Budget Boost & Body Lift Bad Idea? - JeepForum.com
post #1 of 18 Old 02-21-2007, 08:37 AM Thread Starter
DesertTJ
Has any one had any problems running a bb and a 1" body lift? Handling, cornering, highway dirving? I was wondering because i hit full flex with my 2.25 BB and i max my tire out on my fender clearance. Another inch would help when i disco the sway bars.
4" Super Lift, Old Man Emu Steering Stabilizer, Pro Comp ADJ Track Bar, PS Rocker Knockers, Euro Tail Guards, Safari Headlight Guards, Bush Wacker Stone Guard, Bug Screen,4- 100 Watt KC Fog Lights, Silverstar Headlights, Optima Yellow Battery, Poweraid Throttle Body Spacer, Neoprene Seat Covers, Custom High Jack Mount, Custom Gas can mounts, Vertically Driven Sound Bar, 5.25 Speakers Up Front, Custom Decals, 15x10 Soft 8's wrapped in 32"x11.50 BF Goodrich AT, Crown Brake Line Extensions, Hawk Brake Pads, SpeacialTFX Cargo Net, CB Radio With Fire Stick Anntena, Skid Row Steering Gear Box Skid Plate, Besttop Half Door Sliders, Sky Jacker Quick Disconects, Westin Nerf Bars
Colorado Jeep Club Member #?
Chicks dig scars, So trail damage is hot!
99 Sahara
DesertTJ is offline
post #2 of 18 Old 02-21-2007, 08:40 AM
crawl1n
I don't see you having a problem. I am running a 4.5" lift with a 1.25" BL and don't have a problem with it. I know quite a few people who went with a BB and 1" BL to be able to run 33's using an inexpensive lift.
97 TJ SE HP44 ARB, 9" Detroit, 5.13, 36x12.5 TSL's, RE 4.5" Superflex, JKS 1.25" BL, Goferit 1" MML
06 Jetta TDI for daily driving duties
crawl1n is offline
post #3 of 18 Old 02-21-2007, 09:00 AM
FLATFENDER54
FLATFENDER54's Avatar
I dont have one but many on here do and report no problems
01 TJ Sahara 4"short arm/rear gas&tire
carrier bumper/front winch bumper winch/detroitEz
1954 WILLYS CJ3B (under construction)
FLATFENDER54 is offline
post #4 of 18 Old 02-21-2007, 09:14 AM
stevensinger
stevensinger's Avatar
Thats is my next mod, I have an REBB now and want to add 1 inch BL & MML so I can clear 33s
Hello, my name is Steve and I am a Jeepaholic.
"Overkill" is a Supercharged RockCrawler 2008 Jeep JK - Pushing 8psi of Boost to be the fastest one up the mountain! 4.5 Inches of MetalCloak lift, Stuffing 37s /w 5.13 gears running the track at mid 13s. #cloaked #RIPP #JEEP
10k Winch
Smitty Mid Frt Bumper w/LED
JW Speaker Head Lights
AND ONE UNDERSTANDING FIANCE
Next: ?
stevensinger is offline
post #5 of 18 Old 02-21-2007, 09:50 AM
bono426
bono426's Avatar
2005 WK
will you just barely clear them or will it be a nice fit?
2005 WK HEMI QDII 2" BB on JK Rubi Tires. Retro Fitted MyGig
bono426 is offline
post #6 of 18 Old 02-21-2007, 10:55 AM
Bigbob
Bigbob's Avatar
33" tires should work fine with a 2" BB and 1" BL. You of course will need to have the proper bumpstops so the tires don't grind off the flares.
2006 Solar Yellow Rubicon Unlimited
Jeep Club Member #1340
6 Speed, Hardtop
Mods done: Hurst tee handle, cheap hand throttle, Rokmen Merc front bumper, Warn 9.5 TI winch with 3/8" X 100 worth of Viking yellow rope, DPG OME Ultimate with JKS ACOS up front, Kilby Gas Tank Skid, Kilby Steering Box Skid, Jeep Medic Belly Up, Skidrow Engine Skid, Rockcrusher Diff Skid in the rear, Warn Diff cover in front, , AR Outlaw II's and MTR 12:50/15's, Homemade rear Bumper, Cheap Cobra CB, Puma OBA, Sirius Radio, Locker Defeat, Rockhard cage, Rockmen short corners, homemade tire swing/tailgate hinge affair, Airlift air bags on the rear- - - - - - and more to come!
