Budget boost and 33x12.5 tires - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Budget boost and 33x12.5 tires
FREE, FREE, FREE EVENT!! Save big on Lockers now till ApriJKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6Teraflex JK HD Hinged Carrier & Adjustable Spare Tire
Unread 09-06-2010, 01:42 PM   #1
Zeusismyonlygod
I have a rubicon express 2 inch BB and I was wondering if 33x 12.5 tires would fit or if I would have to do a few little tweaks to some things... If so please let me know what all you did or what I need to do. Thank you
Zeusismyonlygod is offline   Reply With Quote Quick reply to this message
Unread 09-06-2010, 01:47 PM   #2
Neil F.
You can run that on the street just fine but don't expect to clear if you off road with any big suspension movement.
Neil F. is offline   Reply With Quote Quick reply to this message
Unread 09-06-2010, 01:50 PM   #3
Zeusismyonlygod
I plan on getting a bigger lift but your saying that on the street they will run fine with a little or alot of rubbing..
Unread 09-06-2010, 01:56 PM   #4
jeepinmichguy_
get a 1.25 inch bl and extend your bumpstops.
[CENTER][SIZE="4"]ΜΟΛΩΝ ΛΑΒΕ[/SIZE][/CENTER]
[QUOTE=TheBoogieman;12766892]Jeepinmichguy is a jerk.[/QUOTE]
[QUOTE=mrblaine;12000822]
How about this, if you had the Jeep Spirit, you wouldn't abuse the rest of us trying to enjoy a nice day out wheeling by bringing your brokeass broken down junkyard crap out to play where it can't handle it?[/QUOTE]
[QUOTE=JeepForum123;13578398]you all have nice rigs, stop being f****** a**holes.[/QUOTE]
jeepinmichguy_ is offline   Reply With Quote Quick reply to this message
Unread 09-06-2010, 01:58 PM   #5
Zeusismyonlygod
already got the BL but havent installed it yet.. and are extended bumpstops needed?
Unread 09-06-2010, 02:13 PM   #6
k9cop
Yes or you will rub when off road. Probably use the washer mod so when at full steer you won't rub as well.
k9cop is offline   Reply With Quote Quick reply to this message
Unread 09-06-2010, 02:15 PM   #7
Zeusismyonlygod
what is the washer mod?
Unread 09-06-2010, 02:26 PM   #8
Boston_Wheeler
You can adjust your steering stops by removing them, adding washers and re-installing the stops. This will help prevent rubbing at full turn. Check out Stu Olson's site for a good write-up.
Boston_Wheeler is offline   Reply With Quote Quick reply to this message
Unread 09-06-2010, 02:26 PM   #9
Zeusismyonlygod
ok thank you
Unread 09-06-2010, 03:44 PM   #10
stuntjumper
With 33x12.5 you'll need new wheels with about less backspacing or some wheel spacers. Although I would never pay for spacers, I'd get a cheap set of soft 8's instead.
Also, the BL will help a lot as well and the bumpstops will be necessary off road and possibly for large pot holes.
stuntjumper is offline   Reply With Quote Quick reply to this message
Unread 09-06-2010, 04:49 PM   #11
Neil F.
On the street you will be fine.
When I go mine it had 33x12.5 on AR Baja wheels (don't know the backspace), Bushwacker 6" flares and a 1.25 BL, no suspension lift. I had no rubbing on the street or light trails. No disconnecting. I ran that for 2 years. The PO ran that way for who knows how long. (The tires were bretty bald)
Plenty of people have run 33's with a 2" BB on the street.
Unread 09-06-2010, 06:21 PM   #12
2ellas
I am running a 2" teraflex bb on 15" wheels with 3.75" backspacing and 33x12.5x15. I haven't had any rubbing on the street even at full turn. Haven't been off road yet but my main concern is that my tires are sticking out 3-4" past my flares and I have to get an inspection this month. Hope they're cool about it.
2ellas is offline   Reply With Quote Quick reply to this message
Unread 09-06-2010, 06:59 PM   #13
Cavitation
33s on 3 inches of lift is about max. I take it you will have 2 inch spacers and 1.25 inch BL? If so you will be fine even for some pretty stiff off road. I only have 3.25 inches of suspension lift and I have not rubbed yet. I have done Moderate wheeling with the front end disconnected. This rock is probably about 20 to 24 inches high.
Cavitation is offline   Reply With Quote Quick reply to this message
Unread 09-06-2010, 07:58 PM   #14
whooda
4'' lift with 285 75 16 (32.8") tires. I have installed 2" bump stop extensions and still rubbed pretty bad. I bent the fenders and cut the tires a little when I would fully stuff either tire.
whooda is offline   Reply With Quote Quick reply to this message
Unread 09-06-2010, 11:30 PM   #15
jeepinmichguy_
as soon as he starts to get some decent flex he will rub big time, speaking from experience with a 2.25 in bb, 1.25 inch bl, shocks and discos. i rubbed on all 4 corners without extended bumpstops and bent the front fenders (the metal) up a little bit. he will not be ok off road.
