bucking and surging in first gear - JeepForum.com
post #1 of 12 Old 05-11-2012, 07:40 AM Thread Starter
jeepin1995
jeepin1995's Avatar
jeep has been doing this a while. if i cruise in 1st or second for an extended perion of time (think riding thru a parking lot) and go to accelerate after said ride, it starts bucking and surging bad. i push the clutch and it runs normal again. no codes, no spits, sputters otherwise. its a 98 with 4.0L, 139000 miles, manual trans.
any ideas?
"IF YOU CAN'T DAZZLE THEM WITH FACTS, BAFFLE THEM WITH BS"
jeepin1995 is offline
post #2 of 12 Old 05-11-2012, 08:26 AM
TheBoogieman
Sorry ATL. #5 soon
TheBoogieman's Avatar
My old 98' used to do that really bad.I put some Lucas fuel injector cleaner in it and it never did it again.
TheBoogieman is offline
post #3 of 12 Old 05-11-2012, 09:56 AM
JWebber
You need a good tune up or you need to test your fuel pump psi.
JWebber is offline
post #4 of 12 Old 05-11-2012, 10:01 AM
RedStep
My 97 does this too, didn't think much of it until I saw this. Usually just happens in first though, sometimes if I step on it harder than normal in second it jerks a little bit. Mine also has the original clutch at 76k miles so I thought that could have something to do with it
RedStep is offline
post #5 of 12 Old 05-11-2012, 10:19 AM Thread Starter
jeepin1995
jeepin1995's Avatar
clutch is new (couple months ago) will give a full tune-up and see what that does for it. probably needs one regardless. and i will check fuel pressure. thanks for the starting points.
post #6 of 12 Old 05-11-2012, 10:25 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Have you ever replaced the upstream 02 sensor?
If not, might not be bad idea with your mileage.
Wheelin98TJ is offline
post #7 of 12 Old 05-11-2012, 10:37 AM Thread Starter
jeepin1995
jeepin1995's Avatar
dont know if its been replaced. only had the jeep since november.
post #8 of 12 Old 06-19-2013, 06:04 PM
StanF
any ideas?
What was the resolution for your problem?
StanF is online now
post #9 of 12 Old 07-01-2013, 09:12 AM Thread Starter
jeepin1995
jeepin1995's Avatar
never found a resolution........
post #10 of 12 Old 07-02-2013, 08:01 AM
StanF
This might help someone here...
I solved my problem by replacing cleaning the IAC/TB, replacing TPS, spark plugs and IAC. Unfortunately, I did everything at once, so I'm not sure which one was the solution. YMMV
StanF is online now
post #11 of 12 Old 07-02-2013, 08:27 AM
Greenfun2
If I had to guess, I would say the TPS is what did it for you.
Greenfun2 is offline
post #12 of 12 Old 07-02-2013, 12:41 PM
StanF
Agreed! It was most likely the TPS. Wish I had done things more methodically, but it was easier to do everything at one time.
StanF is online now
jeep surging in 1st gear sixmanz TJ Wrangler Technical Forum 3 08-12-2010 05:56 PM
1st gear bucking tchthsky TJ Wrangler Technical Forum 12 06-15-2010 03:11 PM
Violent Bucking/surging after vacuum fix Tranquilize TJ Wrangler Technical Forum 18 02-07-2010 08:10 PM
Surging, bucking and dying Jeep25 TJ Wrangler Technical Forum 5 10-01-2007 05:36 AM
Surging in 4L 1st Gear Dogman TJ Wrangler Technical Forum 6 08-07-2005 01:22 PM
