Budget TJ Lift Kit - JeepForum.com
post #1 of 7 Old 10-07-2011, 02:56 PM Thread Starter
rwilson93
Budget TJ Lift Kit
I am trying to put together a lift kit for my TJ. It is my daily driver but I want to put on 33's and do some moderate off roading. I am looking at the Old Man Emu 4" kit which seems to include everything I need but a steering stabilizer and control arms. Which control arms should I replace first? (I can't afford to do them all yet) Or if anyone has a completely different way to go please advise. I have about a $1400 budget.
rwilson93 is offline
post #2 of 7 Old 10-07-2011, 03:01 PM
biffgnar
biffgnar's Avatar
The word "budget" doesn't go well with 4" of suspension lift. If you want to fit 33s on a budget do a 2" BB and 1.25" BL.
To answer your question you'll need to do rear control arms first, as with 4" of lift to avoid driveline vibes you'll likely need to do a SYE/CV driveshaft replacement and then use the adjustable arms to orient the pinion.
Romney in 2020!
biffgnar is offline
post #3 of 7 Old 10-07-2011, 07:21 PM
Caribic-TJ
You forgot to fill out your profile...
08 JKU Rubicon
98 TJ fully locked
Caribic-TJ is offline
post #4 of 7 Old 10-07-2011, 07:58 PM
MayRoll
Does that include tires too?
First of the Breed
03 Khaki Rubi
JF short arm champ
MayRoll is offline
post #5 of 7 Old 10-07-2011, 10:26 PM Thread Starter
rwilson93
no, $1400 just for the lift.
post #6 of 7 Old 10-07-2011, 10:56 PM
mike721
look into rough country i got there n2.0 lift and love it
mike721 is offline
post #7 of 7 Old 10-07-2011, 11:54 PM
Boodyrider
2.5" Rough country lift, 1.25 body lift total under 400
Add SYE with driveshaft from Tom Woods - http://4xshaft.com/ for 525-650
Flat fenders from Tnt/Treks 625 or at the same price highline flat fenders and cut the hood
Total 1500 to 1600... And will rather nicely fit 33s OR 35s.
Add good control arms from Currie or the like, plate some control arm mounts, and you'll have a respectable offroad rig on a reasonable budget... at least until you decide to do a tummy tuck, longarms, and axles that will hold up to abuse with 35s.
IMHO... you need a regear even for 33s.
97 TJ Sport - 4.0/HP D30 w ARB/8.8 w LS/4.88s; 35s and flat fenders on 2.5 lift
84 CJ7; frame off restoration in progress.
The technical advice you get from me here is worth exactly what you paid me for it. Warranty issues will be reimbursed at double what you paid me for the advice.
Boodyrider is offline
budget , lift kit , recommendation , tj
Budget Boost and Body Lift vs. Suspension Lift Bayview471 TJ Wrangler Technical Forum 20 03-18-2011 05:49 PM
Finish my education on budget lift solutions, shackles and body lift for 31s 01TJfuntime YJ Wrangler Technical Forum 2 06-20-2009 07:32 PM
budget boosters vs. body lift with suspension lift zac87 TJ Wrangler Technical Forum 2 02-01-2009 02:54 PM
Budget Lift? RooRooTJ TJ Wrangler Technical Forum 8 05-03-2006 08:42 PM
Budget Lift hmmhoyhoy YJ Wrangler Technical Forum 1 07-27-2005 09:36 PM
