Budget Boost Bump Stops - JeepForum.com
post #1 of 7 Old 07-28-2010, 11:26 PM Thread Starter
Lucille92
I have 31" tires on my jeep and im about to get a 2.25" BB. The BB comes with rear bump stops, but not front ones. Should i not worry about it with these tires or should i invest the $20 and get a set of front bump stops? (or even use the hockey puck trick?)
Lucille92 is offline
post #2 of 7 Old 07-29-2010, 05:47 AM
TheBoogieman
Dead Jeepers Club
TheBoogieman's Avatar
That's up to you.I've never used longer front bumpstops with a 2,25" lift and 31's.
TheBoogieman is offline
post #3 of 7 Old 07-29-2010, 10:59 AM Thread Starter
Lucille92
Thanks man
post #4 of 7 Old 07-29-2010, 11:01 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
depends on shock length and whether you have enough space to compress the springs in the tower
what's the collapsed length of the aftermarket shocks you'll be using?
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #5 of 7 Old 07-29-2010, 11:10 AM Thread Starter
Lucille92
I'll be using the Skyjacker Hydros. Collapsed: 13.71"
post #6 of 7 Old 07-29-2010, 11:12 AM
TheBoogieman
Dead Jeepers Club
You're fine.Don't over think it.
post #7 of 7 Old 07-29-2010, 11:15 AM Thread Starter
Lucille92
Haha i figured i was fine. Just wanted to make sure
tj , wrangler , bb , budget boost , bump stop
Bump stop extenders pushing past Bump stops. KraZeDav YJ Wrangler Technical Forum 5 09-12-2009 03:57 PM
Budget boost without bump stop extensions rpiereck TJ Wrangler Technical Forum 5 06-15-2009 02:54 AM
are the bump stops suposed to hit when i go over a bump? MC_NickP TJ Wrangler Technical Forum 10 03-01-2009 06:40 PM
Extended Bump Stop Budget Boost Advice RAAB3485 TJ Wrangler Technical Forum 1 02-21-2006 03:19 PM
Bump Stops - what is really out there? tomwbates YJ Wrangler Technical Forum 3 01-14-2004 02:08 PM
