budget/junkyard cv driveshafts, who runs them? Do you like?
#1 | |
Ive been doing some research and it looks like its possible to run an explorer or cherokee front driveshaft, after shortening, with the sye kit if you are on a budget?
Does anyone have any experience with this? What are the pros and cons?
#2 |
MyJKRocks!
I ran a cherokee shaft on my YJ for a few years with good luck. I have cherokee shafts front/rear on my TJ now.....no issues to this point. It's a good inexpensive upgrade.
#3 |
how much did they cost?
#4 |
Mine was $110; $50 for the drive shaft, and $60 for the cut and balance. Make sure you check the CV joint and try to look at the vehicle it was pulled from. If they have to straighten it, and you have to rebuild the CV joint, it could easily cost as much as a new one.
'02 TJ X Apex Edition '00 XJ Sport |
#5 |
thats what i was thinking, all those ujoints add up if you have to rebuild it.
#6 |
I have used jeep cherokee and wrangler front shafts shortened for the rear several times with good results. You can grind the weld down, and knock out the end, then cut the tube, tack it, check for straightness, then weld the bead. It won't be balanced, but be plenty good enough for a part time driver and trail rig.
V-8 wrangler: http://www.jeepforum.com/forum/f9/v-8-unlimited-build-562450/ |
#7 |
I've got a explorer drive shaft in the rear of my TJ. Works great!
I can't think of any pro's or con's Cost $40.00 Cut and balance $140.00
Canadian Jeep Club Member #5 |
#8 |
great stuff guys, this is the input i was looking for. Im currently trying to put together a build sheet on a budget and i didnt particularly want to spend almost $400 on a cv driveshaft after the sye kit.
I wanted to build a low CG jeep on 33s but the little woman wants a mall crawler which means more work and money |
#9 |
What measurements do you have it cut too?
97 TJ 4.0, AX15, Back halfing w/ tons and 4?s Stop by and check us out Western Mass 4x4 or Check us out on Facebook and be sure to stop by and like the NEA4WDC while your there. |
#10 |
I use a Cherokee front shaft for my sye. 30 bucks the shaft and 25 for a 1310-1330 u joint. I had my friend cut and weld the shaft, I never even got it balanced, it doesn't vibrate at all.
1999 Jeep Wrangler Sport |
#11 | |
#12 |
Any know how long these are to start with? Wondering how much shortening it would need to be used in a LJ?
#13 |
Does it matter what year of Cherokee?
1995 YJ SBC 350, Auto Trans, 4" lift, 33's |
#14 |
#15 |
I believe any 4-door XJ front driveshaft will work, however you will want one from an Automatic, as they will be longer.
Trombino -- '04 TJ -- Rubicon Express 4.5" Superflex + 3/4" Front Spacers, OME Shocks, Currie Rear Shock Relocators, JKS 1.25" BL, JKS BMML, JKS Quicker Discos, 15x8 Cragar Soft 8's, 35x12.50 BFG KM's, LoD Heavy Duty Rear Tire Carrier, Chopped Front Bumper, Uniden 520XL w/ 3' Firestik II, Skyjacker Steering Box Skid, Rusty's Engine Skid, IPF H4 Conversion w/ Fatboys, Hella 500 Windshield Driving Lights, Tomken Gas Tank Skid, ARB Rock Sliders, PSC Rock Ring (D30), Riddler (D44), MV50 OBA, Rusty's Air Tube, TBS, Flowmaster 40, Dana 44 with Trac-Loc, Warn XD9000i w/ Grill Guard The Wife -- '02 KJ Limited -- Pre-Lowered, Full Mopar Skids, 245/70-16 General Grabber AT2's, Trac-Loc Rear, Flowmaster 50 SUV |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
