Quantcast Budget Junkyard Upgrades - Page 6 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Budget Junkyard Upgrades
Poison Spyder February Special: FREE Rubber Liners when yoSlappin' on 61,510 Rigid Industries Lumens for Big RedRUBICON EXPRESS Lift Kits and Accessories Available at Bas
Old 03-19-2008, 10:44 AM   #76
MuDD OlllllllO
Originally Posted by GreenJip View Post
Any year Explorer with a front CV shaft will work, just make sure it has the 1310 U-Joints. I pulled mine off the doner vehicle when I did my 8.8 swap.
What year was the donor vehicle? That will help me narrow it down to the ones with the 1310 U-joints. Most people who are selling them have no idea what type of u-joints they have... thanks!
2004 TJ Sahara Dana 44 Black Dual Tops w/Tinted Windows
Full Traction 3" Lift w/ M-Force Monotube Shocks
Superwinch EPi9.0 w/ Viking Synthetic Trail Line
33" Goodyear Wrangler MT/Rs, Spidertrax 1.25" Wheel Spacers
Rubicon Rocker Guards, MasterFlow OBA
MuDD OlllllllO is offline   Reply With Quote
Old 03-19-2008, 10:24 PM   #77
FifteenCents
Originally Posted by ksp2002TJ View Post
I am either blind or too tired, but I didn't catch this. When taking the springs from the Crown Vic for the 3" lift, do you want the fronts from the CV for the rear on the TJ? or do you use all the springs from the CV in the same positions on your TJ?
You need the front springs and the rubber isolators from a V8 Grand Cherokee
and the rear springs from a Crown Victoria. I have a complete write up on what I did
here.
http://www.jeepforum.com/forum/f9/cheap-3-5-inches-lift-276664/
FifteenCents is offline   Reply With Quote
Old 03-19-2008, 11:42 PM   #78
bebout
still nothing on track bars?
bebout is offline   Reply With Quote
Old 03-30-2008, 11:47 PM   #79
RUBtjICON
Originally Posted by WillysEdition04 View Post
ZJ front springs installed on front TJ provide 3" lift. TJ front springs moved to TJ rear will lift rear to level out the Jeep.
What's the advantages of the Durango stearing box swap?
Also: What years Durango are compatible with what years TJ?
So If I run coils from the front of a '95 V8 ZJ, and a 2" BB in the back, will that get me sitting level, insteads of nose down ?
2004 TJ Rubicon........My build thread, My URE Vid
www.vanc4x4.net
All Who Drive Jeeps Are Not Jeepers - Willy 3:16
RUBtjICON is offline   Reply With Quote
Old 03-31-2008, 10:01 AM   #80
FifteenCents
That sounds like it might work...
give it a go and let us know how it works.
Old 04-05-2008, 07:58 PM   #81
Guardian7
Bullet Proof Tie Rod Sleeve for $8 using a piece of pipe from Home Depot or Lowe's.
Many of my Club Members are running this mod which is cheap and easy to do. This mod will bullet proof one of the weakest parts found on a Jeep, the "Tie-Rod" and will increase the strength 100 times over stock. I have rammed huge boulders since installing mine and it literally bounced off the rocks with no damage. You can add the sleeve before or after your stock rod gets bent but most people add the sleeve after they damage their factory tie-rod as a repair by bending the rod straight enough to slide a piece of DOM tubing over it. Simply pop the end joint off the drivers side steering knuckle, it helps to have tie-rod puller, (Harbor Freight) mark the threads on the end joint before unscrewing it, loosen the sleeve clamp, apply some WD40 to the end joint threads and unscrew it. Slide your new Super Sleeve on, install clamp and end joint, re-attach to steering knuckle and re-check the Toe-in for 1/8" toe with front wheels off the ground. If the factory rod is still straight the sleeve may rattle just a bit so to cure this we drill a couple holes about 4-6" from each end and inject some RTV into the space between the tubes curing any rattles. (Specs on the tubing for TJ are as follows: Approx Length=32.5" OD=1.25" Wall=.120" pipe. DOM tubing is nice but not necessary) The trail repair shown below was done by my friend Doug on a 2005 Rubicon which was blocking the John Bull Trail.
