YJ Wrangler Technical Forum 24 05-19-2006 07:06 PM
BB Bumpstops ?? DeepC TJ Wrangler Technical Forum 8 04-10-2006 05:56 AM
bumpstops Jibbyjeep00 TJ Wrangler Technical Forum 2 04-05-2006 11:20 AM
