Quantcast Budget Junkyard Upgrades - Page 23 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Budget Junkyard Upgrades
Front and rear Drive shafts @ free shippingPoison Spyder February Special: FREE Rubber Liners when yoSlappin' on 61,510 Rigid Industries Lumens for Big Red
Old 07-18-2009, 03:43 PM   #331
Mini-Me26
Originally Posted by MudDuck99 View Post
with the durango steering box what exactly do i need to look for?
98-99 Durango, 318 engine, with 4x4 option. Plow option is available on 98, IINM, and has a lower lock-to-lock rotation.
Mini-Me26 is offline   Reply With Quote
Old 07-19-2009, 05:48 AM   #332
MudDuck99
SWEET...im going to go find one tomorrow. i know where a few durangos are
[FONT="Arial Black"][SIZE="4"][B][COLOR="Teal"]Founder of the Steel Blue Jeep Group[/COLOR][/B][/SIZE][/FONT]
MudDuck99 is offline   Reply With Quote
Old 07-19-2009, 12:43 PM   #333
jaminj
steering Box
So th durango box bolts right up as long as you get 98-99 no other things you need?? The drop pitman arm on my current 4 cyl. will work also just need some clarification as I think this sounds like a awesome upgrade
jaminj is offline   Reply With Quote
Old 07-19-2009, 01:41 PM   #334
Mini-Me26
Look two posts above. You'll have to keep your current pitman arm because the Durangos use a ball joint to connect to the drag link. At least mine did. The Durango box bolts right up to 97-02 (may be wrong on the latter year) and requires some modding on 03+ (which has been reported on, use the search function to find it).
Old 07-19-2009, 04:24 PM   #335
Peej03
Been searching to try and find what is needed for modding the 03 for the Durango steering box.. cant really find anything.. Anyone know anything or could give me a helpful link?
And Any Grand Cherokee year tie rods will fit on any tj?
They Call me..Peej
2003 TJ SE Trail Rider/DD
1982 CJ5 Project
Peej03 is offline   Reply With Quote
Old 07-19-2009, 04:36 PM   #336
Niceface
Needs to be a V8 I believe
JGM Enterprises- Click It!
Niceface is offline   Reply With Quote
Old 07-19-2009, 04:39 PM   #337
Mini-Me26
'03+ extra steps: http://www.jeepforum.com/forum/f9/durango-steering-gear-late-model-tj-03-06-a-816687/
The Grand Tie Rod and ends that are stronger than the stock TJ ones are from a '95-'98 (or is it '99?) V8, both 5.2 and 5.8, I believe.
Old 07-19-2009, 05:37 PM   #338
Peej03
Okay thanks!
Any idea what year dodge amp will fit an 03? It has to be the 4.7 for the 160 amp right? I thought i read it in here somewhere but cant find it now...
Seems like a lot of dodge parts swap over to the tj.. What about driveshafts? I was looking at a ZR2 s10 and the driveshafts looked bomb proof, I was wondering if they or (if the dakota maybe had tough shafts too?) could be cut to fit a sye/front/rear tj?
They Call me..Peej
1982 CJ5 Project
Old 07-20-2009, 08:42 AM   #339
mike090702
Spring Swap
I was reading the post on the ZJ front springs, and moving the TJ's front springs to the rear. Has anyone else tried this? What else is needed? It sounds to simple to add 3". The way it sounds no lines need to be extended, or anything else. Just swap the springs!! Do the stock absorbers still work with this mod.?
Mike
mike090702 is offline   Reply With Quote
Old 07-20-2009, 09:07 AM   #340
timritchieblue
Mike
been their done that, does it work, yes. will you be happy, no.. just buy the proper springs, the zj frt springs ride like crap (stiff), if you have a 6cly, you wont get that much lift 1.5" woo-ho! getting the tj frt springs in the rear is not easy, and you end up with a very bouncy ride. just call jeffery @ ROUGH COUNTRY spend $300, and get a real nice lift..
FOR SALE:SOLD
2000 TJ 2.5" CLAYTON L.A. W/HYDROS, SYE/XJ SHAFT, 4:10 GEARS, 8.8 MINI SPOOLED, LOC-RIGHT FRONT, 1" BODY LIFT, 1" MML, 35" MAXXIS BIGHORNS, RE GEN 2DISCOs, BELLY UP, ALCOS IN FRONT, WARN X8000I
timritchieblue is offline   Reply With Quote
Old 07-20-2009, 09:12 AM   #341
mike090702
Yep, got the 6cyl.. Thanks for the advice. Will give him a call this week.
Old 07-28-2009, 05:05 PM   #342
StellaTheZJ
Mike, shock absorbers and lines only *really* need to be changed if you're changing the control arms too. Unless your shocks are on the short side, it's the control arms that limit droop - not the shocks or the lines. With 2", 3", 4" of lift, doesn't matter. It's not the springs that limit droop, so chaging springs will not endanger your lines. If you change the control arms though, all bets are off for the shocks and lines!
For an XJ or ZJ, the YJ rubber lines are a bolt in swap, and much longer, for the front. Is this true for a TJ too?
A longer rear line is not required for a lifted ZJ, don't know about how the TJ lines are run. Again, the YJ one is a good option for a lifted XJ.
StellaTheZJ is offline   Reply With Quote
Old 08-24-2009, 06:42 AM   #343
ex m38a1er
ZJ overhead console on a TJ?
What do you think?Especially 2.4 03?
I saw someone doing this on a XJ...
ex m38a1er is online now   Reply With Quote
Old 08-24-2009, 07:17 AM   #344
rikkards
Stupidly simple but the little clip that holds the hood prop kept popping off and I finally lost it. Grabbed a spare rare earth magnet and a little electrical tape to keep it from sliding up and down the rod (hehe) and lo and behold, it works.
On my deathbed, my final wish is to have my ex-wives rush to my side so I can use my dying breath to tell them both to go to hell one last time. - Ron Swanson
rikkards is offline   Reply With Quote
Old 08-24-2009, 07:52 AM   #345
sshrrt
sshrrt's Avatar
i have a stock set up except for some RC 2-4in hydro shocks and I just came across some RE 3.5in coils. If I go from stock to 3.5in do you guys know what else I might need? Like trac bar relocation brackets, pitman arm, or t-case drop? Shouldn't need SYE or CV shaft b/c its under 4inches right?
when your happy as a bird with a french fry, you are having a good day...
sshrrt is offline   Reply With Quote
Glock Forum