Wimpy Stock Tie-rod After Hitting Rock
Bullet Proof Tie-rod After Sleeve Install
The Proof: Here you see me slamming into a boulder on Holcomb with my Bullet Proof Tie-rod Sleeve and zero damage, no I did not plan to hit the rock but I am still amazed!
Thanks to my friend Doug for this mod
Guardian7 is offline   Reply With Quote
Old 04-05-2008, 08:02 PM   #82
willhbauto
Originally Posted by Guardian7 View Post
Bullet proof Tie Rod Sleeve for $8 piece of pipe at Home Depot or Lowe's.
Many of my Club Members are running this mod which is cheap and easy to do. This mod will bullet proof one of the weakest parts found on a Jeep, the "Tie-Rod" and will increase the strength 100 times over stock. I have rammed huge boulders since installing mine and it literally bounced off the rocks with no damage. You can add the sleeve before or after your stock rod gets bent but most people add the sleeve after they damage their factory tie-rod as a repair by bending the rod straight enough to slide a piece of DOM tubing over it. Simply pop the end joint off the drivers side steering knuckle, it helps to have tie-rod puller, (Harbor Freight) mark the threads on the end joint before unscrewing it, loosen the sleeve clamp, apply some WD40 to the end joint threads and unscrew it. Slide your new Super Sleeve on, install clamp and end joint, re-attach to steering knuckle and re-check the Toe-in for 1/8" toe with front wheels off the ground. If the factory rod is still straight the sleeve may rattle just a bit so to cure this we drill a couple holes about 4-6" from each end and inject some RTV into the space between the tubes curing any rattles. (Specs on the tubing for TJ are as follows: Approx Length=32.5" OD=1.25" Wall=.120" pipe. DOM tubing is nice but not necessary) The trail repair shown below was done by Doug on a 2005 Rubicon which was blocking the John Bull trail.
Awesome, I've been wanting to upgrade my steering, maybe I'll do this as temporary fix so I don't bend mine up. How long of a piece to I buy? The whole length of the tie rod?
[B][U]2001 Wrangler TJ Sport 5-Speed[/U][/B]
Dana 44 Rear, 3.73 Gears, 4" ProComp Lift w/ Daystar 1 3/4" Spacer in front, Skyjacker Hydro 7000 Shocks, JKS Quicker Disconnects, 33"x12.50" Pro Comp Xtreme M/T, R.C. Adj. Front Track Bar, RR 1/4" CA Mounts, Front Aussie Locker, Front/Rear Riddlers, EBC Yellowstuff brake pads, Rokmen Power Steering Skid, Rusty's Radiator Skid, Rokmen Mercenary Front Bumper, Rokmen Mercenary Rocker Guards, Warn Engine/Oil Pan Skid, Tuff Designs Rear Tire Carrier/Bumper, Warn M8000 Winch, IPF H4 Headlight conversion w/ IPF Fatboy X55 bulbs
[U]Waiting to be installed:[/U]
*Rusty's Steering Box Support Brace
willhbauto is offline   Reply With Quote
Old 04-05-2008, 09:16 PM   #83
GreenJip
Mine came from a 98.
/l ,[____],
l---L -OlllllllO-
()_)-()_)-o-)_)
8.8 Swap: http://www.jeepforum.com/forum/f9/8-8-swap-into-tj-build-thread-501704/
GreenJip is offline   Reply With Quote
Old 04-06-2008, 12:02 AM   #84
benjamin.olejnik
Okay, I'm a nube to jeeps and lifts in general, are these Crown Vic springs a true 3" life option? Do the shocks need to be upgraded? What about the drive shaft, steering linkage (if going with the front)? Sorry for my ignorance, college degrees do not translate into mechanical experience very well!
benjamin.olejnik is offline   Reply With Quote
Old 05-27-2008, 04:15 PM   #85
HellGoneWild
subscribe is good!
