bumpstop extensions - JeepForum.com
post #1 of 11 Old 12-08-2012, 08:46 AM Thread Starter
andrewf09
bumpstop extensions
I just purchased AEV 3" springs, 1.25 BL + 1" MML and Rancho 9000xl shocks and plan on using 33's
What size bumpstops should I use?
andrewf09 is offline
post #2 of 11 Old 12-08-2012, 08:49 AM
biffgnar
biffgnar's Avatar
Measure distance between spring pad and edge of bumpstop cup (not jounce bumpers). Measure distance from tires to fenders. Measure distance before shocks bottom out. Add bumpstop extensions till first measurement is equal to or less than other two measurements.
Edit: Oh, yeah, also need to check your steering in front at full bump. Depending on where you have axles positioned, what trackbar you are running, what diff cover you are running, etc. you may need more extension to prevent interference there.
biffgnar is offline
post #3 of 11 Old 12-08-2012, 08:49 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
use just enough to keep the shocks from bottoming out, avoid suspension interferences at full bump and keep the tires out of the steel of the fenders.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #4 of 11 Old 12-08-2012, 08:56 AM Thread Starter
andrewf09
everything is stock. I also purchased the Currie Adjustable trackbar with bracket for the back.
post #5 of 11 Old 12-08-2012, 01:36 PM Thread Starter
andrewf09
Unlimited04, i'm going to read your write up later today.
http://www.jeepforum.com/forum/f9/bu...points-734737/
Nice job on the TJ Tech BOOT CAMP-A Must Read!
post #6 of 11 Old 12-08-2012, 01:47 PM
Ironhead
every vehicle is different, the only way to tell is to do the work and cycle your suspension
Ironhead is online now
post #7 of 11 Old 12-08-2012, 02:12 PM
chmo
guys ... even though there are so many variations ...
but can't you just tell OP 1.5"-2" BS extension for his 33" with a 1.25 BL and Rancho shocks for 3" lifts should be OK?
The theory ... with 1.25 BL he would clear 33" off his fenders if he uses about 1" BS extensions.
The Rancho shocks are the limiting factor ... and savvy is selling the 2" Currie BS extensions for their 3" and 4" lifts ... with or without BL ... and quite often in conjunction with the right Ranchos. Not so much magic, right?
"The more I know, the more I realize how much I don't know"
chmo is offline
post #8 of 11 Old 12-08-2012, 02:24 PM
biffgnar
biffgnar's Avatar
Give a man a fish or teach him how to fish
biffgnar is offline
post #9 of 11 Old 12-08-2012, 02:38 PM
Ironhead
thats a lot of estimates, they may work, but would not be optimal.
post #10 of 11 Old 12-08-2012, 03:30 PM
chmo
ever wondered why the Currie Bumpstops (equiv 2" extension) are one size fits MOST applications?
Because MOST shocks for 3"-4" lifts need this much for protection (as well as MOST aftermarket adjustable front track bars need this much to clear front diff cover).
All coincidence ...
If you keep the shock mounts stock there is not much more uptravel to gain ... maybe 0.5" (with a very limited number of 10" travel shocks).
And 33" tires under stock fenders are just fine with 2" BS extension ... with or without BL.
chmo is offline
post #11 of 11 Old 12-08-2012, 03:50 PM
Trendsetter75
2010 JK Wrangler
Please post some before and after pics when your done, Im curious to see how it looks! Thanks!
2010 JKU (6-spd)
Trendsetter75 is offline
aev springs , bl , bumpstops , mml , rancho
