is this bumper winch deal good? - JeepForum.com
post #1 of 11 Old 06-25-2008, 08:42 PM Thread Starter
bremz8
Rock Hammer Jeep Front Bumper -
Tube Work: Winch Height Hoop
Finish: Bare Steel
Winch Fairlead Mount: No Fairlead Mount
Steering Box Skid: No Steering Box Skid
Clevis Shackles: Add Two 3/4" Clevis Shackles
= $375.00
http://www.shrockworks.com/product.php?productid=16138
Ramsey REP 8.5E Winch
8500 lb. Non-Integrated Solenoid Winch
Selected options:
Remote: Wireless & Wired Remotes
Rope: Synthetic Amsteel Blue - 5/16x100ft.
Fairlead: ShrockWorks Aluminum - Natural
= $796.00
http://www.shrockworks.com/product.php?productid=16195
thanks
bremz8 is offline
post #2 of 11 Old 06-25-2008, 10:10 PM Thread Starter
bremz8
bump, trying to buy this tonight ty sry for being impatient
bremz8 is offline
post #3 of 11 Old 06-25-2008, 10:19 PM
RnEmOvr
Have Cummins, Will tow.
RnEmOvr's Avatar
that style bumper can be found cheaper, and a warn winch of same stats is lot cheaper
RnEmOvr is offline
post #4 of 11 Old 06-25-2008, 10:27 PM
raskull
raskull's Avatar
It's not a regular tube bumper.. it's formed and has a larger top plate for the winch. It also has a winch guard. Not only that, I've seen Shrockworks stuff and it's very strong and well built. $375 seems fair to me.
The winch however.. if you want something cheap maybe try the Warn M8000? They can be had for about $600 or cheaper on sale.
(O|||||||O)
l_l*-----*l_l
Raskull - Metallic Silver '03 Jeep TJ Sport (
<- Write-ups on mods/maintenance/trips and a video/image gallery
raskull is offline
post #5 of 11 Old 06-25-2008, 10:29 PM
RnEmOvr
RnEmOvr's Avatar
if i can get this bumper for $325 new, i know he can do better cause mine has the same style winch plate,
RnEmOvr is offline
post #6 of 11 Old 06-25-2008, 10:31 PM
PyroXian
A Warn winch with 100' of amsteel blue and an aluminum hawse fairlead for cheaper than that... I doubt that very much. I think if you look at the specs on the bumper it's substantially beefier than most that are similar in style also. 1/4" v. the typical 3/16". Factor in the integrated winch mount & I think it's a decent deal... maybe not great but certainly decent.
Take a look at this link before you pull the trigger though
http://www.winchline.com/winch.htm
They offer superwinch v. ramsey, but price is similar for the same setup (synth & aluminum) ... the comparison at the bottom of that page paints a picture of the superwinch that is very favorable when compared to several other big name winches... Or spend a couple hundred more & get a Warn.
I wish I had enough money to drive stupid.
PyroXian is offline
post #7 of 11 Old 06-25-2008, 10:32 PM
bigchevyman24
bigchevyman24's Avatar
That's actually not too bad on the winch bumper. I want something similar and the cheapest I could find it was around $200 without the winch plate and that was on ebay. I wanted to do this, but lack on welding skills: http://www.rokmen.com/products/diy_f...nt_bumper.html
CURRENT: 2001 WJ V8 LIMITED - Quadratrac, 60th anniversary, Fat Bob's 2.5/2 lift, HID's, roof rack, 31" Rugged Terrains, 5k lb Curt Hitch
SOLD: 2000 WJ 2WD CONVERTED TO 4X4, 97 TJ ON 35'S, 95 XJ ON 33'S
bigchevyman24 is offline
post #8 of 11 Old 06-25-2008, 11:06 PM
RnEmOvr
RnEmOvr's Avatar
i missed the Synthetic Amsteel Blue line, so winch yes thats a good deal, but i still think bumper seems high considering i payed less for mine and it has the same intergrated winch plate and a full stinger
RnEmOvr is offline
post #9 of 11 Old 06-26-2008, 05:40 AM
phonewiz
Hey Bremz8...You can get a very similar front bumper from Eddie at Ground Pounder for probably less then $300.00. Email Eddie a picture of the bumper you like and he can make it custom to have any option you want. website: www.groundpounderfab.com email: groundpounderfab@verizon.net
2006 Silver TJ Rubicon 4.0L,6-Speed,AC/Cruise/Kenwood DDX512, with both Black Hard and Soft tops.
phonewiz is offline
post #10 of 11 Old 06-26-2008, 10:51 AM Thread Starter
bremz8
thanks for all the replys very helpful. on the ramsey winch i chose the 8500 cuz its little more than i need and it was the cheapest listed ramsey winch i found. i have a small crush on ramsey winches from my last winch, bought it new in 1986 and still pulls out my toyota tundra. i checked out the ground pounderfab and that looks promising just wondering can he have mount points for a winch added and a winch height grill guard?
thanks again!
bremz8 is offline
post #11 of 11 Old 06-26-2008, 11:39 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
thanks again!
ramesy winches are notoriously slow. Check out T-Max and Warn. T-Max's are a lot cheaper than Warn, but don't have the lifetime warranty, and have been known to destroy itself before thermally shutting off. Warn on the other hand has been known to thermally shut off before the job is finished, and before the motor gets 'all that hot'. you want a winch rated for twice the vehicle weight...so if your TJ weights 4000lbs, you want an 8000lbs winch. Snatch blocks can be used to double the winches capacity.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
R/C winch plate & 8500lb Super winch on factory bumper. fernjack JK Wrangler Technical Forum 17 11-23-2010 10:12 AM
I'm an idiot.. and ordered a winch.. (Winch plate for stock bumper) RVA_TJ06 TJ Wrangler Technical Forum 32 12-26-2009 08:35 AM
Pics of new MOPAR winch bumper, the one w/fog light cutouts & Hyd winch nycrd JK Wrangler Technical Forum 25 12-11-2009 05:33 AM
guys looking for a deal on front bumper or rear bumper with tire carrier... 79CHKCHK Wrangler General Discussion 1 05-31-2009 12:41 PM
Rugged Ridge XHD Non Winch Bumper Stronger than Bumper w/ Winch Plate??? mlupacchino JK Wrangler Technical Forum 7 04-21-2009 06:01 PM
