Bumper Frame Tie-In-Are LJ Holes same as TJ - JeepForum.com
post #1 of 23 Old 08-04-2012, 02:50 PM Thread Starter
explorerlyon
I need to add frame tie-ins to my bumper. Are the holes in the frame identical for an LJ as a TJ? I have searched and think they may be different.
05 Rubicon Unlimited, Automatic
explorerlyon is offline
post #2 of 23 Old 08-04-2012, 02:53 PM
Delta9
Delta9's Avatar
Yes sir! Did that to my LJ.
Delta9 is offline
post #3 of 23 Old 08-08-2012, 11:22 AM Thread Starter
explorerlyon
The tie-in brackets that came with my bumper (LoD) are pictured. The holes do not line up. Are the LJ holes alligned different than a TJ or do I have a bad bracket?
post #4 of 23 Old 08-08-2012, 11:27 AM
GMBNT42
TJ/LJ same.
GMBNT42 is offline
post #5 of 23 Old 08-08-2012, 12:16 PM
tweenerlj
The genright ones that I installed on my LJ lined right up. They are sold to fit all TJs including the LJ.
tweenerlj is offline
post #6 of 23 Old 08-08-2012, 12:24 PM
brplatz
Pry bar?
The Second Amendment is in place in case they ignore the others.
That's like saying you wish your boyfriend was a bit less gay.
MOΛΩN ΛΑΒΕ
brplatz is offline
post #7 of 23 Old 08-08-2012, 12:30 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
i had the same problem with the frame tie-ins I bought from Jeeperman back in 05-ish.
I mounted them on the bumper end, and drove to a local muffler shop and had them weld the frame tie-ins on...cost $20. it's cheaper to do that than ship those back or buy new units.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #8 of 23 Old 08-08-2012, 05:51 PM
williambmac
The tie-ins from my 2000 tj worked fine on my 05 LJ. Everything lined up perfect.
2000 TJ 5.5 Long arm, lots of extras. R.I.P.
2005 LJ rubi 35's Clayton, lots of extras
williambmac is offline
post #9 of 23 Old 08-08-2012, 08:28 PM
Hesher420
I installed Rokmen tie-ins on my '06 LJ without any alignment issues.
"We are one. One society. Digitless."
"I am not a number, I am a free man!"
Hesher420 is offline
post #10 of 23 Old 08-09-2012, 09:03 AM
joe_jeep
do you own a drill? or a welder?
glfwda #6624
2005 rubicon sahara lj #592
joe_jeep is offline
post #11 of 23 Old 08-05-2014, 09:46 PM
aje3721
2006 LJ won't line up
Short and simple. LOD bumper with the Rigid Dually cut out; excellent. Frame tie ins; don't line up. LOD says the LJ is different, Rokmen says they are the same as a TJ. Any more information out there on this. I don't want to burn on the frame and yes, I have a drill. I've considered welding the holes shut in the LOD tie ins, marking and re-drilling but if there is something out there that fits I'd rather go fishing and avoid the drama.
aje3721 is offline
post #12 of 23 Old 08-05-2014, 10:12 PM
05x
05 rubi tj here a to z tire carrier w/frame tie ins I was told also works for LJ
05x is offline
post #13 of 23 Old 08-05-2014, 10:13 PM Thread Starter
explorerlyon
LOD is WRONG!!!!! I was told the same thing and started this thread. I purchased new frame tie-ins from Ground Pounder Fab. They lined up perfect and were way better than the ones from LOD. The Ground Pounder Fab frame tie-ins used to be available on e-bay but I cannot find them now. Throw away the LOD frame tie ins and get something else.
post #14 of 23 Old 08-05-2014, 10:17 PM
Lastshot
I had to grind a little of My AtoZ tie ins,Holes were ever so slightly low, not as bad as in those pics though
{Project
-'05 LJ build }~{SOLD '98 TJ -
{You know you drive a TJ
gily25 Says...
Issues only become problems when you don't have the tools or time to fix it.
Mike318 Says...
I like my 4.0L like I like my ****... stroked and blown. :duhrock:
Lastshot is offline
post #15 of 23 Old 08-06-2014, 07:18 AM
Tonellin
That's pretty disconcerting that the LJ is a decade old and they still don't know the differences between a LJ/TJ. I can't imagine how many people they've tried to convince over the years that the frame holes are different between the two models.
06 LJ Rubicon
http://www.jeep-owner.com/index.php/topic,748.0.html
Tonellin is offline
holes in frame???????? 45caljeep TJ Wrangler Technical Forum 7 03-18-2010 05:48 PM
Holes In The Frame tedder19 TJ Wrangler Technical Forum 12 05-05-2009 09:00 PM
What are these 3 holes in the frame for? YJames90 YJ Wrangler Technical Forum 15 06-19-2008 08:47 PM
Drain holes in frame? Tom Hartz TJ Wrangler Technical Forum 6 03-31-2007 03:17 PM
holes in frame? ramburger YJ Wrangler Technical Forum 1 03-19-2006 09:19 PM
