Quantcast Budget Junkyard Upgrades - Page 24 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Budget Junkyard Upgrades
Front and rear Drive shafts @ free shippingPoison Spyder February Special: FREE Rubber Liners when yoSlappin' on 61,510 Rigid Industries Lumens for Big Red
Old 08-24-2009, 09:04 AM   #346
JOXJ87
Just seen this since it was brought to the top. I read thru and didnt see the Rodeo/Passport D44 on there. They have 6 lug but can easily be redrilled to 5 and can come with 4.56 gears!! i have one i got for free laying at my folks.
Cole
JOXJ87 is offline   Reply With Quote
Old 08-24-2009, 10:38 AM   #347
Mini-Me26
Originally Posted by nunnyabinus View Post
i have a stock set up except for some RC 2-4in hydro shocks and I just came across some RE 3.5in coils. If I go from stock to 3.5in do you guys know what else I might need? Like trac bar relocation brackets, pitman arm, or t-case drop? Shouldn't need SYE or CV shaft b/c its under 4inches right?
You'll need to relocate your track bar mount or install an adjustable track bar. The '4" for SYE' rule isn't a clear cut and established rule. You won't be fine with 3.5" but then suddenly have vibes at 4". Every Jeep is different. Drive it after the lift and if you feel vibes drop the T-Case until you can splurge on the SYE/CV.
Mini-Me26 is offline   Reply With Quote
Old 08-24-2009, 10:42 AM   #348
sshrrt
sshrrt's Avatar
thanks for explaining that to me newbie here!
when your happy as a bird with a french fry, you are having a good day...
sshrrt is offline   Reply With Quote
Old 08-29-2009, 11:00 PM   #349
Madmanmiller802
Off road lights, Work truck Bumpers, Spare tires... Junkyards are great
Madmanmiller802 is offline   Reply With Quote
Old 08-29-2009, 11:28 PM   #350
jaysway12
will a 93 mitsubishi diamante a/c compresser fit on a 97 jeep wrangler
jaysway12 is offline   Reply With Quote
Old 08-30-2009, 02:19 PM   #351
timinfla2
Thank you for all the great ideas - Will definitely look forward to trying them soon!
timinfla2 is offline   Reply With Quote
Old 08-31-2009, 11:51 PM   #352
07wurubi
07wurubi's Avatar
Just picked up an explorer front driveshaft myself after reading this. Got it for $30 and it was already pulled from vehicle.
Now just need to order a SYE kit and get the shaft fixed up. Great info in here to help save a few $$$ for sure.
Is it possible to make this thread a sticky at the top or whatever it is called. Sure would make finding it easy. I know the search function works for that. Just an idea for us nubes.
Mike Fox
My Jeep:
00 Wrangler Sport
4" RC LA full suspension system
axles (30,8.8) with 4.88 gears ARB F/R
SYE and CV rear driveshaft
Currie HD steering (Thanks Savvy, Awesome customer service)
GY MT/R Kevlar 35x12.50x15 on 15x10 American Racing AR23
Smitty front and rear bumpers w/rear tire carrier
Smitty XRC8 winch w/synthetic rope
Bestop soft top with tinted windows
Smittybilt rear corners and 3" flares, rock sliders with step and 3" front tube fenders
Wife's Jeep:
07 Wrangler Unlimited Rubicon 4dr Red Rock Crystal
3" lift with MX-6 adj shocks. Stock other than that.
07wurubi is offline   Reply With Quote
Old 09-02-2009, 02:10 PM   #353
AustinTexasXJ
how hard is a durango steering box swap?
>Dirty Betty 01 XJ< Wrecked.
>Blue Lucy 97 TJ< Sold.
>STACY 99 WJ<Weekend Warrior.
>Austin Cityprofile.< Check it out.
ΜΟΛΩΝ ΛΑΒΕ!
Xbox live Gamer Tag : BMW Alive 01XJ
Former Nightcrew member #266(RIP 01/28/09 - 07/22/09) www.nightcrew.org
JFI member #2
Originally Posted by SplitNail View Post
...The 4.slow sounds like a pissed off butterfly. just my 2 cents. :)
AustinTexasXJ is offline   Reply With Quote
Old 09-02-2009, 02:24 PM   #354
skeebs
skeebs's Avatar
I did it in my TJ and it wasn't bad, I assume an XJ is gona be about the same process.
skeebs is offline   Reply With Quote
Old 09-02-2009, 05:21 PM   #355
deltl1ks
Great thread,
deltl1ks is offline   Reply With Quote
Old 09-02-2009, 09:08 PM   #356
tulman22
tulman22's Avatar
Subscribed!
US Navy "SPOOK" RETIRED
Impact Orange member # 39
tulman22 is offline   Reply With Quote
Old 09-03-2009, 10:58 PM   #357
SHAKEnBLAKE
SHAKEnBLAKE's Avatar
if you're in texas, I wouldn't guess too bad.
I'm in salty winter muddin ohio and every bolt on my jeep is seized. Mine was pretty straightforward, and if you search around there are some good writeups. The only snag was removing the pitman arm. A pickle fork did not cut it. a harbor freight puller did not cut it. We ended up calling our mechanic buddy and he brought a quality, adjustable pitman arm puller and the beast came right off!
We somehow broke the clock spring though, so I am airbag and horn-less til I fix that. And no, we didn;t turn the wheel while the box was off.
Shake & Bake with SHAKEnBLAKE - "Build Thread"
www.ohio4x4.com
98 pile o' parts: 4.0L, 3spd auto, 4", 35" KM2s, XRC8, 4.10s, MCE flatties, KOZ cage
SHAKEnBLAKE is offline   Reply With Quote
Old 09-04-2009, 02:41 AM   #358
propjockey2002
Originally Posted by Peej03 View Post
Okay thanks!
Any idea what year dodge amp will fit an 03? It has to be the 4.7 for the 160 amp right? I thought i read it in here somewhere but cant find it now...
Seems like a lot of dodge parts swap over to the tj.. What about driveshafts? I was looking at a ZR2 s10 and the driveshafts looked bomb proof, I was wondering if they or (if the dakota maybe had tough shafts too?) could be cut to fit a sye/front/rear tj?
You need the 160 amp alternator from the 04 Dodge Durango with the 4.7L V8. You will have to cut off one mounting bracket from the alt, but iother than that its a direct bolt up.
propjockey2002 is offline   Reply With Quote
Old 09-04-2009, 04:26 AM   #359
VanBCguy
Subscribe to the thread. Just as easy, if not more so. E-mail update options too.
Savvy Off-Road: http://www.savvyoffroad.com
VanBCguy is offline   Reply With Quote
Old 09-04-2009, 04:58 AM   #360
rikkards
Ignore this
On my deathbed, my final wish is to have my ex-wives rush to my side so I can use my dying breath to tell them both to go to hell one last time. - Ron Swanson
rikkards is offline   Reply With Quote
Glock Forum
