BUMP! goes my front end - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > BUMP! goes my front end
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineJeep JK Wrangler 3" Suspension Lift Kits $439.99 deliJeep XJ Cherokee Ulitmate Sliders now available!
Unread 02-21-2003, 11:08 AM   #1
imteachin
Recent snow here in PA. Tooled around in it, nothing major though. Before, I used to notice a "clunk" or "bump" sound in my front end once in a while- usually during a turn or a pothole. Now I have really began noticing this sound, especially when I am making a turn. Little thud under my feet. What is this?
I have also noticed that when I take it out of 4x4, it takes a few seconds to disengage and finally does so with a clunk.
Are these related? Remedies?
Thank you very much.
2000 TJ 4.0 Sport 5spd
imteachin is offline   Reply With Quote
Unread 02-21-2003, 11:15 AM   #2
Jeep-Ne-Time
I think it would help if you stated your vehicle and specifics on the tranny and such. Just a thought
Mark
Wheeling in Arkansas...The Natural State!!
2001 Tj, Yellow Sport, 5 speed,
4.5" RE super-flex, 1" body and motor lift,
33x12.5x15 Super Swamper SSR's
on Black Rock Crawlers,
Locked front and rear
Cobra CB, and NO CHROME!!!!!
Jeep-Ne-Time is offline   Reply With Quote
Unread 02-21-2003, 11:16 AM   #3
asjeep
mine was doing the same thing.... check your tires.....
are they worn more on the front than the rear? get 1 new replacement lately?
i had 2 (identical tread pattern) 2 year old bfgs on my rear and 2 new (same tread pattern) bfg's on the front, had the same noises........ got 2 new rears and life was good
2002 TJ SE
WWW.IDRIVEAJEEP.COM
asjeep is offline   Reply With Quote
Unread 02-21-2003, 11:24 AM   #4
imteachin
Added my info...sry
Tires are 1 yr old...don't think it is that. Definitely a mechanical knock up front... a single "clunk"
2000 Grand Cherokee Limited
4.7 Liter Auto
Wrangler days are over
Unread 02-21-2003, 02:17 PM   #5
Jim Shanks
Maybe try checking your swaybar links, if one's broke it can knock around. Besides that, could be your motor/tranny mounts letting things twist more than they should and rattling your t-case linkage.
HTH,
Jim
"Cracked Cow" '01TonTJ2a, Solid Mfg HP60's, 5.38's, ARB's, PSC full hydro, 14" coilovers, ASD roof and doors, armored everywhere sitting on 40" Iroks.
Owner of IA4x4.com
Subscribe to CRAWL
Jim Shanks is offline   Reply With Quote
Unread 02-21-2003, 02:23 PM   #6
Jeep-Ne-Time
Check out the U-Joints and grease the seven zerks around the front end...If its a clunk make sure everything is tight up front. I am no mechanic, I am just thinking out loud. Never had experiance with your description of whats going on, just trying to imagine what "could" be going on. Have you made any modification to the suspension?
Mark
Unread 02-21-2003, 02:43 PM   #7
macb
get under the front end and tighten everything down...if you offroad
then regular maintenance must be a SOP for you if you want to keep
your jeep running properly. If you have a BB or small lift without
new arms then the bushings on the stock arms could be binding
as well (which is know for causing an intermitant 'cluncking' sound)
retorque and then grease your front end, then get back to us.
HTH
btw, this is exactly how I learned what to do under there.
3.5" Terraflex, 1" BL, Flat Belly Pan, Currie Steering, 35s, Cowl Intake, blah blah blah: [URL]http://www.sajeeps.com[/URL]
[url=http://www.cafepress.com/H2RT]No Bling - H2 Recovery Gear[/url]
Bob Supplee:supplee@ionet.net or (405) 799-8977
Stu Olson's great jeep resource site: [url=http://www.stu-offroad.com]www.stu-offroad.com[/url]
macb is offline   Reply With Quote
Unread 02-21-2003, 03:52 PM   #8
jeepofun
Could it be the diff?
I had a sound like that in my rear diff whenever I made a right hand turn, and it turned out to be a bunk spider gear, it was under warranty though and was replaced for free so if you still have that option you definately want to exercise it before things get really bad.
"I'l believe no matter what they say"
-Sonny
jeepofun is offline   Reply With Quote
Unread 02-21-2003, 03:55 PM   #9
Jerry Bransford
Do it right or not at all
Jerry Bransford's Avatar
One more item to check that commonly causes 'clunks and bumps' is the track bar. That's the part that connects the axle to the frame via that heavy steel tube that mounts at the passenger-side of the axle and the driver's side of the frame. This is not the one that goes to the steering (Pitman) arm.
The passenger-side bolt and nut can be tight enough to feel tight, but not tight enough to prevent clunking as the steering wheel is turned left or right. REALLY tightening that passenger-side nut and bolt down may take care of the noise you hear.
Though the above suggestions like to check for a loose anti-swaybar link are all very good too.
Jerry's Geezer Jeep II Website
Getting Savvy...
Coolest offroad magazine ever! CRAWL Magazine
Jerry Bransford is offline   Reply With Quote
Unread 02-21-2003, 08:07 PM   #10
mrmagoo1
Check the bolts on your transfer case skid. Mine were loose(damn nutserts) it allowed the the whole works to shift just enough to make a clunk under my feet.
if the the car in front is going too slow
[DRIVE OVER IT!!!!!!
mrmagoo1 is offline   Reply With Quote
