Building UCAs - Joint Questions - JeepForum.com
post #1 of 36 Old 11-30-2008, 05:35 PM Thread Starter
Dogman
Dogman's Avatar
I will be building a pair of adjustable UCAs soon. I'm going with a Johnny Joint on one and a rubber bushing on the other.
Here is my situation, right now I'm building these because I'm doing a belly up. However, I would like to reuse the joints when I build long arms in the future.
From what I can tell, the stock bushings are 2" wide. Since I'll be using the stock brackets for now, I need to use 2" joints.
Johnny Joints
Rubber bushings
Does this sound right? I would like to get 2.5" JJ, but I'm not sure if I could mod (bend) the brackets and make it work.
Also, does anyone know of good rubber bushings that come with a sleeve?
I'm looking for any input that you guys might have.
John 3:17
Dogman is offline
post #2 of 36 Old 11-30-2008, 05:42 PM
rubidriver
I think you got it down man as far as I can tell, I would like to watch this thread also.
2005 Black Rubicon - OME 933/942 - 4" Bilstein 5100 (canister up) - JKS Adj Track Bars Front/Rear - JKS Quicker Discos - 285/75/16
Originally Posted by bigj1974 View Post
your money will go farther in College Station.
rubidriver is offline
post #3 of 36 Old 11-30-2008, 05:42 PM
never monday
Johnny Joints
Rubber bushings
you are correct sir. 2.5 JJ's won't work without surgery
Look at the stock replacement bushings for the rubber.
never monday is offline
post #4 of 36 Old 11-30-2008, 05:45 PM
lj_wil
ekorb mi
lj_wil's Avatar
Why not use jj's all around?
W6FU
lj_wil is offline
post #5 of 36 Old 11-30-2008, 06:23 PM Thread Starter
Dogman
Dogman's Avatar
Cost is the only real reason.
EDIT: I see you're running a Clayton kit, I thought they used a rubber bushing at one end? Or is that just the lowers?
John 3:17
Dogman is offline
post #6 of 36 Old 11-30-2008, 06:26 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
That plus having that kind of joint at both ends makes for more shock and vibes being transmitted into the Jeep through the control arms. Having a rubber bushing at one end serves to isolate that out of the cab for rigs that aren't pure trail machines.
Jerry Bransford is online now
post #7 of 36 Old 11-30-2008, 06:34 PM
lj_wil
ekorb mi
lj_wil's Avatar
Somehow I think Jerry just answered both of our q's
W6FU
lj_wil is offline
post #8 of 36 Old 11-30-2008, 07:03 PM
timritchieblue
dont mean to jack the thread, but couldnt i cutoff one end of my skyjacker arms and weld a jj on the end?
FOR SALE:SOLD
2000 TJ 2.5" CLAYTON L.A. W/HYDROS, SYE/XJ SHAFT, 4:10 GEARS, 8.8 MINI SPOOLED, LOC-RIGHT FRONT, 1" BODY LIFT, 1" MML, 35" MAXXIS BIGHORNS, RE GEN 2DISCOs, BELLY UP, ALCOS IN FRONT, WARN X8000I
timritchieblue is offline
post #9 of 36 Old 12-01-2008, 10:18 AM Thread Starter
Dogman
Dogman's Avatar
I guess it depends on how your arms are constructed...but I'm sure you could.
John 3:17
Dogman is offline
post #10 of 36 Old 12-01-2008, 10:20 AM Thread Starter
Dogman
Dogman's Avatar
Does anyone know what size tube I need for the outer shell of the "RE small upper bushing"?
EDIT: I ended up going with these (free shipping): http://www.alljeep.com/oscommerce/pr...ucts_id=168722
John 3:17
Dogman is offline
post #11 of 36 Old 12-01-2008, 10:26 AM
bjpjeep
Wow this is funny. I just bent my stock UCA's and last night i was sitting at home thinking about just making my own using auto cad.
bjpjeep is offline
post #12 of 36 Old 12-17-2008, 11:37 AM Thread Starter
Dogman
Dogman's Avatar
http://www.ballisticfabrication.com/..._p_7-1402.html
This is more for my own reference, but here are some tube adapters that will work with the JJs I'm using. Size #4 to work with my 1.5" O.D. x .120" DOM.
John 3:17
Dogman is offline
post #13 of 36 Old 12-17-2008, 11:53 AM
timritchieblue
found this one too...http://www.polyperformance.com/shop/...p-1-c-728.html
FOR SALE:SOLD
post #14 of 36 Old 01-11-2009, 12:56 PM Thread Starter
Dogman
Dogman's Avatar
Just thought I would update this with some pictures and comments on my experience.
I went with the Ballistic tube adapters, very nice and beefy.
One note about the RE bushings and sleeves. Our initial attempts at pressing them into the sleeves failed. We placed a 1" plate on top of the bushing and tried to press them in. What we found was that if you press anywhere on the bushing itself, it expands and will not allow the bonded sleeve to "crush" down into the end ring.
Let me step back, the bushings are bonded to a sleeve. The sleeve has a flange on one side and then tapers down after about 3/8" to a smaller diameter. The end ring (the portion actually welded to the arm) has an ID the same size as the smaller diameter of the bushing sleeve. When you press the bushing into the end ring, it sort of crushes down and gives a really tight fit.
We ended up using another end ring on the bushing flange and it went in like butter (figured a 20 ton press was enough )
Here are some pictures before I cleaned up and painted.
John 3:17
Dogman is offline
post #15 of 36 Old 01-11-2009, 02:55 PM
rubidriver
So can you give us an idea of the cost on all of this?
Building a new rear suspension... What type of joint at the lower axle end? JeepRocks86 TJ Wrangler Technical Forum 3 12-16-2009 07:29 PM
Questions on Building Prerunner/Race Style TJ ScottyR TJ Wrangler Technical Forum 4 09-24-2009 12:14 PM
Questions / observations about building a TJ BEACHSAND TJ Wrangler Technical Forum 4 03-06-2009 05:24 AM
Building my 97 TJ: Multiple questions Katoom119 TJ Wrangler Technical Forum 10 02-01-2009 07:25 PM
Building a Dana 44 ang got questions Ratmeat YJ Wrangler Technical Forum 1 10-02-2008 11:06 AM
