Bubbling or Gurgling Sound from Engine - Page 2 - JeepForum.com
post #16 of 23 Old 07-28-2011, 12:20 AM
BYuen
BYuen's Avatar
Originally Posted by Knuckelhead View Post
Why?...
You're right. It's just every time I turned the heater on high it seemed that more air would come out than if I didn't. So just for the sake of it, I do it that way every time.
I just looked in my fsm and it says you don't even need to run the engine with the cap off.
COOLING SYSTEM-REFILLING
(1) Tighten the radiator draincock and the cylinder block drain plug(s).
(2) Fill system using a 50/50 mixture of water and antifreeze. This is described in the Coolant section of this group. Fill the radiator to the top and install the radiator cap. Add sufficient coolant to the reserve overflow tank to raise the level to the FULL mark.
(3) Operate the engine with both the radiator cap and the reserve/overflow tank cap in place. After the engine has reached the normal operating temperature, shut the engine off and allow it to cool.
(4) Add coolant to the reserve/overflow tank as necessary. Only add coolant when the engine is cold. Coolant level in a warm engine will be higher due to thermal expansion.
Then under...
COOLING SYSTEM DEAERATION
As the engine operates, any air trapped in cooling system gathers under the radiator cap. The next time the engine is operated, thermal expansion of coolant will push any trapped air past the radiator cap into the coolant reserve/overflow tank. Here it escapes to the atmosphere into the tank. When the engine cools down the coolant, it will be drawn from the reserve/overflow tank into the radiator to replace any removed air.
I've never had good luck with getting all the air out by this method, but it could have just been a bad radiator cap. I've just replaced mine. Next time I mess with the coolant I'll give it a try.
2001 White TJ Sport
2013 Black JKU Rubicon 10A
BYuen is offline
post #17 of 23 Old 07-28-2011, 11:57 AM
freeskier93
Then under...
Usually when I flush or add coolant I fill the rad up half way, run the engine until the thermostat opens, then continue filling until full. It's messy but gets almost all the air out. But the FSM method should work, usually when I flush everything and fill the next couple days I'll find the cap on the overflow bottle has popped off.
freeskier93 is offline
post #18 of 23 Old 07-28-2011, 12:11 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Why would it pop off when it has a large vent port?...
Knuckelhead is offline
post #19 of 23 Old 07-28-2011, 01:16 PM
freeskier93
Because it doesn't? Or at least '97 doesn't.
post #20 of 23 Old 07-28-2011, 04:49 PM
Erik T.
Pew Pew Vroom Vroom!
Erik T.'s Avatar
So is there any negative effect from over filling your reserve tank? Pretty sure I've done that.
Atla.
- For those in the Trenches of Responsibility
Humorous, Witty, Slightly Obnoxious - Political and Social Commentary in a World Gone Mad.
New Post 10/16 -
Erik T. is offline
post #21 of 23 Old 07-28-2011, 05:47 PM
BYuen
BYuen's Avatar
It will just spew out from the vent in the tank when things get hot.
2001 White TJ Sport
BYuen is offline
post #22 of 23 Old 07-28-2011, 07:37 PM
Knuckelhead
AFSOC Retired
I think it does.
Look at the rear, upper part of the overflow reservoir...
post #23 of 23 Old 07-28-2011, 09:01 PM
ryanlipski
thermostat
Get a new thermostat. I had that problem a while ago - thermostat would randomly open and shut on me. After I swapped it no more issues. I will admit that it could have needed bleeding but I'm not sure why that would have changed over time... Either way, it was a $5 fix.
ryanlipski is offline
coolant , gurgling , radiator cap
97 Sahara - HORRIBLE gas mileage, check engine light, gurgling sound from gas tank JeepGuy425 TJ Wrangler Technical Forum 6 05-09-2012 09:12 AM
Got 'perculating' in the engine. (you know, bubbling sounds like a coffee pot?) Erik T. TJ Wrangler Technical Forum 8 04-27-2010 01:46 PM
bubbling exhaust johnroot01 YJ Wrangler Technical Forum 9 10-05-2009 01:40 PM
Bubbling Paint Flyusaf2002 TJ Wrangler Technical Forum 3 12-22-2004 09:10 AM
gurgling sound from the engine?? TJdave TJ Wrangler Technical Forum 5 04-27-2004 02:06 PM