Bigbob is offline
post #7 of 18 Old 02-22-2007, 08:18 AM Thread Starter
DesertTJ
Im going to stick with my 32's. I just want a little more room for flex before i hit the fenders. Thanks for your reply's, if any one has pre advice on methods of installing the JKS 1.25 body lift please let me know.
99 Sahara
DesertTJ is offline
post #8 of 18 Old 02-22-2007, 08:44 AM
zer010gic
Who makes the BB that you are using.
Corey
zer010gic is offline
post #9 of 18 Old 02-22-2007, 08:57 AM
Dogman
Dogman's Avatar
This is the Rubicon Express BB 1.75", 1" BL and 31 x 10.5
John 3:17
Dogman is offline
post #10 of 18 Old 02-22-2007, 10:47 AM
SecondTJ
SecondTJ's Avatar
there is nothing wrong with a 1" BL, it will give you the proper clearance you need to flex with those 32s. go for it
'98 Sport, 4.0, AX-15, D44, 3.73, stock w/ 10k original miles
Gone - 2000 Sport, 1987 YJ, 1997 SE, 1998 XJ
SecondTJ is offline
post #11 of 18 Old 02-23-2007, 07:17 AM Thread Starter
DesertTJ
My BB is the one advertised on the main banner on this web site. I cant remember the name of the web site. They offer different packages, i went with 2.25 coil spacers and RE Monotube shocks. They make a world of difference. The extra .25"helps, when a normal BB settles it's usually around 1.75" mine settled at 2".
99 Sahara
DesertTJ is offline
post #12 of 18 Old 02-23-2007, 07:38 AM
SpoiledRotten
SpoiledRotten's Avatar
I don't believe you will need the 1'' BL if you extend you bump stops to keep your tires out of the fenders. That is what I did and the tires don't even come close.
Christian Jeepers _ Member #2
United Four Wheel Drive Association _ Member
National Rifle Association _ Member
SpoiledRotten is offline
post #13 of 18 Old 02-23-2007, 07:52 AM
PeteC
Ran 33x9.5 BFG AT's with an 2" REBB (1.75" actual), 1" BL and proper bumps stops for 3 years with 0 rubbing even at full flex. Ran 33x12.5 for the last year without changing anything else and the only rub I got was at full flex and then it was just a push out on the fender flares.
I never experienced any handling problems on or off road with this set up. With the Doetschtech shocks (when new) it rode better than stock.
So, yes, adding a 1" BL your 32's will have more than enough room and you should not be giving up and handling or feel.
'00 TJ With toys, lift and tires.
'10 Dodge Ram 1500 Quad 4x4. Daily driver and tow rig
'05 Dodge Neon. Wifes daily driver and gas sipper.
There is no Bandaid for Stupidity
Sorry if my support of legal wheeling offends you
PeteC is offline
post #14 of 18 Old 02-23-2007, 12:52 PM
lupinsea
lupinsea's Avatar
Here's my Jeep with the RE 2" BB and a 1" BL/MML combo. It works very well and gives just enough clearance for the 32x11.50s.
- Jay
lupinsea is offline
post #15 of 18 Old 02-23-2007, 05:32 PM
HipCheck_1
I have a 2" inch Body Lift and a 2" Budget Boost and I have no issues or major changes with handling, cornering, or highway driving.
Of course it is not a sports car....
HipCheck_1 is offline
Body lift VS. Budget Boost jake7893 TJ Wrangler Technical Forum 48 08-20-2009 08:59 AM
What's the difference between a Budget Boost and a Body Lift staquinas TJ Wrangler Technical Forum 26 08-06-2009 02:14 AM
Jeep (budget boost or body lift) JCWrestler TJ Wrangler Technical Forum 14 07-02-2008 06:20 PM
Budget Boost and Body Lift question rooster5333 JK Wrangler Technical Forum 5 10-28-2007 04:11 PM
body lift or budget boost RON310 TJ Wrangler Technical Forum 15 10-17-2007 10:29 PM
