Bump stops with new lift? - Page 2 - JeepForum.com
post #16 of 21 Old 07-15-2010, 09:33 AM Thread Starter
Joel99TJ
Are they hard to pull? Wouldn't I need to pull the spring to get them out in the junkyard?
Joel99TJ is offline
post #17 of 21 Old 07-15-2010, 09:34 AM Thread Starter
Joel99TJ
I just talked to the stealership and they said front and back are the same. $50 bucks each!!!!!!!!!!!!!!!!!!!!!
Joel99TJ is offline
post #18 of 21 Old 07-15-2010, 09:37 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
not if your smarter than the spring.
take some channel locks and a socket set. pull the front shocks off, leave the spring and track bar. grab the bumpstops with channel locks, wiggle them out of the cup, let them drop into the spring. remove the cup with socket set, pull that out. then squeeze the bumpstop through the spring. might need to hit it a few times with the channel lock. i assure you it fits...just takes some grunting. i pulled 8+ this way in less than 40 minutes, and that includes walking across a huge junkyard.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #19 of 21 Old 07-15-2010, 09:45 AM Thread Starter
Joel99TJ
So they are held in with pressure, no bolts?
Joel99TJ is offline
post #20 of 21 Old 07-15-2010, 09:53 AM
Unlimited04
you'll see when you try to pull them out. just grab with channel locks and twist and pull down. armor all or vinyl conditioner will make them easier to slide in.
Useful Write-Ups:
Funny:
post #21 of 21 Old 07-16-2010, 12:18 PM Thread Starter
Joel99TJ
I got the energy suspension polyurethane replacement ones, they went in piece of cake. $20 a pair. I am happy and my rough country lift is done! It's awesome.
Here is the link, Energy Suspension 2-9101R - Energy Suspension Front Bump Stops in Red for 97-06 Jeep® Wrangler TJ - Quadratec
Joel99TJ is offline
bump stops , rc , rough country , 2.5 , lift , suspension , worn out
What ext. bump stops are you using with 2.5" RC lift? webejpn01 JK Wrangler Technical Forum 3 09-01-2009 08:00 PM
Bump stops for 35s and +-6" lift 93jeepyj YJ Wrangler Technical Forum 2 07-26-2009 09:00 AM
Bump Stops for 2 Inch Lift cvd TJ Wrangler Technical Forum 6 12-19-2006 02:31 AM
Bump Stops/Lift ?'s JJs99TJ TJ Wrangler Technical Forum 5 02-05-2006 07:22 PM
bump stops on 2in lift motor12 TJ Wrangler Technical Forum 1 03-19-2005 06:10 PM