2000 Wrangler SE:
Old Cobra 19 CB
31x10.5 MTZ on 15" Procomp steelies
Cotter pin disco'd
So there I was with a JEEP fund, and then the baby ate it all!
HellGoneWild is offline   Reply With Quote
Old 05-28-2008, 12:44 AM   #86
MuDD OlllllllO
Thanks for the idea!!!
I got a front driveshaft from a 93 Cherokee for $40.
Then I ordered this kit for $65:
http://broncograveyard.com/bronco/i-12462_dana_spicer_driveshaft_repair_kit__dana_spic er.htm
and also this:
http://broncograveyard.com/bronco/i-32485B_cv_ball_dust_shield_1990-96_bronco.htm
*note: you might have to file the inside down a bit to get it the new dust cover to fit, depending on what driveshaft you get, but it is millimeters.
Then I rebuilt the driveshaft. When you are getting grease, be sure to pick one of these up:
http://www.autozone.com/in_our_stores/loan_a_tool/steering_suspension/ball_joint_press.htm
It makes the job WAY easier.
Going to have it shortened by a local shop next week after the SYE intall this weekend should be about $70. That will make the total be $179 for an effectively new CV driveshaft. Oh yeah, and don't forget the flat black rustoleum. I will post some pics later
Old 05-28-2008, 09:38 AM   #87
FifteenCents
When using the parts from other vehicles is sometimes called a franken lift.
The grand cherokee front spring and ford Crown Vic rear spring lift it is not
a "KIT" in a kit you get everything that has been engineered to work
together.
What I did and what people are talking about is a "MOD" modification if you will.
It took a lot of tweeking and adjusting to get something that worked
I could not afford to buy a "lift kit" so I used what was available.
If you do not have the resources or the mechanical ability it is best to buy a "KIT".
here is the wrwite up on what I did to get 3.5 inches of lift.
http://http://www.tjhardcore.com/forum/viewtopic.php?t=603&highlight=
The above post is my opinion and I have no facts to prove it... :)~
The ultimate TJ owners only forum
Old 05-28-2008, 10:00 AM   #88
Si1ver03Rubicon
So do you have to run the ZJ spring isolators? Or can you run just the spring for a smaller lift? I've got a 2.25" BB and its got a sag in the front.
[b]03 Rubicon 5SPD, 2.5 RC Lift, Skid Row EngineTrans Skid, MG LCA Skids, Rancho Xtreme LCAs, & JKS Discos.
---->[url=http://www.jeepforum.com/forum/showthread.php?p=6641775#post6641775]SOLD 03-06 Skid RowEngine/Trans Skids SOLD!!![/url] <----[/b]
Si1ver03Rubicon is offline   Reply With Quote
Old 05-28-2008, 12:13 PM   #89
slate210
Awesome thread. Any words of wisdom on the ZJ rear disc brake swap? I've got the calipers, pads, and rotors. Just trying to find a nice set of backing plates.
2000 TJ 4.0 5-SP 115k mi. Patriot Blue - Bone stock...for now.
1997 TJ 4.0 5-SP 134k mi. Red Jeep Club Member #450 - Some mods...
NJJA - New Jersey Jeep Association
2006 VW Jetta TDI DSG 54k mi. BLACK Rocketchipped, boostvalve, boost gauge.
slate210 is offline   Reply With Quote
Old 05-28-2008, 12:50 PM   #90
FifteenCents
No you do not have to use the isolators, but you will not gain much.
The V8 ZJ springs with one stock spacer will net you 3 inches of lift and will
level your TJ (remove the front lower than the back rake). Not really
worth the effort in my opnion. Running without any isolators will make your
jeep sound a little rough on the road, road noise will travel through the axle to the frame though the springs.
If you put the crown vic springs in the back without any spacers you will get
3.5 inches of lift. The rear upper spring perch has a rubber washer so the
sound is muffled there.
Glock Forum
