Quantcast Building a new rear suspension... What type of joint at the lower axle end? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Building a new rear suspension... What type of joint at the lower axle end?
Old 12-16-2009, 11:16 AM   #1
JeepRocks86
Some Call me RockDog
JeepRocks86's Avatar
What type of joint would you all recommend to use at the axle end?
I was planning on going with poly end at the lower axle side, but would it be better or would there be a big benefit to having a flex joint instead?
The uppers are going to have a flex joint at either end with reversed threads so I don't have to remove upper arms to make adjustments.
vs
vs
On the Upper Control arms I am going to keep the 9/16 bolts, but for the lower rears I am going to use 5/8 for a little more added strength.
Stretched TJ Future, Coil overs, 40s, 60/14 bolt
My Build Thread.
www.kifourwheelers.com www.indyorv.com
For Sale:
TJ 44 Combo, 4.88s, detroit, Alloy USA shafts, Disc Brakes, HD lower mounts, Clayton tube Truss
35" procomp tires with Aluminum wheels $650
(4) 5x4.5 steel beadlocks $200
3 11"& 2 13" BBCS shocks
Ford Dana 60 Rear $150
Big Daddy Offroad HD tie Rod
(4) 15x8 5x4.5 TJ, YJ, XJ, etc bolt pattern Aluminum wheels $175
JeepRocks86 is offline   Reply With Quote
Old 12-16-2009, 11:25 AM   #2
Imped
TITS
Imped's Avatar
You're building arms and considering poly? Go joint or go home. Currie, Poly, RE, and Ballistic all make nice joints.
OlllllllO
Float Test Build
IndyORV
Best served cold
Imped is offline   Reply With Quote
Old 12-16-2009, 12:37 PM   #3
JeepRocks86
ok sounds good. The jeep is 90+% a trail toy that gets driven on the street rarely.
They will be made out of square tube though because I have been given a bunch for the lowers, but I would prefer DOM, but it's a lot more $$$
My Build Thread.
For Sale:
Old 12-16-2009, 08:29 PM   #4
JeepRocks86
Ordered over $400 worth of joints and tube inserts.
Selling my rear clayton arms should offset the cost
My Build Thread.
For Sale:
Glock Forum
