Quantcast Budget Junkyard Upgrades - Page 30 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Budget Junkyard Upgrades
Front and rear Drive shafts @ free shippingPoison Spyder February Special: FREE Rubber Liners when yoSlappin' on 61,510 Rigid Industries Lumens for Big Red
Old 01-20-2010, 03:15 PM   #436
saltydawg1845
one of the guys at work has one and he is doing all sorts of upgrades to it. he threw that intake away soo I grabbed it up
saltydawg1845 is offline   Reply With Quote
Old 02-15-2010, 11:49 AM   #437
ex m38a1er
Originally Posted by Guardian7 View Post
Here is the current list from what I read on the thread, I may have missed a few;
ZJ V8 Tie Rod (huge improvement)
XJ complete High Pinion front axle.
ZJ Front Coil Spring Clamps (Locks bottom of coil in place)
ZJ, XJ, or TJ front driveshaft to build a rear CV driveshaft.
ZJ front coils with isolators from a V8 will lift the front about 3"
Crown Vic rear springs will lift the rear about 3.5"
ZJ Disk Brake Assemblies D35 and D44 (huge improvement).
ZJ or XJ stock pitman arm = 4" drop pitman arm for TJ.
98-99 Durango Steering Gearbox (larger gears & piston bore, quicker steering radius)
Chevy Astro steering box (for those who want to tap for hydro assist)
136 Amp Alternator from 97-98 ZJ, Dakota, Durango, or Ram (OEM PN:56027913)
AMC or old school Ford York Air Compressors.
Perfectly balanced tires with 1000 20gram air soft pellets in each tire.
8.8 Ford Explorers 95-01 with disk brakes, easy upgrade for YJ's.
Transmission and Power Steering Coolers off many vehicles.
Various E-Fan upgrades.
That's what i need !!!
ex m38a1er is online now   Reply With Quote
Old 02-15-2010, 11:07 PM   #438
4x4grey88
ROCK WHEELER
4x4grey88's Avatar
I went to the junkyard and got me one of those lighted rear view mirrors and installed it. Great map reading and increased lighting when I open my doors.
___________________________________________
In or Near San Diego, CA? Click Here
Black Jeep Club Member #1016
Senior Member: Jeep Repair Club, San Diego Chapter
4x4grey88 is offline   Reply With Quote
Old 02-15-2010, 11:56 PM   #439
BeerMe
Originally Posted by saltydawg1845 View Post
I got this intake off a subaru sti and it fits like a glove... well with a lil bit of persuasion
What about the breather tube? You can rig a filter to it, but I wouldn't leave it open like that.
BeerMe is offline   Reply With Quote
Old 02-16-2010, 10:40 PM   #440
jwb4786
Originally Posted by NeoAnderson View Post
I'm surprised no one has mentioned bolting in Grand Cherokee(ZJ) seats into a TJ.MUCH more comfy.
WJ seats work as well.
No mods when you use the factory TJ brackets.
Less than 15 minutes to unbolt and bolt in.
Don't ask me bout making the power up/down/back/forth stuff work cuz i ain't figured it out yet.Ya gotta use the ZJ seat sliders to make that stuff functional.
Look at my cardomain page 2 for pics of mine.
Does anyone have any more info about moving ZJ seats into a TJ? I found a few sets of really nice seats at my local yard. If I use the factory TJ brackets I can move the seat back and forth, but I am concerned about not being able to lean the seat back and forth because that is operated by power. Any help would be much appreciated!
jwb4786 is offline   Reply With Quote
Old 03-02-2010, 03:40 AM   #441
Miltoncouple
Found a Isuzu rear dana 44 going to match it with a waggy front and do a soa with yj leafs for about a grand plus the regear and drive shafts although i found out how im going to do those cheap from this link.
long live leafs
Miltoncouple is offline   Reply With Quote
Old 03-02-2010, 03:49 AM   #442
jeep2008
This, in my book, is called a HOT air intake...
my build thread
04TJ (SOLD)
01TJ (BUILDING)
jeep2008 is offline   Reply With Quote
Old 03-06-2010, 10:12 PM   #443
FF151DJG
you are asking about the need for the durango upgrade. i had 35's on my jeep and upgraded to the durango box and wow could i tell a difference on the ease of my steering. it was well worth the time and money spent
FF151DJG is offline   Reply With Quote
Old 04-23-2010, 10:46 PM   #444
1jack5
long live leafs
Take those leafs to the YJ section Haha just kidding man.
1jack5 is offline   Reply With Quote
Old 04-23-2010, 11:18 PM   #445
jeepnkal
subscribed
jeepnkal is offline   Reply With Quote
Old 04-23-2010, 11:20 PM   #446
MattTheMudder
Ask Mr. Owl
MattTheMudder's Avatar
I was just talking about this today and actually chimed in to mention it. Any more info on it? I've yet to actually go look for one.
-Matt
Me fail English? That's unpossible
MattTheMudder is offline   Reply With Quote
Old 04-29-2010, 08:30 PM   #447
Jeeperator
Didn't see this method listed on here so I thought I add it. How about a v8 zj tierod over the knuckle on a dana 30 hp. You have to drill your driverside knuckle and purchase and weld in a insert Goferit Products! . The only thing is you have to flip the tierod over also so the adjustment sleeve it on the draglink side. The nice thing is you dont have to relocate the swaybar brackets. The fliped zj tierod has factory bends that clear everything almost perfect. I did notice very little rubbing one the trackbar mount with the sleeve clamp but it was mostly paint transfer. Putting a washer under the limit stop would most likely fix this if your concerned though. I am in process of trying this with a Currie draglink setup and save $100 on a complete currectlink kit.
Jeeperator is offline   Reply With Quote
Old 08-20-2010, 01:25 PM   #448
hoponhopper
Originally Posted by WillysEdition04 View Post
ZJ front springs installed on front TJ provide 3" lift. TJ front springs moved to TJ rear will lift rear to level out the Jeep.
What's the advantages of the Durango stearing box swap?
Also: What years Durango are compatible with what years TJ?
So the front springs on a TJ will lift the rear 3"?
hoponhopper is offline   Reply With Quote
Old 08-21-2010, 10:11 AM   #449
Patton
Yes if not 4" but the spring isn't as secure as I would feel comfortable with.
06 TJ X 4spd auto 3.73
4" pieced together lift
Patton is offline   Reply With Quote
Old 09-16-2010, 01:45 PM   #450
Disconnect
Wandering Techie
Disconnect's Avatar
Anyone manage to get the power fun (& heaters) working on the grand cherokee seats? I'm wondering how smart the BCM is, maybe it could be installed isolated and used solely for the seat controls.. (it seems to be entirely environmental/fluff controls - interior lights, etc. So maybe..maybe..)
Disconnect is offline   Reply With Quote
Glock Forum
jeeppartsdept.com
Get your jeep parts here. Full line Jeep dealer. HUGE DISCOUNTS!
