Budget lift the redneck way - JeepForum.com
post #1 of 12 Old 05-01-2007, 10:09 AM Thread Starter
wahooz04jeep
I know lots of people have mentioned the use of XJ springs or springs from a grand cherokee V8 for the front of a TJ to get about 3 inches of lift. I need some re affirming notes to know that this would not be a stupid thing to do. I would also be moving my front coils now to the rear and taking off all of my coil spacers that I bought. the idea seems a bit sturdier to me. Like I said Budget, I know it's not a true budget but it's cheaper than buying something with a brand name on it.
2007 Jeep Patriot Sport
OlllllllO
I wave
wahooz04jeep is offline
post #2 of 12 Old 05-01-2007, 10:37 AM
pendleton
Here is a write up for it. The only thing that I would stay away from is moving the front springs to the back. Check his post install notes on the bottom and see that his jeep sagged bad in the back.
http://www.4x4xplor.com/tj3inch.html
pendleton is offline
post #3 of 12 Old 05-01-2007, 10:41 AM Thread Starter
wahooz04jeep
So what would be a good spring to use in the rear? Just a full set of ZJ springs?
OlllllllO
I wave
post #4 of 12 Old 05-01-2007, 11:20 AM
pendleton
Hmm, I'm not sure how the rear ZJ springs would work in the rear of the TJ. You might just have to purchase 3" rear lift springs for a TJ. You could sell off your factory spring to help offset the cost.
post #5 of 12 Old 05-01-2007, 11:25 AM
badoosh27
badoosh27's Avatar
I have a full set of ZJ springs and am planning to put them on soon, I'll try the rear ZJ's in the back and let yall know what it does.
2001 Wrangler Sport 4.0, 5 speed, 30/35 axles, 3.73's, ZJ springs, 1"BB, 31" Futura M/Ts
badoosh27 is offline
post #6 of 12 Old 05-01-2007, 11:30 AM Thread Starter
wahooz04jeep
it would be greatly appreciated badoosh
OlllllllO
I wave
post #7 of 12 Old 05-02-2007, 01:23 PM
pendleton
I just remembered this thread, and thought you guys might like it...
http://www.dailydriventj.com/forum/viewtopic.php?t=228
This guy uses Crown Vic Springs in the rear for his lift. If I did this with my Ford 8.8 install, would I be driving a Jeep or a Ford?
post #8 of 12 Old 05-05-2007, 09:13 AM
badoosh27
badoosh27's Avatar
apparently the springs i got off of ebay were not from a V-8 ZJ, because i got about half an inch of lift out of the front ones. im going to install the rear ones and see what that does. what a rip
post #9 of 12 Old 05-05-2007, 10:11 AM
GzrGlide
GzrGlide's Avatar
Here's the thread that started it all........
http://www.jeepforum.com/forum/showt...ighlight=crown
As you read through it, you'll see that guys have found that crown vic springs fit better in the rear of the TJ. Personally I've done this lift as well but used the front TJ springs in the back. The only issue is that they have sagged somewhat. I've probably only got about 2 inches of lift left.
It's a decent idea and a cheap way to get 3 inches of lift in a 4 cylinder. 6 cylinder jeeps will get less lift.
It a good lift that works well. Especially if you're on a tight budget. Here's my write-up on it.
http://7slotgrille.com/tech/zjtjlift/index.html
Hope that helps.
Mike
<<< ya know ya want to!
98 TJ SE
RE 4.5SF with 3.5 springs & Tera QDFTs
Super 35 & Detroit in back w/4.88s
33x10.5 BFG KM2's
Cobra 75WXST w/4' Wilson Antenna
Warn M8000
(1) Rubber Ducky
GzrGlide is offline
post #10 of 12 Old 05-07-2007, 08:00 AM Thread Starter
wahooz04jeep
which crown vic springs would I want though? Just the front I would guess?
OlllllllO
I wave
post #11 of 12 Old 05-07-2007, 08:07 AM Thread Starter
wahooz04jeep
And I'm guessing there's no specific year I need either?
OlllllllO
I wave
post #12 of 12 Old 05-07-2007, 12:24 PM
GzrGlide
GzrGlide's Avatar
You'll have toread through the thread!
Mike
98 TJ SE
33x10.5 BFG KM2's
Warn M8000
(1) Rubber Ducky
GzrGlide is offline
Finish my education on budget lift solutions, shackles and body lift for 31s 01TJfuntime YJ Wrangler Technical Forum 2 06-20-2009 07:32 PM
Lift Kit for 35s on a budget 07rescuerubi JK Wrangler Technical Forum 22 02-20-2009 01:31 PM
budget boosters vs. body lift with suspension lift zac87 TJ Wrangler Technical Forum 2 02-01-2009 02:54 PM
Best budget lift for a tj jhunt87 TJ Wrangler Technical Forum 9 06-16-2008 12:03 AM
TJ lift on a budget caddyman TJ Wrangler Technical Forum 4 02-10-2008 11:37 AM
