Bumper tire carrier breakage - JeepForum.com
post #1 of 18 Old 07-27-2011, 10:28 AM Thread Starter
ATLTempe
So a fellow Jeeper drops by and we're discussing my TJ build. I mentioned that I had ordered a new bumper/tire carrier for my rig and he strongly suggested that I not do it. His point was that no matter how robust the pivot on the carrier was built the bumper would eventually crack around the welds. A quick search of the forum didn't come up with anything. Any input?
ATLTempe is offline
post #2 of 18 Old 07-27-2011, 11:08 AM
ftgiles
Here's some points to consider when talking to a "Fab Guy" when their "will never break design" is all about "bigger and heavier".
Just look at the first post in this thread
http://www.jeepforum.com/forum/f9/br...rrier-1110894/
http://blog.comp4x4.com/
http://www.comp4x4.com/instructions/Dual-shear-tire-carrier-hinge-kit-installation-03.pdf
ftgiles is offline
post #3 of 18 Old 07-27-2011, 01:05 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
lots of people prefer the tub mounted tire carriers.
many say the frame & crossmember itself are flexing slightly, even with frame tie-ins...with the leverage of a tire carrier, 1mm of flex at the frame turns into 1" at the tire.
I used to have a bumper/tire carrier combo, it weighed 120lbs. i sold it because I couldn't stop it from rattling against the tailgate, even with much bumperette work. I now run a tub mounted tire carrier and don't even know its back there.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #4 of 18 Old 07-27-2011, 01:20 PM
Dabbill
http://www.genright.com/ProductInfo....ductid=RTC3200
This is what i will likely go with.
Dabbill is offline
post #5 of 18 Old 07-27-2011, 01:32 PM
Lawrence
This is nice and it would help prevent the spindle from breaking off, but I think it should be used in conjuction with upper tie-ins to reduce the leverage on that single pivot point. Mine is failing both at the spindle area and also at the crossmember mounting area.
The one I had on the TJ put a nice dent in the tailgate and the one on the LJ is failing miserably as noted above.
I am leaning toward the T&T tub mounted one but some things bug me about it. The other option would be the Hanson hybrid combo with has an upper hinge and rollbar tie-ins
Lawrence is offline
post #6 of 18 Old 07-27-2011, 02:27 PM
ftgiles
There might be a "good" bumper-mounted spare-tire carrier but there are so many bad ones. And most of the bad ones come from some "fab guy's" garage or only cost $500 (Olympic or Smittybuilt). If it's going to work it's going to be double-sheer at the spindle, just for starters.
I would never run a bumper mounted spare!
Then you've got guys that think if it's body mounted then it's some trickery and hours of time that keeps them from opening their tailgate.
OR-Fab has an outstanding, easy-to-open body-mounted tire carrier.
AEV has an outstanding double-sheer spindle bumper setup that is also attached to the tailgate that has the design features that could work, but that's a JK offering.
Hanson also has something similar (double sheer/body mounted) for a TJ that could work, but it's not a nice looking setup, which Hanson is normally known for.
The biggest thing that people don't pay enough attention to is the departure angle of the tire. Using the tire as a skid is really hard on any carrier. So forget about the low-hanging-tire setups to begin with.
And does one really need a can carrier making the departure angle even worse? Keep it high and tight.
ftgiles is offline
post #7 of 18 Old 07-27-2011, 02:34 PM
Speed94
I run a BESRK bumper and carrier...no issues yet. Not even a rattle when going over bumps at speed.
97 TJ PD club member #007
Speed94 is offline
post #8 of 18 Old 07-27-2011, 03:02 PM
Lawrence
Mine was supposed to be a "good" one, oh well. I agree on the preference to run a tub mounted one, but the choices are slim.
I have seen it on several occasions and I think it is a really good carrier. Unfortunately, the mounting bracket seems to be in the way if you have flush mounted LEDs and it appears that it may not work in this case.
Hanson's seems to be the best alternative to a tub mounted one. They claim their redesigned version is much more reliable than before with the upper hinge now tied into the rollbar on the pivot side, and a new upper latch on the left side. Here is a pic from forum member TheDragonfly
Lawrence is offline
post #9 of 18 Old 07-27-2011, 03:03 PM
Necko2529
Necko2529's Avatar
Ftgiles. What are you running, neighbour ?
Rokmen TT, Rokmen control arms, Novak NV241 cable shifter, JKS 1.25" BL + 1" MML.
Anybody can take advice if it doesn't interfere with their plan.
RIP "Prescott 19" Prescott Fire Department
Necko2529 is offline
post #10 of 18 Old 07-27-2011, 03:08 PM
Varnish
Varnish's Avatar
In retrospect, this is something I wish I had put more thought into. If you often do real steep climbs then keep in mind that tire is gonna hit.
'06 LJ, '88 YJ
Varnish is offline
post #11 of 18 Old 07-27-2011, 03:14 PM
Unlimited04
yup, I expected this when I built my bumper mounted tire carrier. I welded the spindle through both sides of the tube - top and bottom. It was very solid to the bumper. Still couldn't eliminate the flexing of the upper frame into and away from the tailgate though....
yea, those look sweet. too bad they're soooo expensive.
I've seen some nice tire carrier skids that mount into the receiver hitch. Myself, I just slide in a hitch. I don't care if I bash the heck out of a hitch sliding off a rock Heck, I've been known to drag my hitch mounted bike rack on trails, with my mountain bike on it.
Useful Write-Ups:
Funny:
post #12 of 18 Old 07-27-2011, 03:30 PM
Lawrence
I know, garbage. I'll have mine rewelded and then it's off to CL.
Not that expensive if you consider the price of an Or-Fab or T&T tub mounted carrier and the addition of a nice rear bumper. Pretty much in the same league price-wise, unless you build your own.
Lawrence is offline
post #13 of 18 Old 07-27-2011, 04:09 PM
ftgiles
At the risk of sounding like I'm plugging the one that I have, therfore it's the best, I refuse to answer.
If you really start looking and thinking about the Hanson setup, it's pratically a body-mounted carrier. So why involve the bumper?
Plus the tire is 2" lower when mounted on the Hanson setup vs. the OR-Fab setup and 3" lower if you run a 1" body lift.
ftgiles is offline
post #14 of 18 Old 07-27-2011, 04:56 PM
Jay12
You shouldn't have to extend those rubber bumpers on the tailgate if your tire carrier latches properly, and is strong.
Jay12 is offline
post #15 of 18 Old 07-27-2011, 05:43 PM
wushaw
Rockin jeep
wushaw's Avatar
Interesting, I copied Besrks bumper/tire carrier design and it don't squeak, rattle or shake. The spindle is in a sleeve so it's not welded at the top so if it breaks it's not going to be due to a weld weakening the spindle.
wushaw is offline
arb rear bumper w/ tire carrier vs currie rockcrawler2 w/tire carrier and rockribs lstcj7 Wrangler General Discussion 0 07-03-2010 07:57 AM
guys looking for a deal on front bumper or rear bumper with tire carrier... 79CHKCHK Wrangler General Discussion 1 05-31-2009 12:41 PM
Bestop Tire Carrier or Bumper/Tire Carrier Combo dallasjetfan TJ Wrangler Technical Forum 6 12-22-2008 09:46 AM
Front Bumper, Rocker Guards w/ Steps, Rear Bumper w/ Tire Carrier VaLoRiaN TJ Wrangler Technical Forum 23 04-28-2007 08:07 AM
Rear Bumper Tire Carrier Bike Carrier Solution Cidk TJ Wrangler Technical Forum 1 05-07-2003 09:39 PM
