Quantcast Budget Junkyard Upgrades - Page 26 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Budget Junkyard Upgrades
Front and rear Drive shafts @ free shippingPoison Spyder February Special: FREE Rubber Liners when yoSlappin' on 61,510 Rigid Industries Lumens for Big Red
Old 10-14-2009, 11:03 AM   #376
rudyyj
Originally Posted by Guardian7 View Post
Here is the current list from what I read on the thread, I may have missed a few;
ZJ V8 Tie Rod (huge improvement)
XJ complete High Pinion front axle.
ZJ Front Coil Spring Clamps (Locks bottom of coil in place)
ZJ, XJ, or TJ front driveshaft to build a rear CV driveshaft.
ZJ front coils with isolators from a V8 will lift the front about 3"
Crown Vic rear springs will lift the rear about 3.5"
ZJ Disk Brake Assemblies D35 and D44 (huge improvement).
ZJ or XJ stock pitman arm = 4" drop pitman arm for TJ.
98-99 Durango Steering Gearbox (larger gears & piston bore, quicker steering radius)
Chevy Astro steering box (for those who want to tap for hydro assist)
136 Amp Alternator from 97-98 ZJ, Dakota, Durango, or Ram (OEM PN:56027913)
AMC or old school Ford York Air Compressors.
Perfectly balanced tires with 1000 20gram air soft pellets in each tire.
8.8 Ford Explorers 95-01 with disk brakes, easy upgrade for YJ's.
Transmission and Power Steering Coolers off many vehicles.
Various E-Fan upgrades.
I am a junk yard whore...all the ones in red above i have done!!!!
scott
97tj
rudyyj is offline   Reply With Quote
Old 10-14-2009, 12:27 PM   #377
PhillyPyro
There are plenty of rear upgrades to pull from this or that, but I have yet to read anything about what to do w the D30 up front. I dont want to spend regear money on that D30. I am already workin on the 8.8 for the rear, but what if any can i swap into the front?
PhillyPyro is offline   Reply With Quote
Old 10-14-2009, 12:33 PM   #378
Sobie
Bolt-on Maniac
Sobie's Avatar
An HP D30 out of an XJ.
My Golden Eagle Build
USAF
Sobie is offline   Reply With Quote
Old 10-14-2009, 12:35 PM   #379
Patton
If you are going to stick with 33's than it will be fine. You can beef up a 30. Even a Rubicon dana 44 for the front isn't much of an improvement. An older Dana 44 would be better but they will all be different bolt patterns.
06 TJ X 4spd auto 3.73
4" pieced together lift
Patton is offline   Reply With Quote
Old 10-14-2009, 12:59 PM   #380
PhillyPyro
I kind of gave up on tryin to locate a D44 at a fair price. I do not plan on going over 33s I like to DD my jeep and I am verry happy with the 4" and 33s. any more may be too much for me. Im just breaking stock stuff now and replacing with nice new diesel a$$ parts. I dont want to break anything I just put money into, thats y i ask about the D30. sounds good tho.
What is the difference in the D30 i HAVE AND THE hp D30 from an XJ? is this a straight bolt in or does it get as involved as the 8.8 swap? is there a speciffic year spread that will work?
Old 10-14-2009, 01:39 PM   #381
N8Doggz
Is this still ok to buy? whats the difference between a box and a rack:
1999
Steering Rack/Box
Dodge DurangoTHIS IS A STEERING BOX NOT RACK
Can i use the stock nuts and bolts??
N8Doggz is offline   Reply With Quote
Old 10-14-2009, 01:47 PM   #382
PhillyPyro
yes but I recomend replacing the 2 hoses. They dont tend to come off easy.
Old 10-14-2009, 01:47 PM   #383
N8Doggz
help with alternator
Originally Posted by joeyprice View Post
Fill in your profile so we know what we're dealing with as far as the Jeep goes. If you have a post 03 TJ with the 4.0 a 160 amp alternator out of a late model Durango with a 4.7 V8 should bolt straight in (it did in my 2005 at any rate) - you should be able to verify with a visual inspection.
What year durango? I found a 2004-06 with 4.7/160 amp. This will just bolt right in my '06 sport?
Old 10-14-2009, 09:38 PM   #384
Guardian7
The 98-99 Durango steering box is supposed to bolt right up from what I've read on various forums it just has internal improvements. A rack usually means Rack and Pinion which is completely different and would require some serious mods. I also own a 2006 Wrangler 4.0, thanks for the Alternator tip N8Doggz I will look for one this weekend at the Salvage yard. The front Dana 30 gets bent easily so if your planning on keeping the D30 you could truss the passenger side from the diff to avoid the smiley sydrome.
Guardian7 is offline   Reply With Quote
Old 10-15-2009, 04:59 AM   #385
rikkards
It isn't just internal difference, the whole cylinder it is housed in is larger. It still bolts up no problem.
Mine was off a 99
On my deathbed, my final wish is to have my ex-wives rush to my side so I can use my dying breath to tell them both to go to hell one last time. - Ron Swanson
rikkards is offline   Reply With Quote
Old 10-15-2009, 06:34 PM   #386
N8Doggz
No problem!!! There was a sight given here that automatically seaches junkyards in your area. I think it was car-parts.com or something. Its in this thread. I found a 160 alternator for $100with 15k on it. Way better than paying about $400 for a MEAN GREEN!!!
Old 10-15-2009, 06:49 PM   #387
N8Doggz
Will let you know if i run into any probs but as far as i gathered is it bolts right on.
Midnight Blue '06 TJ//Dana 44 w/4.56/4" Teraflex w/shrt adj arms, 1" teraflex BL, discos, adj trackbar F+R/SYE, Tom Woods shafts/ARB lockers F+R/Yukon frnt axle w/760/ARB Hi output compressor/ Safari Snorkel/KC 6"+8" trails+fogs lights/Procomp Rockcrawlers/35" BFG MT KM2/Warn winch/steering box, oil pan, trans, bellyup,warn diff skids/diamond plate body armor/Olympic Rocker Guards/Herculined/CB/Amsoil all the way around, and a few more things
/l ,[____],
l---L-OlllllllO-
(_) ) ()_)-o-)_)
Old 10-16-2009, 08:39 AM   #388
PoopFaceKillah
did the 98 GC 136amp alt upgrade a few days ago. Went smooth as silk. i swapped the pulleys and the plastic piece. Also upgraded the charging cabling to 6 ga to accomodate larger throughput of amps.
(alternator from a 98 - ? grand cher with the 5.2 v8. its 136 amp)
97 TJ
No longer with me: 99 XJ, 74 CJ5, 94 YJ
PoopFaceKillah is offline   Reply With Quote
Old 10-16-2009, 08:46 AM   #389
PhillyPyro
The Durango steering box swap is a dirrect bolt up. its twice the size as the stock TJ box but the bolt holes and the hoses are identical.
Old 10-16-2009, 08:54 AM   #390
rudyyj
not twice the size...that would be HUGE
The cap on the YJ/TJ/XJ is 3" The Durango is 3.5". measure the diameter of the cap on the front of the box( the actual cap size, the casting will be larger) The complete box diameter will bigger but I dont have the measurement.
scott
97TJ
Glock Forum
