#16 | ||
I used an xj front shaft, had my friend cut it for me. Total cost was 60 bucks (shaft and new 1310 - 1330 u joint) ![]()
1999 Jeep Wrangler Sport |
#17 | |
Will ZJ rear springs lift a TJ 3" in the rear? I'm working on a camping trailer, i need 3" rear TJ coils (or something compatable) to level it out behind my XJ. I need the pigtails to be the same size. |
#18 |
Trust me....
ZJ coils with isolaters from a V8 will lift the front about 3"
Crown Vic rear springs will lift the rear about 3.5" Try to get the ones from a police interceptor, they are a little stiffer. Read this thread http://www.jeepforum.com/forum/f9/zj-cv-3-5-lift-wrangler-276656/
Patriot Blue 2001 TJ Everything I need to fix on the heep: ABS indicator, speed 4 on the blower fan, torn softop over driver's head, both seat release/tilt cables, missing center cap on spare, broken under hood light, wire up the CB, wiring problem with the reverse lights, broken bottle jack, leaky front and rear pinion seals, loose trackbar relocation bracket, torn drivers seat on the side, broken center console lock, lost nuts for door hinges, squeaking centering ball, loose parking brake cable, oil change and rotate the tires. My build threadhttp://www.jeepforum.com/forum/f22/free-wife-good-home-pics-included-528892/ Last edited by dogbluedrummer; 02-19-2008 at 02:11 PM.. |
#19 |
ZJ rear coils have a 4.02" inner diameter
TJ rear coils have a 5.05" inner diameter I believe ZJ rears are only pig-tailed at one end as well. TJs are at both ends. Also not sure they'd give the right amount of lift anyway, so probably not worth the time to try and make them work. |
#20 | ||
Where are those prices for the ZJ springs from?? For example is it a website/junkyard/autoparts store. Thanks in advance
1999 TJ Wrangler, 4 banger 5-spd Soft-top, full doors 31" BFG AT, 3" Lift 1954 CJ3B Willys Hurricane 4, 3-spd with Warn Overdrive, Snow-plow NGJC# 15 Low Output 4 cylinder Jeep Club Member #166 Build Thread Are You An Offroad Junkie Quote:
#21 | |
Trust me....
Those are prices for new springs from an auto parts store. They may be a little dated, but still relative.
Patriot Blue 2001 TJ Everything I need to fix on the heep: ABS indicator, speed 4 on the blower fan, torn softop over driver's head, both seat release/tilt cables, missing center cap on spare, broken under hood light, wire up the CB, wiring problem with the reverse lights, broken bottle jack, leaky front and rear pinion seals, loose trackbar relocation bracket, torn drivers seat on the side, broken center console lock, lost nuts for door hinges, squeaking centering ball, loose parking brake cable, oil change and rotate the tires. My build threadhttp://www.jeepforum.com/forum/showthread.php?t=528892 |
#22 |
my TJ is almost completely built of OPJ (other peoples junk). At various times I have had or helped others with:
-V8 ZJ tie rod. -ZJ complete front axle (3.73 ratio) instead of paying for regear. -XJ complete HP front axle -TJ axle shafts in older model XJ housing (for bigger ujoints) -ZJ, XJ, or TJ front driveshaft to build a rear CV driveshaft -ZJ front springs for lift -ZJ disk brakes -ZJ or XJ stock pitman arm = 4" drop pitman arm for TJ -Used 4.10 rubicon "thick" gears to regear a D44 so we would not have to buy a new carrier. I'll think of more later.....
97 TJ Sport OPJ project (other peoples junk) I can't remember the last time I bought a new part. |
#23 |
I have ZJ springs front and back and mine is level, so i would try that if you can before spending money on other springs...
2001 Wrangler Sport 4.0, 5 speed, 30/35 axles, 3.73's, ZJ springs, 1"BB, 31" Futura M/Ts [url]http://www.cardomain.com/ride/2634280[/url] |
#24 | |
so you have 2 front axles? also, what year ZJ tie rods work?
#25 | |
ujoint ?
Thanks
No matter how far you go, there you are. |
#26 |
I am now on my 3rd front axle. First was the original TJ, next was a 3.73 ZJ, now I'm putting in a 4.11 XJ HP.
As far as I know any V8 ZJ tie rod will work 94-98. I did this mod because I had a beat up ZJ in the yard and a spare TJ tie rod laying around, so I traded them. Not sure how much I'd actually pay for it. It is substatially heavier than the TJ, XJ rod. You can also buy it new from the parts store (one end of it is a tie rod end, but the other end is built into the rod itself-ie no replaceable end on it).
#27 |
This is off subject but i've been having problems with my front springs. I have the OME zj 1" lift front springs. I got them to help with the weight of my Warn 8274. Yall say that the stock ones are 3" lift so these should be 4" lift, right? They are not even level with the 2.5" Skyjackers that I have on the rear. Can anyone help me figure out why?
Thanks
2004 Tj X, 2.5 Skyjacker rear, OME ZJ front, 285/75 16 A/T's on moabs, Bedlined stuff, some offroad Lights, Warn 8274 w/ Warn plate, Aussie front, Truetrack rear, PSC trail corners, Pro-comp adjustable front trackbar, 1 1/8" skateboard wheel bl, Teraflex bmml |
#28 |
Another junkyard topic....pick up an intermittent wiper switch from a Cherokee or Neon if your Wrangler is not equipped with that option. Should be cheap, and its an easy swap.
----------------------------------------------------------------------------- '99 TJ SE, 2.5 / Ax5 / NP231, D30/35, 4.11 Intense Blue, Dual Tops, Full Hard Doors / Soft Doors 31" BFG ATs, Canyon Wheels, Warn M8000 Winch, Cobra CB '07 Patriot Limited, 2.4 / 5 Speed, 4x4 FDI, Jeep Green |
#29 |
dont use a ZJ front axle, its a LP D30. If you are going for a front axle, get one from a XJ where it is a HP
Ha, you can't get there.....hrm, watch me. 2008 Wrangler Unlimited X. 4dr, 4x4, 3.8 V6, 3.73 D44 LSD. 93 Grand Cherokee Laredo. SOLD. Sad to see it go. |
#30 | |
Oops, sounds expensive!
(81 CJ, 92 YJ, 97 TJ, All Gone) 05 TJ Rubicon Stupity Kills, but not nearly enough. |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
