Quantcast Budget Junkyard Upgrades - Page 3 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Budget Junkyard Upgrades
RUBICON EXPRESS Lift Kits and Accessories Available at BasTruck-Lite's New LED Headlamp SeriesIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Old 02-19-2008, 08:42 PM   #31
04TJ Dogg
OME 934's which I looked up as ZJ 1" lift for the front.
2004 Tj X, 2.5 Skyjacker rear, OME ZJ front, 285/75 16 A/T's on moabs, Bedlined stuff, some offroad Lights, Warn 8274 w/ Warn plate, Aussie front, Truetrack rear, PSC trail corners, Pro-comp adjustable front trackbar, 1 1/8" skateboard wheel bl, Teraflex bmml
04TJ Dogg is offline   Reply With Quote
Old 02-19-2008, 09:40 PM   #32
Bottledbird68
Subscribing
96 ZJ 3.5" pro-comp on 33" MT/R's with black steelies
The family wheeling wagon. (Broken, but about to be better ;D) Edit, gave up and sold it lol. Concentrating on the TJ now :D
99 TJ Sport Her ride. 2" BB w/ 32" bfg MT's on black steelies
Bottledbird68 is offline   Reply With Quote
Old 02-19-2008, 09:54 PM   #33
ExpeditionXJ
Originally Posted by Hot Sauce View Post
ZJ rear coils have a 4.02" inner diameter
TJ rear coils have a 5.05" inner diameter
I believe ZJ rears are only pig-tailed at one end as well. TJs are at both ends.
Also not sure they'd give the right amount of lift anyway, so probably not worth the time to try and make them work.
Thanks for those diameters, where did you find them? Looking at the RE catalog the ZJ rear coils are pigtailed at both ends as well.
ExpeditionXJ is offline   Reply With Quote
Old 02-19-2008, 09:56 PM   #34
ExpeditionXJ
Originally Posted by cj847 View Post
-ZJ or XJ stock pitman arm = 4" drop pitman arm for TJ
I'll think of more later.....
The ZJ pitman arm is a 3/4" drop on an XJ.
Old 02-19-2008, 10:01 PM   #35
ExpeditionXJ
Originally Posted by badoosh27 View Post
I have ZJ springs front and back and mine is level, so i would try that if you can before spending money on other springs...
So you have ZJ V8 front and rear coils on your TJ for roughly 3" lift?
On the ZJ tierod... all V8 has the larger. I got the inner tierod and coupler at my local AutoZone, had to go elsewhere for the outter tierod as their computer lists a 6CYL outer for a V8. Cost was about $110 total.
Old 02-19-2008, 10:37 PM   #36
cvd
cvd's Avatar
Originally Posted by GreenJip View Post
I pulled a CV shaft out of a ford explorer and had it shortend to the correct length. Total cost $130 after replacing the u-joints.
Was anything required other than shortening it and new u-joints? I take it the splines match? I'm thinking of doing this, instead of a full SYE/CV, to eliminate slight vibes with my small lift.
cvd is offline   Reply With Quote
Old 02-19-2008, 10:37 PM   #37
hecubus
1997 XJ Cherokee
isn't there a dirt-cheap alternator upgrade? Why yes: http://www.bc4x4.com/tech/2004/jeepalt/
Has anyone done this? Also, is there a rebuild kit (bushings etc) you an buy to 'refresh' the bone-yard alt before installing?
"eh, it's the bank's jeep anyway..."
hecubus is offline   Reply With Quote
Old 02-19-2008, 11:32 PM   #38
GreenJip
I used this set up in the rear for my 8.8 I had to get a flange apapter. If you are just putting it on a dana 35 or 44, you don't need anything else for the shaft. However, this shaft will not work without an SYE.
/l ,[____],
l---L -OlllllllO-
()_)-()_)-o-)_)
8.8 Swap: http://www.jeepforum.com/forum/f9/8-8-swap-into-tj-build-thread-501704/
GreenJip is offline   Reply With Quote
Old 02-19-2008, 11:52 PM   #39
badoosh27
yeah, its more like 2.5 or so. But yeah, it works
2001 Wrangler Sport 4.0, 5 speed, 30/35 axles, 3.73's, ZJ springs, 1"BB, 31" Futura M/Ts
[url]http://www.cardomain.com/ride/2634280[/url]
badoosh27 is offline   Reply With Quote
Old 02-20-2008, 03:07 AM   #40
emschris
Oops, sounds expensive!
emschris's Avatar
If memory serves, the OME ZJ (and other) springs come in light, medium, and heavy duty. If you don't have the heavy duty one's, this could be contributing to the problem with the winch on the front. I believe the difference is in the diameter of the spring, but not really sure. I'll see what I can find.
Have you taken any measurements to see how far your off.
(81 CJ, 92 YJ, 97 TJ, All Gone) 05 TJ Rubicon
Stupity Kills, but not nearly enough.
emschris is offline   Reply With Quote
Old 02-20-2008, 03:08 AM   #41
MattTheMudder
Ask Mr. Owl
MattTheMudder's Avatar
Try these -
Ford Taurus electric fan
York air compressor
HPD30 (haven't done it, but it's cheap)
Durango steering box if you need it
Homemade snorkel (Hummer style)
-Matt
Me fail English? That's unpossible
MattTheMudder is offline   Reply With Quote
Old 02-20-2008, 06:42 AM   #42
MuDD OlllllllO
That is awesome. What year ford explorer did you pull it from?
2004 TJ Sahara Dana 44 Black Dual Tops w/Tinted Windows
Full Traction 3" Lift w/ M-Force Monotube Shocks
Superwinch EPi9.0 w/ Viking Synthetic Trail Line
33" Goodyear Wrangler MT/Rs, Spidertrax 1.25" Wheel Spacers
Rubicon Rocker Guards, MasterFlow OBA
MuDD OlllllllO is offline   Reply With Quote
Old 02-20-2008, 07:54 AM   #43
bigV
what year ZJ tie rods work?
http://www.stu-offroad.com/steering/zjtie/tierod-1.htm
www.hd4w.org
bigV is offline   Reply With Quote
Old 02-20-2008, 08:04 AM   #44
MeltdWhiskey
what's the advantage of the durango steering box?
MeltdWhiskey is offline   Reply With Quote
Old 02-20-2008, 08:39 AM   #45
moparjunkee
Is the axle side u-joint the same from the explorer front to the jeep rear?
Also what is the advantage of durango steering box.
No matter how far you go, there you are.
moparjunkee is offline   Reply With Quote
Glock Forum
