Buildup for my '04X - JeepForum.com
post #1 of 8 Old 08-29-2006, 11:54 AM Thread Starter
Lud04X
Buildup for my '04X
Just asking for your opinions on this build.
1) Lift-OME Ultimate Kit around 1200.00 bucks
2) 33x12.50x15 Kumho Mud Tires on my current 15x8 Cragar 342D wheels with 4.0 BS
3)Axles and gears- This is where I'm split. I can go the Super 35 route and get 4.56 gears front and rear. By the way what's the cheapest I can find this kit for?
Or I can go with buying a D44 housing from Jeepsareus.com.
Then I'd buy some alloy axle shafts detroit locker and the 4.56 gears. I have a friend who can install gears and in fact he's gonna teach me when I do this which is cool. I have thought 8.8 but I would rather have a factory D44 under the Jeep which is more bolt in.
And of course 4.56 gears for the D30 up front with new alloy axle seals.
Is there anything else I need to consider? I'm hoping to stay under 5000 for all of it if possible.
Khaki 2004 Wrangler X
OME HD Kit,JKS BMML,1.25 JKS BL, adj. control arms
RE Generation II Quick Discos
35x12.5x15 Goodyear MTR's w/ Kevlar, MT Classic II's
D44 rear axle w/ ARB, alloy shafts, 4.56 gears
Dana 30 with ARB, 4.56 gears, alloy shafts and ujoints
Lud04X is offline
post #2 of 8 Old 08-29-2006, 12:06 PM
Jakemd98
Choosy moms choose jeep.
Jakemd98's Avatar
sounds like fun... That's what i plan on eventually doing, the OME lift 33/12.50 bfg muds, D44, 4.10's (front/rear) tru-trac (front/rear)
You will be pushing your budgit a little, but if you can you might want to consider belly up skid and an SYE and CV.
Good luck
Jake Davis
97 Jeep Wrangler
4.0, 5 speed AX-15, D44 & Ford 8.8 w/Detroit - 4.88, NP-231, OME 2.5" coils w/1.25" spacers on front, 1.25" JKS BL, 35X12.50R15 KM2 on 15x8 Eagle alloys, Banks Header, Banks Monster Exhaust, Brown Dog MML, Rhino Liner, Tuffy Glove Box, AtoZ Rockers, Optima Red Top Battery.
1998 GMC Yukon
Jakemd98 is offline
post #3 of 8 Old 08-29-2006, 12:15 PM Thread Starter
Lud04X
I have a lot to do. I have the 3.07 gearing and D35 combo you do. Why oh why didn't I get a sport with the upgraded axle? Why do they sell Jeeps with 3.07 gearing in the first place? At least I got the 4.0 I6.
Lud04X is offline
post #4 of 8 Old 08-29-2006, 12:16 PM
Jakemd98
Jakemd98's Avatar
the 3.07 are not bad, unless you get bigger tires. My jeep does perty good going 70 down the hwy.
Jake Davis
97 Jeep Wrangler
1998 GMC Yukon
Jakemd98 is offline
post #5 of 8 Old 08-29-2006, 12:21 PM Thread Starter
Lud04X
Exactly, I have 31's now and 5th gear is useless already. haha
Lud04X is offline
post #6 of 8 Old 08-29-2006, 12:27 PM
McRoberts
2011 JK Wrangler
Id recommend the 44 over the Super 35. Spend the extra few bucks to build your Jeep right. I never built my 35 (when I had it) because Ive been told by a few different people (JP Mag guys, Buck's 4x4, etc) that putting money into a 35 is like polishing a turd. It doesnt matter what you do to it, it's still *****.
Just my two cents...
Being Green is the new Red.
McRoberts is offline
post #7 of 8 Old 08-29-2006, 05:44 PM Thread Starter
Lud04X
Are there other places to get a D44 housing? What about a rear D44 from a Rubicon, can I just build it up like a regular TJ Dana 44 and not use air lockers but a detroit instead??
Lud04X is offline
post #8 of 8 Old 08-29-2006, 06:22 PM
ytodd
ytodd's Avatar
I personally would never spend a dime on a D35.
ytodd is offline
1 ton TJ Buildup tweba99 TJ Wrangler Technical Forum 166 06-09-2009 02:37 PM
Help! Icy buildup on AC unit wbgordon TJ Wrangler Technical Forum 10 03-19-2009 01:37 AM
F8.8 Buildup for TJ Spectre66 TJ Wrangler Technical Forum 15 03-01-2007 11:29 AM
4.0L buildup help Midnight22 YJ Wrangler Technical Forum 5 11-29-2006 09:19 PM
My first TJ buildup - Need help! Trailmaster TJ Wrangler Technical Forum 8 03-16-2004 06:08 AM
