Quantcast Bumper Build || Next Stage - Page 6 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Bumper Build || Next Stage
Truck-Lite's New LED Headlamp Series4.25" 97-06 Jeep TJ Wrangler Lift Kit - NO SYE NeededRuffstuff Axle Simple Swap Kit!
Old 09-07-2009, 09:57 PM   #76
Gonewhln
i hate them also i just found out Parts america owns 4 wheel parts/4wd Pro Comp and smitty built and the list goes on....who's next to fall to the corporations.
Gonewhln is offline   Reply With Quote
Old 09-07-2009, 10:44 PM   #77
cheech66
jeep t 99 really enjoyed all your info tks for all the great stuff i love this **** tks man!!!
cheech66 is offline   Reply With Quote
Old 09-09-2009, 03:34 PM   #78
C2U5H
Okay guys, here's a question for you:
I'm trying to find a hard mount for the quick disconnect outlet somewhere on my frame rail, but I can't find an explanation of how to do this. Does the QD disassemble and reassemble, going through a hole in a piece of sheet metal ... because I can make that easily. How is it done??
Also, I can't find a detachable cap (with a tether) for the QD when not in use. I've searched all over the place locally and on the net ... maybe I'm not using the correct search terms? Can someone help me out here??
Thanks!
Formally JeepinTJ99 ...
Go Anywhere: 2012 "Crush" Clearcoat JK Rubicon, loaded to the hilt || Thread
Carve Time: 2009 "Racing Red" Buell 1125CR — 150 RWHP
Will be missed:
1999 "Deep Amethyst" Pearlcoat TJ +3" on 33's
C2U5H is offline   Reply With Quote
Old 11-03-2009, 08:51 PM   #79
Tjosh97
Originally Posted by JeepinTJ99 View Post
Can't beat that for $200. Only a little more than the 150W KC's, and considerably less than the "nicer" lights.
Question do you have the write up on the wiring of these HID lights thanks?
Beep Beep, who got da keys to the JEEP???
Red Jeep Club #556 - "DA 4-$LANGER"
1997 Flame Red TJ 4-Banger (2.5L) 4.0 TB 62mm Bored w/ Spacer -- 31x10.50 D. Cepek "Crushers" -- 15" Black Rock Crawlers -- AEM DryFlow -- Dynomax Super Turbo Cat-Back -- EBC Brake System -- Rough Country 2.5" Lift w/ Discos -- RC Adj Track Bars -- Currie HD Steering -- Rugged Ridge Diff Covers - DDM 6000K HID
Tjosh97 is offline   Reply With Quote
Old 11-04-2009, 12:28 AM   #80
Deacon
Purveyor of Funk
Deacon's Avatar
Thanks!
Are you talking about a way to store the QD up out of the way when you're running around on the trail disconnected? If so, check out TeraFlex's disconnects. They're what I have. Notice there are 4 posts, there? Not just two? In the picture (zoom in if you have to) the two posts on the right are screwed into the frame where the disconnects naturally swing up to after you pull the pins and disconnect them. You have to drill a hole in the frame for each side and then tap it so that you can screw in the posts. So when you disconnect, you swing them up, put them on the post, and then put the washer on and then put the retaining pin in just like you would if they were disconnected, and it holds them up and out of the way. For me, this is the perfect solution. I don't know if other brands come with the same kind of thing, or if you can buy just those upper posts from TeraFlex, or what. Of course, you could make your own, too.
I don't have a picture of the finished product at the moment, but here's a pic I snapped while a buddy of mine was doing the tapping, to give you an idea of where they go:
Deacon is offline   Reply With Quote
Old 12-02-2009, 01:11 PM   #81
C2U5H
I don't think one is really needed tobe honest. They use a simple two wire hookup since the ballast is integrated within the housing. Just use a switch, fuse, and simple 30A relay and you're set. If you really want a step by step write-up, PM me.
Thanks for putting your time into helping me out Firekit, but I'm talking about a female pneumatic QD for my OBA setup. Still haven't fixed it yet.
Will be missed:
Old 12-02-2009, 11:06 PM   #82
Deacon
Purveyor of Funk
Deacon's Avatar
You mean where you can hit a switch and roll disconnected? I don't think there's any such thing. If you're not referring to disconnecting the suspension, you might want to consider where you're posting and therefore be more clear about it
Old 12-03-2009, 08:38 AM   #83
C2U5H
No offense, but go back and read what I've been doing in this thread. No recent suspension mods (yet!) ... but I just added an On-Board Air (OBA) setup, and I was looking for a way to hardmount the female Quick Disconnect (QD) access point for air. Right now, I have the OBA output zip-tied to the top of my driver side frame rail, and I'm thinking of welding a little tab either on the top of the frame rail or to the rear bumper (when I build it) to hardmount it, but just haven't had the time to do anything.
And there is an electronic quick disconnect setup for the swaybay called the ORO's dual rate SwayLOC with a solenoid-switched pneumatic input source. Push a button, pneumatic solenoid switches the unit to the softer rate (disconnected): Off Road Only SL-TJ-AR - Off Road Only Dual Rate AirROCK&#8482 Controlled SwayLOC&#8482 Swaybar for 97-06 Jeep® Wrangler TJ & Unlimited with 0-8" Lift - Quadratec
You might want to consider where you're posting (my summer build thread) in the TJ Tech Section ... which, last time I checked, OBA setup questions were allowed. Wheel on!!
Will be missed:
Old 12-05-2009, 08:19 AM   #84
Deacon
Purveyor of Funk
Deacon's Avatar
Good lord some people get butt-hurt too easily.
You're posting in the TJ tech section where referring to quick-disconnects means disconnecting the front sway bar. Without any more immediate context or explicit clarification, you have to expect for people to assume that's what you're referring to. Nobody says anything about what is "allowed." And no, the SwayLOC isn't a disconnect, whether manually or pneumatically switched, nor is the Anti-Rock or whatever TeraFlex calls theirs.
And in the end I'm still jealous of your OBA setup.
Glock Forum
EGGERS BROS. INC YOUR JEEP SOURCE
CALL 1-800-274-2460
Competitive pricing!
